Bitgamer
gunit
  On 9/30/2015 at 5:09 PM, gigapig said:
I have 4 SSD's in my machine and will soon be getting an M.2 drive for boot. The current  drive (OCZ Vertex 3) is about 4 years old and still absolutely fine.
the need for 4 of these drives is...??? Is it because the size still sucks? That was another thing for me. But, four years sounds NICE man.
:thefinger:I do my fighting in the real world, In a sanctioned cage or ring, not online tough guys:eviltongue:
Gracie Trained.
Purple Belt
Get some
:secruity:
  • Replies 54
  On 9/30/2015 at 5:04 PM, gigapig said:
There is a new compiled version of mame in the downloads section and some threads floating around for the slightly older 0.164.
http://www.hyperspin-fe.com/files/file/10828-mame-0165-x64-hi-score-no-nag/
If your ROM set is really old you might be better off getting a fresh set instead of messing around, but it will on your bandwidth.
I think that doing an entire download isn't a bad idea.
I can handle the bandwidth i think.
And how the heck do you get rid of those horrible " adult games " lol.
Gracie Trained.
Purple Belt
Get some
:secruity:
No the size to Dollar ratio is much better than it used to be. I have one for the OS, a 500gb for Steam and a 256gb for Hyperspin.
You can use a app to remove the adult games or use an xml that does not have the adult games on, they then won't show up on your wheel.
  On 9/30/2015 at 4:59 PM, D1RT33B1RD said:
You can use a mouse to play it for now. I had wiimotes working on an old setup, but it was so unstable and required too much voodoo to get it going again. For sure light guns are the best if you put them in. carnevil should have a folder with the name carnevil and a carnevil.chd file inside, when you load carnevil it's looking at the ROM then loading the information from the folder. Should work no problem unless you dumped the CHD files into the main folder instead of keeping them in their own folder. [emoji41]
Sent from my SM-N900T using Tapatalk
Im going to try this today then. Even with a AMD 4.1 8core, 16 gigs of ddr5. MSI Redeon 7900 overclocked. I swear i don't get it lol. Maybe there is some kind of optimizing i need to be doing.
I would like to get some inexpensive guns...but i really like how the EMS guns look.
Gracie Trained.
Purple Belt
Get some
:secruity:
