teachimp Posted August 18, 2015 Posted August 18, 2015 I've recently come back to my working set-up and all seems well until I try to select a system on the main wheel - it simply returns me back to main wheel rather than the sub-wheel. I also try to exit but the exit menu is not visible, yet I can still exit with the correct key pushes. Can anybody help please?
heykool69 Posted August 18, 2015 Posted August 18, 2015 It happened to me also a couple days ago. Regardless which emulators i chose....it'll just brings me back to the wheel of emulators again each time i hit the return key. I was just on planning on deleting the entire files and reinstalling it again. Then out of the blue.....it worked. I'd tried changing some keyboard & joystick button settings in HyperHQ. And remapping the correct file paths. Can't quite remember what i did, but i must had done something right. Maybe it could be my return key was working as a "reset". Or maybe my PC just needs restarting each time i change some settings. Good luck.
Guest Posted August 18, 2015 Posted August 18, 2015 This usually happens when you have HLHQ set to only show rows you have. There maybe a problem with the rom path or the rom file extensions for that system in HLHQ. Either untick the boxes restricting which roms are shown. Or fix the path / file extensions.
Guest Posted August 18, 2015 Posted August 18, 2015 Hyperhq* Oh yeah, apologies HyperHQ - thanks for the correction.
volumetric Posted August 19, 2015 Posted August 19, 2015 If you're not using 1.4 this can happen when no speakers are plugged in.
teachimp Posted August 20, 2015 Author Posted August 20, 2015 Hey thanks guys, very interesting that you mention the sound device, the PC I'm trying it on doesn't have one installed. Will give this a go and get back to you
griffin518 Posted August 20, 2015 Posted August 20, 2015 Hey thanks guys, very interesting that you mention the sound device, the PC I'm trying it on doesn't have one installed. Will give this a go and get back to you Just plug any headphones or earbuds in to see if it'll work... worry about the final set up later. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
teachimp Posted August 20, 2015 Author Posted August 20, 2015 Well, I would never have solved that one in a million years, I installed a sound card and now it's all working as it should Thank you everyone for your help. Is this bug fixed in the newer versions?
heykool69 Posted August 20, 2015 Posted August 20, 2015 If you're not using 1.4 this can happen when no speakers are plugged in. Yes, i remember wiring my speakers before i turned on mine that day i found it working.
