cowbells Posted September 29, 2015 Posted September 29, 2015 Honestly, I'm not sure. This isn't the method I use. Instead, I setup everything within Rocket Launcher under Alternate Emulators in the system wheel. Then I set up each game in the Alternate list on the game list as well (at work, so I don't remember exactly what these tabs are called, but it's all pretty straight forward.) I took a break from this 'cause I'm super busy this week, but I'll be back on it this weekend. Hopefully I'll have the list done soon.
mccorkled Posted September 30, 2015 Posted September 30, 2015 On 9/29/2015 at 11:30 PM, cowbells said: Honestly, I'm not sure. This isn't the method I use. Instead, I setup everything within Rocket Launcher under Alternate Emulators in the system wheel. Then I set up each game in the Alternate list on the game list as well (at work, so I don't remember exactly what these tabs are called, but it's all pretty straight forward.) I took a break from this 'cause I'm super busy this week, but I'll be back on it this weekend. Hopefully I'll have the list done soon. This is how someone helped me set up my Sega CD games. Any chance you will make a write up and upload the necessary files? I would like to cross Sega Saturn off my list. Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
JoeC3109 Posted September 30, 2015 Posted September 30, 2015 I should have clarified initially when I posted that list: it's the alternate emulators I use for Saturn. Basically it was just a reference for people who needed to see which version of the emu you would need for certain games.
cowbells Posted September 30, 2015 Posted September 30, 2015 On 9/30/2015 at 1:59 AM, mccorkled said: This is how someone helped me set up my Sega CD games. Any chance you will make a write up and upload the necessary files? I would like to cross Sega Saturn off my list. Yes indeed! My first pass through I got almost 400 games working with a single set up of SSF. When I first started, tons of games were screwy in some way. I found that switching to version 0.12 Beta R3 (instead of the most recent R4) was much more compatible. It could still be that R4 is better with the majority of the list, but at least with games in the A's I was having much better luck with R3, so I stuck with that for the rest. I started working on launching games that I can find compatibility info on (thanks JoeC!). I'm also using these lists: http://www.segasaturn.org/ So far, Astal is the only one I've had problems with. Giga posted his SSF ini for me to try out (thanks Giga!). For now, I've skipped over it, but I'll come back to it. I'm going to write up a compatibility guide with some tips on how to get some problematic games working. For example, games with wavs and mp3s return an error in Rocket Launcher, but you can easily fix them. I'll cover that too. I'd like to then go through N64, Sega CD and the PSX games that I care about. I'm still using Kega Fusion for Genesis and CD. I couldn't immediately get Retroarch working for CD and Genesis ended up having insanely messed up controls for me, so I just reverted back. If it ain't broke... Btw, if anyone has a list of Sega CD games that need or don't need Perfect Sync, that'd be awesome! I'm getting all of this ready to finally put my HS in a cabinet, so I don't want any errors. I can live with tweaking on the fly on my PC, but not if I'm going to put it in front of people. I want everything to work as much as possible. When all of that is done, I'll continue making wheels
gigapig Posted September 30, 2015 Posted September 30, 2015 Cowbells, when you do move on to N64, a lot of that work was done by Noshgar. I have been able to find the original thread and found some of the files in my ftp as his folder is missing. The games.ini is below and also in my ftp. N64 Games ini by Nosh.zipFetching info... http://www.hyperspin-fe.com/topic/4380-the-wonderful-world-of-n64-emulation/
mccorkled Posted October 1, 2015 Posted October 1, 2015 On 9/30/2015 at 7:03 PM, cowbells said: I'd like to then go through N64, Sega CD and the PSX games that I care about. Off topic, but I use Project64 for N64 with no issues. Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
cowbells Posted October 4, 2015 Posted October 4, 2015 On 10/1/2015 at 5:37 PM, mccorkled said: Off topic, but I use Project64 for N64 with no issues. Thank you. I'm currently using Retroarch as my main, but also have a lot of experience with PJ64. Also, my assumption is you just haven't loaded the problematic games. Off the top of my head, I remember the following games having major issues: Gauntlet Legends Goemon's Great Adventure Hey You, Pikachu! Mario Tennis I'm sure there are many more and I know several other games have minor issues. The goal is to clear up any issues for every game on the list as much as possible, using the least number of emulator set ups as possible. Hey You, Pikachu! for example, will probably not work on an emulator any time soon because it requires microphone support. I'm assuming that's quite a bit of work for a pretty much garbage game haha. If you want to try those games and report back that'd be great!
mccorkled Posted October 4, 2015 Posted October 4, 2015 On 10/4/2015 at 6:52 PM, cowbells said: Thank you. I'm currently using Retroarch as my main, but also have a lot of experience with PJ64. Also, my assumption is you just haven't loaded the problematic games. Off the top of my head, I remember the following games having major issues: Gauntlet Legends Goemon's Great Adventure Hey You, Pikachu! Mario Tennis I'm sure there are many more and I know several other games have minor issues. The goal is to clear up any issues for every game on the list as much as possible, using the least number of emulator set ups as possible. Hey You, Pikachu! for example, will probably not work on an emulator any time soon because it requires microphone support. I'm assuming that's quite a bit of work for a pretty much garbage game haha. If you want to try those games and report back that'd be great! Just tested them. The only one that didn't work was Her You, Pikachu! I am on Project64 2.2.0.3 Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
cowbells Posted October 6, 2015 Posted October 6, 2015 How bout that? Good to know! Thanks for checking! Edit: I see that my PJ64 is now out of date. Looks like I'm still on 2.1.0.1. Whelp, that explains it!
mccorkled Posted October 11, 2015 Posted October 11, 2015 Anyone still working on this? Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
mccorkled Posted December 7, 2015 Posted December 7, 2015 On 8/6/2015 at 10:15 AM, JoeC3109 said: [NBA Jam Tournament Edition (USA)] Emulator=0.10 Beta R1 System=Sega Saturn [Tunnel B1 (USA)] Emulator=0.10 Prototype System=Sega Saturn [3D Lemmings (Europe)] Emulator=0.10 Beta R1 System=Sega Saturn [A+M+O+K (USA)] Emulator=0.10 Beta R1 System=Sega Saturn [Clockwork Knight 2 (USA)] Emulator=0.10 Prototype System=Sega Saturn [Corpse Killer - Graveyard Edition (USA) (Disc 1)] Emulator=0.10 Beta R1 System=Sega Saturn [Corpse Killer - Graveyard Edition (USA) (Disc 2)] Emulator=0.10 Beta R1 System=Sega Saturn [Croc - Legend of the Gobbos (USA)] Emulator=0.10 Alpha R1 System=Sega Saturn [Cyberia (USA)] Emulator=0.10 Beta R1 System=Sega Saturn [Hexen - Beyond Heretic (USA)] Emulator=0.10 Beta R1 System=Sega Saturn [NHL 98 (USA)] Emulator=0.10 Beta R1 System=Sega Saturn [PGA Tour 97 (USA)] Emulator=0.10 Alpha System=Sega Saturn [Quarterback Attack with Mike Ditka (USA)] Emulator=0.10 Beta R1 System=Sega Saturn [Need for Speed, The (USA)] Emulator=0.10 Alpha System=Sega Saturn [Thunderstrike 2 (USA)] Emulator=0.10 Alpha System=Sega Saturn [Mr. Bones (USA) (Disc 1)] Emulator=0.10 Prototype System=Sega Saturn [Mr. Bones (USA) (Disc 2)] Emulator=0.10 Prototype System=Sega Saturn [Scorcher (USA)] Emulator=0.10 Prototype System=Sega Saturn [Slam 'N Jam '96 featuring Magic & Kareem (USA)] Emulator=0.10 Prototype System=Sega Saturn [Street Racer (Europe)] Emulator=0.10 Prototype System=Sega Saturn [NBA Action (USA)] Emulator=0.10 Prototype System=Sega Saturn [Bottom of the 9th (USA)] Emulator=0.10 Prototype System=Sega Saturn [Astal (USA)] Emulator=0.12 Beta System=Sega Saturn [Rayman (USA)] Emulator=0.09 Beta R3 System=Sega Saturn [Grand Slam (USA)] Emulator=0.10 Prototype System=Sega Saturn [Shining Force III - Scenario 2 (Japan) (Translated En)] Emulator=0.10 Prototype System=Sega Saturn [Virtua Fighter Kids (USA)] Emulator=SSF Beta R3, version 2 System=Sega Saturn [Fighters Megamix (USA)] Emulator=SSF Beta R3, version 2 System=Sega Saturn [Earthworm Jim 2 (USA)] Emulator=0.10 Beta R1 System=Sega Saturn [Black Matrix (Japan)] Emulator=0.10 Beta R1 System=Sega Saturn [Dragon Force II (Japan) (Translated En)] Emulator=0.11 Alpha R5'' System=Sega Saturn SSF Beta 3 version 2 is just another 0.12 Beta R3 Can you please make a quick writeup on how to use this? Thanks Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
