zinc database wanted
snstay
Im wondering if there is a zinc database with the rom names instead of the numbers. The rom set i have has the names of the roms and not the numbers.
Thanks alot
I don't think there is one. There is a valid reason why, if I remember correctly the zinc emulator needs the roms to be names with the numbers. I think that is why many folks just don't bother with the zinc emulator and just run the games through MAME, since they are in that database and play fine in Mame.
check my folder in the FTP
this was true at some point,  but the Rocketlauncher Module will remap the number system to the rom names.  if you are using Hyperlaunch 2  you might need the number system XML  I'm not sure if  the HL2 Zinc module supports rom names.
