Krayzed007 Posted August 10, 2015 Posted August 10, 2015 I'm toying with the idea of updating my Hyperspin v1.3.3 and HyperLaunch up to Hyperspin 1.4 and Rocketlauncher. I have yet to find a walkthrough anywhere. maybe i'm blind/stupid/whatever. I setup from scratch using Austins videos, since he's been afk for a bit due to computer issues. Any suggestions from the sweet sweet Hyperspin neighborhood?
Krayzed007 Posted August 10, 2015 Author Posted August 10, 2015 I'm pretty sure my best bet is to upgrade Hyperspin to 1.4 first, then use the transition tool to switch to RocketLauncher. My hiccup is my lack of understanding on updating Hyperspin....
ghutch92 Posted August 10, 2015 Posted August 10, 2015 Going 1.3.3 to 1.4 without rocketlauncher is a simple replace and the changing of the HyperLaunch_Path setting to be the full path to either hyperlaunch or rocketlauncher (i.e. C:\HyperSpin\HyperLaunch\HyperLaunch.exe) in the HyperSpin\Settings\Settings.ini Update HyperSpin to 1.4 before updating rocketlauncher. For a start from scratch guide using RocketLauncher for both 1.3 and 1.4 check out my how to install guide in my signature. If you are currently using RocketLauncher and you want to update to Rocketlauncher and you don't want to lose your HyperLaunch settings then you should use the transition tool (after updating HyperSpin to 1.4). How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
iNTiGOD Posted August 10, 2015 Posted August 10, 2015 You are correct. Being a platinum member you can access the 1.4 beta. Upgrade to 1.4 (very simple to overwrite a couple files), then upgrade to rocketlauncher using the provided instructions. I found running hyperspin 1.3 with the rocketlauncher transition tool messed my system ini files and it was a pain to add new systems. Instead, be on hyperspin 1.4, make an extra backup of your system ini files then upgrade to rocketlauncher. MAME High Score Tutorial For HyperSpin
Krayzed007 Posted August 10, 2015 Author Posted August 10, 2015 Ok... so going to RocketLauncher will be easy. I got that. Now to update from Hyperspin 1.3.3 to 1.4.... 1.)Download 1.4 and replace Hyperspin.exe in my Hyperspin folder 2.)Drop the Scripts Folder into my Hyperspin folder 3.)HyperLaunch_Path setting (in settings.ini) to be the full path Thats it?
ninja2bceen Posted August 10, 2015 Posted August 10, 2015 Yep Tapatalk signature Looking for letter makers. Volunteer http://www.hyperspin-fe.com/topic/10813-project-assignments/ To see what hyperspin still needs... http://hyperbase.hyperspin-fe.com/ Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
luckyluca Posted August 16, 2015 Posted August 16, 2015 Coming from a similar post I'm a little confused about the latest hyperlaunch version, I for instance I'm missing hyperlaunchHQ in my HS folder and missing HyperLaunch_Path in settings.ini. my hyperlaunch.exe is v1.1.73 and it says 2.25c in the .log file. could anybody point me to the lastest hyperlaunch? many thanks L YepTapatalk signatureLooking for letter makers. Volunteerhttp://www.hyperspin-fe.com/topic/10813-project-assignments/To see what hyperspin still needs...http://hyperbase.hyperspin-fe.com/ YepTapatalk signatureLooking for letter makers. Volunteerhttp://www.hyperspin-fe.com/topic/10813-project-assignments/To see what hyperspin still needs...http://hyperbase.hyperspin-fe.com/ YepTapatalk signatureLooking for letter makers. Volunteerhttp://www.hyperspin-fe.com/topic/10813-project-assignments/To see what hyperspin still needs...http://hyperbase.hyperspin-fe.com/
