American Laser Game
awaawaawa
I tried to follow the guide but I have some problem.
I want to configure without bat files.
I have this structure:
Daphne Singe\AMFrameFile media for ActionMax
Daphne Singe\singe\singe rom singe example \crimepatrol with roms and a subfolder with the cdrom
Daphne Singe\singe\ActionMax rom for ActionMax
With RocketLauncher I set the DaphneSinge emulator and the rom path. The rom extension are cfg|singe
The game audit find the game and when I try to launch the game it start and after a while nothing happen.
this is the log:
23:44:31:046 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com)
23:44:31:049 | RL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
23:44:31:214 | RL |     INFO  | +171   | Main - System Specs:
RocketLauncher Dir: O:\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 7 Ultimate
SKU: Ultimate
Total Memory: 8122.67 MB
Free Memory: 2609.56 MB
Used Memory: 5513.109 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 8
GPU 1 Name: NVIDIA GeForce GT 330M
GPU 1 RAM: 1024.00 MB
GPU 1 Driver Version: 9.18.13.4144
Sound 1 Device: NVIDIA High Definition Audio
Sound 1 Status: Enabled
Sound 2 Device: NVIDIA High Definition Audio
Sound 2 Status: Enabled
Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Sound 3 Status: Enabled
Sound 4 Device: NVIDIA High Definition Audio
Sound 4 Status: Enabled
Sound 5 Device: Realtek High Definition Audio
Sound 5 Status: Enabled
Sound 6 Device: NVIDIA High Definition Audio
Sound 6 Status: Enabled
OS Language: Italian_Standard
OS Admin Status: Yes
Monitor #1 (\\.\DISPLAY1): 1366x768 (1366x728 work) [Landscape] (Primary)
Current AHK Desktop Width: 1366
Current AHK Desktop Height: 768
AutoHotkey Path:
AHK Version: 1.1.09.04
Unicode: No
23:44:31:228 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\RocketLauncher.exe exists
23:44:31:232 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\BinHexRW.ahk exists
23:44:31:246 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:250 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\BlockInput.exe exists
23:44:31:253 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\CLR.ahk exists
23:44:31:260 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:264 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\COM.ahk exists
23:44:31:271 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:274 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
23:44:31:281 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:284 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\gdip.ahk exists
23:44:31:294 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:297 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\gdip_alt.ahk exists
23:44:31:304 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:309 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
23:44:31:312 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\gsdll32.dll exists
23:44:31:317 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Module Extensions\itextsharp.dll exists
23:44:31:321 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Java.ahk exists
23:44:31:331 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:335 | RL |   DEBUG1  | +15    | Java.ahk Version: 1.0.0
23:44:31:339 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\JSON.ahk exists
23:44:31:348 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:351 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Origin.ahk exists
23:44:31:361 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:365 | RL |   DEBUG1  | +15    | Origin.ahk Version: 1.0.2
23:44:31:369 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\RegRW64.ahk exists
23:44:31:376 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:380 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Module Extensions\RIni.ahk exists
23:44:31:391 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:396 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
23:44:31:402 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Steam.ahk exists
23:44:31:409 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:414 | RL |   DEBUG1  | +15    | Steam.ahk Version: 1.0.2
23:44:31:419 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\VA.ahk exists
23:44:31:428 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:44:31:431 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\VA_Extension.ahk exists
23:44:31:440 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:445 | RL |   DEBUG1  | +15    | VA_Extension.ahk Version: 1.0.1
23:44:31:449 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\7z.ahk exists
23:44:31:457 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:462 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.0
23:44:31:466 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Bezel.ahk exists
23:44:31:478 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:485 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.2
23:44:31:488 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\Lib\Fade.ahk exists
23:44:31:497 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:502 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.0
23:44:31:505 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Lib\Fade Init.ahk exists
23:44:31:513 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:517 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
23:44:31:522 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\Lib\Fade Animations.ahk exists
23:44:31:533 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:538 | RL |   DEBUG1  | +16    | Fade Animations.ahk Version: 1.1.6
23:44:31:543 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Pause.ahk exists
23:44:31:563 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:567 | RL |   DEBUG1  | +15    | Pause.ahk Version: 1.1.3
23:44:31:570 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Pause Init.ahk exists
23:44:31:577 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:582 | RL |   DEBUG1  | +16    | Pause Init.ahk Version: 1.0.2
23:44:31:585 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Keymapper.ahk exists
23:44:31:593 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:596 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
23:44:31:600 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\Lib\Keymapper Init.ahk exists
23:44:31:607 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:611 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
23:44:31:614 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Lib\MultiGame.ahk exists
23:44:31:622 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:626 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.7
23:44:31:628 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Lib\MultiGame Init.ahk exists
23:44:31:635 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:640 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
23:44:31:643 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\MultiPlayer.ahk exists
23:44:31:650 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:654 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
23:44:31:658 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Password.ahk exists
23:44:31:666 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:670 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.1
23:44:31:674 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
23:44:31:682 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:687 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
23:44:31:689 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Shared.ahk exists
23:44:31:702 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:707 | RL |   DEBUG1  | +16    | Shared.ahk Version: 1.3.0
23:44:31:711 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Statistics.ahk exists
23:44:31:717 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:722 | RL |   DEBUG1  | +15    | Statistics.ahk Version: 1.0.3
23:44:31:726 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Statistics Init.ahk exists
23:44:31:733 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:738 | RL |   DEBUG1  | +16    | Statistics Init.ahk Version: 1.0.1
23:44:31:741 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Virtual Drive.ahk exists
23:44:31:749 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:754 | RL |   DEBUG1  | +15    | Virtual Drive.ahk Version: 1.0.0
23:44:31:757 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\XHotkey.ahk exists
23:44:31:764 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:768 | RL |   DEBUG1  | +16    | XHotkey.ahk Version: 1.0.3
23:44:31:772 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\XHotkey Init.ahk exists
23:44:31:778 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:44:31:782 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.0
23:44:31:785 | RL |   DEBUG1  | +16    | Main - Raw CLI received: "-s American Laser Games -r crimepatrol -e Daphne Singe -f O:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1"
23:44:31:788 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "crimepatrol"
23:44:31:791 | RL |   DEBUG1  | +0     | Main - dbName: crimepatrol
23:44:31:793 | RL |     INFO  | +0     | Main - crimepatrol is being forced via CLI to use the emulator: Daphne Singe
23:44:31:796 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Plugins\HyperSpin.plugin exists
23:44:31:800 | RL |     INFO  | +15    | Main - Loading Front End Plugin: "HyperSpin"
23:44:31:802 | RL |     INFO  | +0     | Main - RocketLauncher received "American Laser Games" and "crimepatrol"
23:44:31:818 | RL |     INFO  | +16    | Main - Did not find a "O:\RocketLauncher\Settings\American Laser Games\Game Options.ini" file, skipping any game-specific options.
23:44:31:821 | RL |     INFO  | +0     | Main - Checking for a [Daphne Singe] section in O:\RocketLauncher\Settings\American Laser Games\Emulators.ini
23:44:31:825 | RL |     INFO  | +0     | Main - Found [Daphne Singe] in O:\RocketLauncher\Settings\American Laser Games\Emulators.ini
23:44:31:828 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Modules\Daphne Singe\Daphne Singe.ahk exists
23:44:31:834 | RL |     INFO  | +15    | Main - CRC Check - CRC matches, this is an official unedited module.
23:44:31:837 | RL |     INFO  | +0     | Main - crimepatrol will use module: O:\RocketLauncher\Modules\Daphne Singe\Daphne Singe.ahk
23:44:31:864 | RL |     INFO  | +32    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
23:44:31:870 | RL |     INFO  | +0     | CheckFile - Checking if O:\_Emulators\Daphne Singe\daphne.exe exists
23:44:31:873 | RL |     INFO  | +0     | Main - INI Keys read
23:44:31:877 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\7z.exe exists
23:44:31:880 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\Module Extensions\7z.dll exists
23:44:31:886 | RL |     INFO  | +0     | Main - "crimepatrol" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
23:44:31:889 | RL |     INFO  | +0     | CheckPaths - Started
23:44:31:891 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol.cfg
23:44:31:893 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\crimepatrol.cfg
23:44:31:896 | RL |     INFO  | +0     | CheckPaths - Found rom by matching name in subfolder: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\crimepatrol.cfg
23:44:31:899 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: crimepatrol
23:44:31:902 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol
23:44:31:905 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .cfg
23:44:31:908 | RL |     INFO  | +0     | CheckPaths - Ended
23:44:31:912 | RL |     INFO  | +15    | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
DetectHiddenWindows, ON
SetTitleMatchMode, 2
SendMode, Event
0 = 12
pluginPath = O:\RocketLauncher\Plugins
pluginName = HyperSpin
pluginExt = .plugin
contextOnExit = 1
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.0.1.2
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = O:\RocketLauncher\Data\Language\Localization.ini
primMonitor = 1
frontendPID =
frontendPath = O:\Hyperspin
frontendExe = HyperSpin.exe
frontendExt = exe
frontendName = HyperSpin
frontendDrive = O:
exitEmulatorKey = ~Esc
exitEmulatorKeyWait = 0
forceHoldKey = ~Esc
restoreFE = false
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath = O:\_Emulators\Daphne Singe\daphne.exe
emuPath = O:\_Emulators\Daphne Singe
emuName = Daphne Singe
emuExt = exe
romPath = O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol
romPathFromIni = O:\_Emulators\Daphne Singe\singe\Singe
romExtension = .cfg
romExtensionOrig = .cfg
romExtensions = cfg|singe
executable = daphne.exe
systemDbName = American Laser Games
systemName = American Laser Games
dbPath =
dbName = crimepatrol
dbExt =
romName = crimepatrol
romMapPath =
romMappingEnabled = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = false
romMatchExt = false
blockInputTime = 0
blockInputFile = O:\RocketLauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
logFile = O:\RocketLauncher\RocketLauncher.log
logLabel := ["    INFO"," WARNING","   ERROR","  DEBUG1","  DEBUG2"]
logLevel = 10
logShowDebugConsole = true
logIncludeModule = true
logIncludeFileProperties = false
logShowCommandWindow = false
logCommandWindow = true
rlDebugConsoleStdout = 7
sysLang = Italian_Standard
sysType = 64-bit
broadcastWindowTitle =
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1366
originalHeight = 768
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdAddDrive = true
servoStikEnabled = false
ledblinkyEnabled = false
ledblinkyFullPath =
ledblinkyProfilePath = O:\RocketLauncher\Profiles\LEDBlinky
ledblinkyRLProfile = O:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
fadeIn = false
fadeInDuration = 500
fadeInDelay = 0
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = false
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 0
fadeLyrInterpolation = 0
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeWidthBaseRes = 1920
fadeHeightBaseRes = 1080
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = imageandbar
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeBarNon7zProgressTime = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoManufacturer = text with label
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoTextMargin = 7
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey =
detectFadeErrorEnabled = true
fadeImgPath = O:\RocketLauncher\Media\Fade
RLDataPath = O:\RocketLauncher\Data
RLMediaPath = O:\RocketLauncher\Media
RLErrSoundPath = O:\RocketLauncher\Media\Sounds\Error
modulesPath = O:\RocketLauncher\Modules
moduleFullName = O:\RocketLauncher\Modules\Daphne Singe\Daphne Singe.ahk
moduleName = Daphne Singe
modulePath = O:\RocketLauncher\Modules\Daphne Singe
moduleExtension = ahk
moduleExtensionsPath = O:\RocketLauncher\Module Extensions
libPath = O:\RocketLauncher\Lib
7zEnabled = true
7zPath = O:\RocketLauncher\Module Extensions\7z.exe
7zDllPath = O:\RocketLauncher\Module Extensions\7z.dll
7zExtractPath = C:\Users\ste\AppData\Local\Temp\HS
7zExtractPathOrig =
7zAttachSystemName = false
7zDelTemp = true
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1920
mgHeightBaseRes = 1080
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = O:\RocketLauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes =
pauseLoadStateKeyCodes =
keymapperEnabled = false
keymapperAHKMethod = false
keymapper = joytokey
xpadderFullPath = O:\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = O:\RocketLauncher\Utility\JoyToKey\JoyToKey.exe
keymapperProfilePath = O:\RocketLauncher\Profiles\joytokey
keymapperFrontEndProfileName = RocketLauncherUI
keymapperFrontEndProfile = joytokey
joyIDsEnabled = false
joyIDsPreferredControllersGlobal =
joyIDsPreferredControllersSystem = use_global
joyIDsPreferredControllersOnExit =
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = O:\RocketLauncher\Profiles\joytokey\RocketLauncherUI
defaultProfile = O:\RocketLauncher\Profiles\joytokey\_Default
systemProfile = O:\RocketLauncher\Profiles\joytokey\American Laser Games
xPadderSystemProfile = O:\RocketLauncher\Profiles\joytokey\American Laser Games\_Default
emuProfile = O:\RocketLauncher\Profiles\joytokey\American Laser Games\Daphne Singe
romProfile = O:\RocketLauncher\Profiles\joytokey\American Laser Games\crimepatrol
RocketLauncherProfile = O:\RocketLauncher\Profiles\joytokey\RocketLauncher
blankProfile = O:\RocketLauncher\Profiles\joytokey\blank
ahkFEProfile = O:\RocketLauncher\Profiles\AHK\RocketLauncherUI
ahkDefaultProfile = O:\RocketLauncher\Profiles\AHK\_Default
ahkSystemProfile = O:\RocketLauncher\Profiles\AHK\American Laser Games
ahkEmuProfile = O:\RocketLauncher\Profiles\AHK\American Laser Games\Daphne Singe
ahkRomProfile = O:\RocketLauncher\Profiles\AHK\American Laser Games\crimepatrol
ahkRocketLauncherProfile = O:\RocketLauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
statisticsEnabled = true
pressDuration = -1
emuVolume = 1
dxwndIni = O:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = O:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
mon1O =
pacDrivedllFile = O:\RocketLauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = O:\RocketLauncher\Lib\User Fade Animations.ini
23:44:32:044 | RL |     INFO  | +125   | BuildScript - Loaded XHotkey Init.ahk scripts
23:44:32:048 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
23:44:32:050 | RL |  WARNING  | +16    | BuildScript - "O:\RocketLauncher\Lib\User Functions Init.ahk" not found
23:44:32:054 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
23:44:32:057 | RL |     INFO  | +0     | BuildScript - Validating module
23:44:32:061 | RL |     INFO  | +0     | BuildScript - Validation complete
23:44:32:064 | RL |     INFO  | +0     | BuildScript - Module:
MEmu = Daphne Singe
MEmuV =  v1.14
MURL = http://www.singeengine.com/cms/
MAuthor = djvj
MVersion = 2.0.6
MCRC = 60C75E1
iCRC = 777E5B50
MID = 635038268880264228
MSystem = "American Laser Games","WoW Action Max"
; Notes:
; Rom_Extension should be singe
; Your framefiles need to exist in the same dir as your Rom_Path, in each game's subfolder, and have a txt extension. The filename should match the name in your xml.
; If you are upgrading from the old daphne-singe-v1.0 to 1.14, don't forget to copy the old singe dir to the new emu folder, it doesn't come with the contents of that folder that you need.
; For this emu to work, paths need to be set in the singe files pointing to the movie files. The old method was done with manual file edits. The new method has the module do it for you automatically.
; NEW METHOD:
; Do nothing!
; OLD METHOD:
; American Laser Games
; For example,  If you rompath is C:Hyperspin\Games\American Laser Games\, the drugwars game would be found in C:Hyperspin\Games\American Laser Games\maddog\
; and the framefile would be in C:Hyperspin\Games\American Laser Games\maddog\maddog.txt
; To change the dir you want to run your games from:
; 1. Backup all your /daphne/singe/ROMNAME/ROMNAME.singe, cdrom-globals.singe, and service.singe files, most games all three in each romdir
; 2. Move all the folders in your /daphne/singe/ folder to the new location you want. You should have one folder for each game.
; 3. Open each ROMNAME.singe, cdrom-globals.singe, and service.singe in notepad and do a find/replace of all instances shown below. For example using an SMB share:
; Old
; ("singe/
; New:
; ("//SERVER/Hyperspin/Games/American Laser Games/
; If using a local drive, it would look something like this C:/Hyperspin/Games/American Laser Games/
; WoW Action Max
; Emu_Path should be something like this C:\HyperSpin\Emulators\WoW Action Max\daphne-singe\
; Rom_Path has to point to where all the m2v video files are kept
; Your framefiles need to exist in the same dir as your rompath and all have txt extensions. The filename should match the name in your xml.
; 1. Backup your /daphne/singe/Action Max/Emulator.singe file
; 2. Move all the files (except Emulator.singe) in your /daphne/singe/Action Max/ folder to the new location you want.
; 3. Open Emulator.singe in notepad and do a find/replace of all instances shown below. For example using an SMB share:
; Old
; "singe/Action Max/
; New:
; "//SERVER/Hyperspin/Games/WoW Action Max/
; If using a local drive, it would look something like this C:/Hyperspin/Games/WoW Action Max/
; There should be 18 instances that need replacing.
; 4. The only file that should be in your /daphne/singe/Action Max/ dir should be the edited Emulator.singe file (and your backup).
StartModule()
BezelGUI()
FadeInStart()
fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1)
globalParams := IniReadCheck(settingsFile,"settings","globalParams","",,1)
daphneWidth := IniReadCheck(settingsFile, "settings", "daphneWidth","1024",,1)
daphneHeight := IniReadCheck(settingsFile, "settings", "daphneHeight","768",,1)
singePathUpdate := IniReadCheck(settingsFile, "settings", "SingePathUpdate","true",,1)
forcePathUpdate := IniReadCheck(settingsFile, "settings", "ForcePathUpdate","false",,1)
params := IniReadCheck(settingsFile,romName,"params","",,1)
params := " " . globalParams . " " .  params
BezelStart()
; Emptying variables If they are not set
fullscreen := If fullscreen = "true" ? " -fullscreen_window" : "" ; fullscreen_window mode allows guncon and aimtraks to work
If bezelPath   ; this variable is only filled if bezel is enabled and a valid bezel image is found
{ params := params . " -ignore_aspect_ratio"
daphneWidth := " -x " . Round(bezelScreenWidth)  ;bezelScreenWidth variable is defined on the BezelStart function and it gives the desired width that your game screen should have while using this bezel
daphneHeight := " -y " . Round(bezelScreenHeight) ;idem above
} Else {
daphneWidth := " -x " . daphneWidth
daphneHeight := " -y " . daphneHeight
hideEmuObj := Object("DAPHNE ahk_class SDL_app",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
If singePathUpdate = true
SingePathUpdate()
HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait
; This allows us to send variables, that when empty, are not sent to the Run command
Run(executable . " singe vldp" . daphneWidth . daphneHeight . fullscreen . params . " -framefile """ . romPath . "\" . romName . ".txt"" -script """ . romPath . "\" . romName . ".singe""", emuPath)
WinWait("DAPHNE ahk_class SDL_app")
WinWaitActive("DAPHNE ahk_class SDL_app")
BezelDraw()
HideEmuEnd()
FadeInExit()
7zCleanUp()
FadeOutExit()
ExitModule()
SingePathUpdate(){
Global romPath,romName,updatedLines,forcePathUpdate,systemName,emuPath
Log("SingePathUpdate - Started")
FileFullPath := []
updatedLines := 0
singeData :=
singeCount :=
singeUpdateStrings := ["dofile(","spriteLoad","io.input","io.output","fontLoad","soundLoad"] ; look for these strings in the singe files
; Check if paths have been updated prior
romSingeFile := romPath . "\" . romName . ".singe"
FileRead, romSingeData, %romSingeFile%
StringReplace, rompathCommonSlash, romPath, \, /, all
If InStr(romSingeData, rompathCommonSlash)
If (forcePathUpdate = "false") {
Log("SingePathUpdate - """ . romSingeFile . """ contains the current Rom Path. Skipping the SingePathUpdate function because your files appear to have the correct paths already set. If you want to force a path update, please set the ForcePathUpdate variable in the Daphne Singe module options in RocketLauncherUI to true.")
Log("SingePathUpdate - Ended")
Return
If InStr(systemName, "Action") { ; WoW Action Max
emuSingeFile := emuPath . "\singe\ActionMax\Emulator.singe"
FileRead, emuSingeData, %emuSingeFile%
FileFullPath[1,1] := emuSingeFile
FileFullPath[1,2] := emuSingeData
FileFullPath[2,1] := romSingeFile
FileFullPath[2,2] := romSingeData
Log("SingePathUpdate - Added the " . romName . ".singe and Emulator.singe to be updated",4)
} Else { ; basically only American Laser Games
Loop, % romPath . "\*.singe"
{ FileRead, singeData, %A_LoopFileFullPath%
Loop % singeUpdateStrings.MaxIndex() { ; for each string in the array
If InStr(singeData, singeUpdateStrings[A_Index]) { ; check each singe file for the strings
singeCount++
FileFullPath[singeCount,1] := A_LoopFileFullPath ; building a table of each .singe file in the romPath and storing it in row 1
FileFullPath[singeCount,2] := singeData ; inserting the file data into row 2
Log("SingePathUpdate - Found a file that needs to have its paths updated: " . A_LoopFileFullPath,4)
Break ; go to next file
Log("SingePathUpdate - " . FileFullPath.MaxIndex() . " files will have their paths updated")
Loop, % FileFullPath.MaxIndex()
currentSingeIndex := A_Index
Log("SingePathUpdate - Now updating this singe file's paths: " . FileFullPath[currentSingeIndex,1],4)
updatedText :=
currentData := FileFullPath[currentSingeIndex,2]
Loop, Parse, currentData, `n, `r
currentLine := A_Index
oldSingeLine := A_LoopField
lineUpdated :=
Loop % singeUpdateStrings.MaxIndex() ; for each string in the array
If InStr(oldSingeLine, singeUpdateStrings[A_Index]) { ; check each singe file for the strings
updatedText .= (If currentLine = 1 ? "" : "`r`n") . UpdateLine(oldSingeLine, singeUpdateStrings[A_Index])
lineUpdated := 1
If !lineUpdated ; if line was not found above, just put the old line back
updatedText .= (If currentLine = 1 ? "" : "`r`n") . A_LoopField
Log("SingePathUpdate - Deleting file: " . FileFullPath[currentSingeIndex,1],4)
FileDelete, % FileFullPath[currentSingeIndex,1]
Log("SingePathUpdate - Recreating file: " . FileFullPath[currentSingeIndex,1],4)
FileAppend, %updatedText%, % FileFullPath[currentSingeIndex,1]
Log(updatedLines . " Singe paths updated by RocketLauncher.")
exitapp
Return
UpdateLine(oldLine, string) {
Global rompath,emuPath,systemName,updatedLines
StringReplace, emupathCommonSlash, emuPath, \, /, all
StringReplace, string2, string, ., \., all
regex = i)%string2%.*/\K(?:.(?!/))+$|%string2%.*\\\K(?:.(?!\\))+$
If RegExMatch(RegExReplace(oldLine,"\s*$",""), regex, matchedLine)
If (InStr(systemName, "Action") and InStr(matchedLine, "framework.singe"))
Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . emupathCommonSlash . "/singe/singe/" . matchedLine)
Else If (InStr(systemName, "Action") and InStr(matchedLine, "emulator.singe"))
Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . emupathCommonSlash . "/singe/ActionMax/" . matchedLine)
Else
Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . rompathCommonSlash . "/" . matchedLine)
updatedLines++
} Else
Line := oldLine
Log("UpdateLine - " . line,4)
Return Line
HaltEmu:
Send, {P}
Return
RestoreEmu:
Winrestore, AHK_class %EmulatorClass%
Send, {P}
Return
CloseProcess:
FadeOutStart()
BezelExit()
WinClose("DAPHNE ahk_class SDL_app")
;Process, Close, %executable% ; WoW Action Max module used this
Return
23:44:32:202 | RL |     INFO  | +140   | BuildScript - Loaded Multi-Player scripts
23:44:32:207 | RL |     INFO  | +16    | BuildScript - Loaded Statistics.ahk script
23:44:32:210 | RL |  WARNING  | +0     | BuildScript - "O:\RocketLauncher\Lib\User Functions.ahk" not found
23:44:32:214 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
23:44:32:219 | RL |     INFO  | +0     | Main - Module is built
23:44:32:222 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\AutoHotkey.dll exists
23:44:32:227 | RL |     INFO  | +0     | Main - Running module
23:44:32:231 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
23:44:32:428 | MD |     INFO  | +N/A   | Module initialized
23:44:32:432 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
23:44:32:458 | MD |     INFO  | +31    | StartModule - Started
23:44:32:461 | MD |     INFO  | +0     | StartModule - MEmu: Daphne Singe
MEmuV: v1.14
MURL: http://www.singeengine.com/cms/
MAuthor: djvj
MVersion: 2.0.6
MCRC: 60C75E1
iCRC: 777E5B50
MID:
MSystem: "American Laser Games","WoW Action Max"
23:44:32:467 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "American Laser Games"
23:44:32:491 | MD |     INFO  | +32    | PluginInit - Started
23:44:32:494 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
23:44:32:497 | MD |     INFO  | +0     | CheckFile - Checking if O:\Hyperspin\Databases\American Laser Games\American Laser Games.xml exists
23:44:32:499 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
23:44:32:523 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Found "Game Name" in the database!
23:44:32:526 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
23:44:32:529 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Crime Patrol"
23:44:32:531 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
23:44:32:554 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Cloneof
23:44:32:557 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
23:44:32:560 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "American Laser Games"
23:44:32:579 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Year
23:44:32:583 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Year" with a value: "1993"
23:44:32:587 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
23:44:32:591 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Gun"
23:44:32:614 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Rating
23:44:32:616 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "AAMA - Red (Life Like Violence Strong)"
23:44:32:620 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
GameInfo Label: Genre | GameInfo Value:
GameInfo Label: Manufacturer | GameInfo Value:
GameInfo Label: Name | GameInfo Value:
GameInfo Label: Rating | GameInfo Value:
GameInfo Label: Year | GameInfo Value:
23:44:32:647 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Ended
23:44:32:650 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
23:44:32:654 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: O:\Hyperspin\Media\American Laser Games\Images\Wheel\crimepatrol.png
23:44:32:678 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a System Logo: O:\Hyperspin\Media\Main Menu\Images\Wheel\American Laser Games.png
23:44:32:682 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
Asset Label: Game Logo | Asset Path1:  O:\Hyperspin\Media\American Laser Games\Images\Wheel\crimepatrol.png | Asset Extension1:  png | Asset Type1:  game
Asset Label: System Logo | Asset Path1:  O:\Hyperspin\Media\Main Menu\Images\Wheel\American Laser Games.png | Asset Extension1:  png | Asset Type1:  system
23:44:32:687 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
23:44:32:706 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
23:44:32:710 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: O:\Hyperspin\Media\American Laser Games\Images\Artwork1\crimepatrol.png
23:44:32:714 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: O:\Hyperspin\Media\American Laser Games\Images\Artwork2\crimepatrol.png
23:44:32:738 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Cartridge: O:\Hyperspin\Media\American Laser Games\Images\Artwork3\crimepatrol.png
23:44:32:741 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: O:\Hyperspin\Media\American Laser Games\Images\Artwork4\crimepatrol.png
23:44:32:744 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: O:\Hyperspin\Media\American Laser Games\Images\Letters
23:44:32:834 | MD |   DEBUG1  | +94    | BuildAssetsTable - Searching for a Other: O:\Hyperspin\Media\American Laser Games\Images\Other
23:44:32:843 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
Asset Label: Letters | Asset Path1:  O:\Hyperspin\Media\American Laser Games\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
Asset Label: Letters | Asset Path2:  O:\Hyperspin\Media\American Laser Games\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
Asset Label: Letters | Asset Path3:  O:\Hyperspin\Media\American Laser Games\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
Asset Label: Letters | Asset Path4:  O:\Hyperspin\Media\American Laser Games\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
Asset Label: Letters | Asset Path5:  O:\Hyperspin\Media\American Laser Games\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
Asset Label: Letters | Asset Path6:  O:\Hyperspin\Media\American Laser Games\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
Asset Label: Letters | Asset Path7:  O:\Hyperspin\Media\American Laser Games\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
Asset Label: Letters | Asset Path8:  O:\Hyperspin\Media\American Laser Games\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
Asset Label: Letters | Asset Path9:  O:\Hyperspin\Media\American Laser Games\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
Asset Label: Letters | Asset Path10:  O:\Hyperspin\Media\American Laser Games\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
Asset Label: Letters | Asset Path11:  O:\Hyperspin\Media\American Laser Games\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
Asset Label: Letters | Asset Path12:  O:\Hyperspin\Media\American Laser Games\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
Asset Label: Letters | Asset Path13:  O:\Hyperspin\Media\American Laser Games\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
Asset Label: Letters | Asset Path14:  O:\Hyperspin\Media\American Laser Games\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
Asset Label: Letters | Asset Path15:  O:\Hyperspin\Media\American Laser Games\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
Asset Label: Letters | Asset Path16:  O:\Hyperspin\Media\American Laser Games\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
Asset Label: Letters | Asset Path17:  O:\Hyperspin\Media\American Laser Games\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
Asset Label: Letters | Asset Path18:  O:\Hyperspin\Media\American Laser Games\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
Asset Label: Letters | Asset Path19:  O:\Hyperspin\Media\American Laser Games\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
Asset Label: Letters | Asset Path20:  O:\Hyperspin\Media\American Laser Games\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
Asset Label: Letters | Asset Path21:  O:\Hyperspin\Media\American Laser Games\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
Asset Label: Letters | Asset Path22:  O:\Hyperspin\Media\American Laser Games\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
Asset Label: Letters | Asset Path23:  O:\Hyperspin\Media\American Laser Games\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
Asset Label: Letters | Asset Path24:  O:\Hyperspin\Media\American Laser Games\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
Asset Label: Letters | Asset Path25:  O:\Hyperspin\Media\American Laser Games\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
Asset Label: Letters | Asset Path26:  O:\Hyperspin\Media\American Laser Games\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
Asset Label: Letters | Asset Path27:  O:\Hyperspin\Media\American Laser Games\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
Asset Label: Letters | Asset Path28:  O:\Hyperspin\Media\American Laser Games\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
Asset Label: Letters | Asset Path29:  O:\Hyperspin\Media\American Laser Games\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
Asset Label: Letters | Asset Path30:  O:\Hyperspin\Media\American Laser Games\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
Asset Label: Letters | Asset Path31:  O:\Hyperspin\Media\American Laser Games\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
Asset Label: Letters | Asset Path32:  O:\Hyperspin\Media\American Laser Games\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
Asset Label: Letters | Asset Path33:  O:\Hyperspin\Media\American Laser Games\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
Asset Label: Letters | Asset Path34:  O:\Hyperspin\Media\American Laser Games\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
Asset Label: Letters | Asset Path35:  O:\Hyperspin\Media\American Laser Games\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
Asset Label: Letters | Asset Path36:  O:\Hyperspin\Media\American Laser Games\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
Asset Label: Letters | Asset Path37:  O:\Hyperspin\Media\American Laser Games\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
Asset Label: Letters | Asset Path38:  O:\Hyperspin\Media\American Laser Games\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
Asset Label: Letters | Asset Path39:  O:\Hyperspin\Media\American Laser Games\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
Asset Label: Other | Asset Path1:  O:\Hyperspin\Media\American Laser Games\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
23:44:32:894 | MD |   DEBUG1  | +62    | BuildAssetsTable - Ended
23:44:32:897 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
23:44:32:901 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: O:\Hyperspin\Media\American Laser Games\Video\crimepatrol.*
23:44:32:904 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Video: O:\Hyperspin\Media\Main Menu\Video\American Laser Games.*
23:44:32:928 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
Asset Label: Game Video | Asset Path1:  O:\Hyperspin\Media\American Laser Games\Video\crimepatrol.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
Asset Label: System Video | Asset Path1:  O:\Hyperspin\Media\Main Menu\Video\American Laser Games.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
23:44:32:933 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
23:44:32:936 | MD |     INFO  | +0     | PluginInit - Ended
23:44:32:956 | MD |   DEBUG1  | +32    | StartModule - Setting romName to the dbName sent to RocketLauncher: crimepatrol
23:44:32:960 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
23:44:32:967 | MD |     INFO  | +0     | StartModule - Ended
23:44:32:990 | MD |     INFO  | +31    | Module Setting - [settings] - Fullscreen: true
23:44:32:994 | MD |     INFO  | +0     | Module Setting - [settings] - globalParams:
23:44:32:998 | MD |     INFO  | +0     | Module Setting - [settings] - daphneWidth: 1024
23:44:32:022 | MD |     INFO  | +31    | Module Setting - [settings] - daphneHeight: 768
23:44:33:025 | MD |     INFO  | +0     | Module Setting - [settings] - SingePathUpdate: true
23:44:33:031 | MD |     INFO  | +0     | Module Setting - [settings] - ForcePathUpdate: false
23:44:33:053 | MD |     INFO  | +31    | Module Setting - [crimepatrol] - params:
23:44:33:056 | MD |     INFO  | +0     | 7z - Started, received O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\crimepatrol.cfg. If rom is an archive, it will extract to C:\Users\ste\AppData\Local\Temp\HS
23:44:33:060 | MD |     INFO  | +0     | 7z - This rom type does not need 7z: ".cfg"
23:44:33:079 | MD |   DEBUG1  | +31    | 7z - Starting non-7z FadeIn animation.
23:44:33:082 | MD |   DEBUG1  | +0     | 7z - romPath changed from "O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol" to "O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol"
23:44:33:086 | MD |   DEBUG1  | +0     | 7z - romName changed from "crimepatrol" to "crimepatrol"
23:44:33:090 | MD |   DEBUG1  | +0     | 7z - romExtension changed from ".cfg" to ".cfg"
23:44:33:093 | MD |     INFO  | +0     | 7z - Ended
23:44:33:114 | MD |     INFO  | +32    | SingePathUpdate - Started
23:44:33:121 | MD |   DEBUG1  | +0     | SingePathUpdate - Found a file that needs to have its paths updated: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-crimepatrol.singe
23:44:33:146 | MD |   DEBUG1  | +31    | SingePathUpdate - Found a file that needs to have its paths updated: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-globals.singe
23:44:33:306 | MD |   DEBUG1  | +156   | SingePathUpdate - Found a file that needs to have its paths updated: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\hscore.singe
23:44:33:334 | MD |   DEBUG1  | +31    | SingePathUpdate - Found a file that needs to have its paths updated: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\service.singe
23:44:33:339 | MD |     INFO  | +0     | SingePathUpdate - 4 files will have their paths updated
23:44:33:343 | MD |   DEBUG1  | +0     | SingePathUpdate - Now updating this singe file's paths: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-crimepatrol.singe
23:44:33:369 | MD |   DEBUG1  | +31    | UpdateLine - dofile("singe/crimepatrol/cdrom-globals.singe")
23:44:33:373 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/cdrom-setuplevel.singe")
23:44:33:394 | MD |   DEBUG1  | +31    | UpdateLine - dofile("singe/crimepatrol/hscore.singe")
23:44:33:398 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/manage.singe")
23:44:33:402 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/service.singe")
23:44:33:425 | MD |   DEBUG1  | +32    | UpdateLine - dofile("singe/crimepatrol/toolbox.singe")
23:44:33:428 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-airdrugs.singe")
23:44:33:432 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-airports.singe")
23:44:33:436 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-bankrobbery.singe")
23:44:33:461 | MD |   DEBUG1  | +31    | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-cars.singe")
23:44:33:465 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-druglab1.singe")
23:44:33:468 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-druglab2.singe")
23:44:33:493 | MD |   DEBUG1  | +31    | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-gang.singe")
23:44:33:497 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-hangar.singe")
23:44:33:521 | MD |   DEBUG1  | +31    | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-nuclearplant.singe")
23:44:33:524 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-store.singe")
23:44:33:530 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-stripbar.singe")
23:44:33:551 | MD |   DEBUG1  | +31    | UpdateLine - dofile("singe/crimepatrol/hitbox-cdrom-warehouse.singe")
23:44:33:554 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitmap-cdrom-practice.singe")
23:44:33:560 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitmap-cdrom-delta.singe")
23:44:33:580 | MD |   DEBUG1  | +32    | UpdateLine - dofile("singe/crimepatrol/hitmap-cdrom-rookie.singe")
23:44:33:583 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitmap-cdrom-swat.singe")
23:44:33:587 | MD |   DEBUG1  | +0     | UpdateLine - dofile("singe/crimepatrol/hitmap-cdrom-undercover.singe")
23:44:33:708 | MD |   DEBUG1  | +124   | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaira.png")
23:44:33:712 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshairb.png")
23:44:33:716 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshairc.png")
23:44:33:741 | MD |   DEBUG1  | +32    | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaird.png")
23:44:33:744 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaire.png")
23:44:33:777 | MD |   DEBUG1  | +31    | SingePathUpdate - Deleting file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-crimepatrol.singe
23:44:33:804 | MD |   DEBUG1  | +31    | SingePathUpdate - Recreating file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-crimepatrol.singe
23:44:33:832 | MD |   DEBUG1  | +31    | SingePathUpdate - Now updating this singe file's paths: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-globals.singe
23:44:33:841 | MD |   DEBUG1  | +0     | UpdateLine - fontDebug6pt = fontLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/m39.ttf", 6)
23:44:33:862 | MD |   DEBUG1  | +31    | UpdateLine - fontDebug8pt = fontLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/m39.ttf", 8)
23:44:33:867 | MD |   DEBUG1  | +0     | UpdateLine - fontCA14pt   = fontLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/addlg___.ttf", 14)
23:44:33:871 | MD |   DEBUG1  | +0     | UpdateLine - fontCA16pt   = fontLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/addlg___.ttf", 16)
23:44:33:892 | MD |   DEBUG1  | +32    | UpdateLine - fontCA24pt   = fontLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/addlg___.ttf", 24)
23:44:33:896 | MD |   DEBUG1  | +0     | UpdateLine - sprArrow    = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/pistol.png")
23:44:33:900 | MD |   DEBUG1  | +0     | UpdateLine - sprBadge    = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/badge3.png")
23:44:33:902 | MD |   DEBUG1  | +0     | UpdateLine - sprBadgeSmall =  spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/badge4.png")
23:44:33:921 | MD |   DEBUG1  | +31    | UpdateLine - sprRev      = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaira.png")
23:44:33:925 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[1] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets00.png")
23:44:33:927 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[2] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets01.png")
23:44:33:931 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[3] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets02.png")
23:44:33:933 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[4] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets03.png")
23:44:33:936 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[5] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets04.png")
23:44:33:958 | MD |   DEBUG1  | +31    | UpdateLine - sprBullet[6] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets05.png")
23:44:33:961 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[7] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets06.png")
23:44:33:964 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[8] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets07.png")
23:44:33:967 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[9] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets08.png")
23:44:33:987 | MD |   DEBUG1  | +31    | UpdateLine - sprBullet[10] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets09.png")
23:44:33:990 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[11] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets10.png")
23:44:33:992 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[12] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets11.png")
23:44:33:994 | MD |   DEBUG1  | +0     | UpdateLine - sprBullet[13] = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/bullets12.png")
23:44:33:997 | MD |   DEBUG1  | +0     | UpdateLine - sndCoin      = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/coin.wav")
23:44:33:019 | MD |   DEBUG1  | +31    | UpdateLine - sndCredit    = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/gunhit.wav")
23:44:34:022 | MD |   DEBUG1  | +0     | UpdateLine - sndGunshot   = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/gunshot.wav")
23:44:34:024 | MD |   DEBUG1  | +0     | UpdateLine - sndEmpty     = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/gunempty.wav")
23:44:34:027 | MD |   DEBUG1  | +0     | UpdateLine - sndReload    = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/gunreload.wav")
23:44:34:029 | MD |   DEBUG1  | +0     | UpdateLine - sndBuzz      = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/buzzer.wav")
23:44:34:049 | MD |   DEBUG1  | +32    | UpdateLine - sndBeep      = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/censoredbeep.wav")
23:44:34:052 | MD |   DEBUG1  | +0     | UpdateLine - sndBreak      = soundLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/break.wav")
23:44:34:055 | MD |   DEBUG1  | +0     | SingePathUpdate - Deleting file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-globals.singe
23:44:34:058 | MD |   DEBUG1  | +0     | SingePathUpdate - Recreating file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\cdrom-globals.singe
23:44:34:080 | MD |   DEBUG1  | +31    | SingePathUpdate - Now updating this singe file's paths: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\hscore.singe
23:44:34:087 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaird.png")
23:44:34:089 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaira.png")
23:44:34:092 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshairb.png")
23:44:34:115 | MD |   DEBUG1  | +31    | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshairc.png")
23:44:34:118 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaird.png")
23:44:34:121 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaire.png")
23:44:34:123 | MD |   DEBUG1  | +0     | SingePathUpdate - Deleting file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\hscore.singe
23:44:34:144 | MD |   DEBUG1  | +31    | SingePathUpdate - Recreating file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\hscore.singe
23:44:34:149 | MD |   DEBUG1  | +0     | SingePathUpdate - Now updating this singe file's paths: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\service.singe
23:44:34:153 | MD |   DEBUG1  | +0     | UpdateLine -  local h1 = io.input("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crimepatrol.cfg")
23:44:34:177 | MD |   DEBUG1  | +31    | UpdateLine -  local h1 = io.output("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crimepatrol.cfg")
23:44:34:183 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaira.png")
23:44:34:205 | MD |   DEBUG1  | +32    | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshairb.png")
23:44:34:211 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshairc.png")
23:44:34:215 | MD |   DEBUG1  | +0     | UpdateLine -  sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaird.png")
23:44:34:233 | MD |   DEBUG1  | +31    | UpdateLine -  --sprCursor  = spriteLoad("O:/_Emulators/Daphne Singe/singe/Singe/crimepatrol/crosshaire.png")
23:44:34:237 | MD |   DEBUG1  | +0     | SingePathUpdate - Deleting file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\service.singe
23:44:34:241 | MD |   DEBUG1  | +0     | SingePathUpdate - Recreating file: O:\_Emulators\Daphne Singe\singe\Singe\crimepatrol\service.singe
23:44:34:246 | MD |     INFO  | +0     | 48 Singe paths updated by RocketLauncher.
23:44:34:270 | MD |     INFO  | +31    | SingePathUpdate - Ended
23:44:34:347 | RL |     INFO  | +2122  | Main - Module ended, exiting RocketLauncher normally
23:44:34:350 | RL |     INFO  | +0     | ExitScript - Started
23:44:34:410 | RL |     INFO  | +62    | SystemCursor - Restoring mouse cursor
23:44:34:435 | RL |     INFO  | +16    | ExitScript - Ended
Somepne can help me please??
Thanks
Did you resolve this issue?
Looks like the extensions you are using are .cfg and .singe??  If they are Daphne Singe games, you should only have singe as your extension.
Also, in your module settings, turn off SingePathUpdate and ForcePathUpdate.
Test and let me know.
Thanks,
Ron
Sweet!  Glad it works.
Yes, you can easliy add it.  I put mine in my Daphne wheel since it doesn't use a light gun.  Only the light gun games are in my ALG wheel.
Open up your .../HyperSpin/Databases/American Laser Games/American Laser Games.xml file.
Somewhere in there, between a game close and game open tag:
</game>
<game>
Paste this text in there:
	<game name="timetraveler" index="true" image="w">
		<description>Time Traveler</description>
		<cloneof></cloneof>
		<crc></crc>
		<manufacturer>American Laser Games</manufacturer>
		<year>1991</year>
		<genre>Action</genre>
		<rating>AAMA - Yellow (Animated Violence Mild)</rating>
		<enabled>Yes</enabled>
	</game>
Thanks,
Ron
One more question.
Why for example Time Traveller is not in the official list??
I can add it??
Thanks again
Right.  Uses mirrors to produce the 3D effect.
When ripping the game from the DVD you can choose 2D or 3D anagliphic.  ;)
Thanks,
Ron
Time Traveller is one of those Holographic games right?
Now American Laser Game works good, thanks again.
The WoW Action Max is not working...
It start, it ask me (the first time) to parse the file, it parse the file, after green screen and the program stop working.
Any idea??
Thanks
An update.
I update the Daphne xml (with the one in the Hyperlist) and there are 20 games instead 17 (in the xml download automatically from the HyperSync).
Why are different??
Anyway one of the 3 new games is Ninja Hayate.When I try to run this game there is an error Bad Command Line.
Now I'm very confused.
But Ninja Hayate is Daphne or Daphne Singe??
Help me please
An update.
Why are different??
Help me please
Ninja Hayate and Time Gal are Daphne-Singe. That's why in your other topic I gave you the direct links to Ron's Daphne & Daphne-Singe tutorials for you to read through.
Ok but why in the HyperList official web page the Daphne has also some Singe games??
And someone can help with the green screen??
Thanks again
I had answered that in your other thread too
For the XML he was saying that those three games are run using the Daphne-Singe emulator, but it makes more sense to have them in the normal Daphne Hyperspin wheel & database with the other laserdisc games. Don't worry about that yet. First read the tutorials, get it working right, figure that part out later once you understand it a bit better.
Since they are Laserdisc it makes sense for them to be in the Daphne wheel with all the other Laserdisc games. So that's why they are in the Daphne database.
Not sure about the green screen.
I have my ALG wheel with only gun games.  ;)
I know it doesn't fit so well.  Some of the games that do not use a gun are still made by American Laser Games.  That said, the Ninja Hayate and Time Gal are not ALG games, even though they are laser disk games.  I think they are better suited into the Daphne wheel.  Along with Time Traveler.  ;)
I really need to change my wheel name for ALG anyway.  Maybe "Laser Disk Gun Games"...  lol  :)
My Daphne I already changed to LaserDisk.  I don't like the fact that Daphne and MAME are named based on the emulator name.  ;)
Just my two cents.
Thanks,
Ron
Hard to help without any logs, my friend.  ;)
You might make sure you have SingePathUpdate and ForcePathUpdate set to false in your Module settings for this system as well.
If that doesn't fix it, post your .../Daphne-Singe/Daphne_log.txt file so we can see what's going on. ;)
Thanks,
Ron
Thanks again
LOL.  Glad it's all sorted now.
Thanks,
Ron
PS: No clue on that emu from me.  ;)
Oh there is a log of Daphne?? I did not know
I found the problem ;)
Thank you
P.S. Any idea for http://www.hyperspin-fe.com/topic/10609-philips-vg-5000/
  • 2 months later...
Thanks,
Ron
Hi Ron I'm hoping you can help me,
I am trying to fix my Aimtraks in Daphne Singe. They work but are hyper movement sensitive and move WAY to fast. I was told to put the emu in full window from screened. Here is my script....
cd data
cls
@daphne.exe singe vldp -x 800 -y 600 -fullscreen -noserversend -framefile singe/drugwars/frame-drugwars-cdrom.txt -script singe/drugwars/cdrom-drugwars.singe
Is that not full windowed already? Any ideas?
