How to map castle crashers to use 2 players ?
MontyQ
the game supports upto 4 players on 360 controllers but only one via keyboard
how can I map play1 and play2 to my 2 player cabinet ?
I tried making keymapper profile but that cant work do to player2 keys are the same as one and both well move the same guy on screen ect.
tried xpaddr that's a no go...any one with a simple solution that can lend a hand?
thanx n cheers
thanks for the links from what I gather it lets you choose what keys do what thing is in castlecrashers there is only support for 1 player via keyboard so if I set player 2 I need to say the same settings as player one and doing that means player 2 controls player on and plaey one does nothing :(
lol take it no one worked this out yet? I still been trying and my update is no luck at all so far. Don't think its possible or if it is it aint simple
  • 1 year later...
  • 5 months later...
If anyone else stumbles across this, I was able to use the x360kb method to get this working with the arcade control panel. It plays very well on an arcade, but keep in mind that you'll need 7-8 buttons..you can get away with 7, but 8 will let you map the last button (duplicate shoulder button in Castle Crashers). I'm posting my config of the x360kb.ini below, but you'll need to download the files that I've attached to this post and edit the config to match the mappings of your control panel. Everything you need is included, along with an application to see if everything works correctly. The files go in the root of the Castle Crashers folder. Enjoy!
[Options]
UseInitBeep=1
Log=0
BackgroundMode=1
PadCount=4
[PAD1]
D-Pad Up=Up
D-Pad Down=Down
D-Pad Left=Left
D-Pad Right=Right
A=Right Bracket
B=Num6
X=Num9
Y=9
Left Shoulder=Z
Left Trigger=V
Right Shoulder=X
Right Trigger=C
Back=5
Start=1
[PAD2]
D-Pad Up=P
D-Pad Down=K
D-Pad Left=J
D-Pad Right=L
A=Num7
B=T
X=O
Y=Left Bracket
Left Shoulder=Num1
Left Trigger=Num4
Right Shoulder=Comma
Right Trigger=Num3
Back=7
Start=3
[PAD3]
D-Pad Up=R
D-Pad Down=F
D-Pad Left=Home
D-Pad Right=G
A=Insert
B=End
X=Num0
Y=Pause
Left Shoulder=I
Left Trigger=Backslash
Right Shoulder=Num2
Right Trigger=Period
Back=6
Start=2
[PAD4]
D-Pad Up=Y
D-Pad Down=N
D-Pad Left=Forwardslash
D-Pad Right=U
A=B
B=H
X=M
Y=E
Left Shoulder=Num5
Left Trigger=0
Right Shoulder=Num8
Right Trigger=Minus
Back=8
Start=4
