Kiro04 Posted September 1, 2015 Posted September 1, 2015 Hi guys! I'm working on Future Pinball tables and media right now. I've a wheel in HyperSpin for Future Pinball tables, and I want to run the tables directly from there. There is a way I can setup my config to do this? I hope that I make myself clear in what I want, sory my English!!! Regards! Juan Manuel
Metalzoic Posted September 1, 2015 Posted September 1, 2015 I deleted all my Future Pinball system and all my tables etc... so I don't remember for sure, but the instructions for how to set it up should be in the module notes like every other system.
Kiro04 Posted September 1, 2015 Author Posted September 1, 2015 I will read the notes then!!! Thanks for the quick answer! EDIT: Nothing in the module notes... EDIT 2: With RocketLauncher the tables runs perfectly... But, when try to run with HyperSpin, nothing happen...
Metalzoic Posted September 2, 2015 Posted September 2, 2015 What are your HyperHQ settings for Future Pinball?
Kiro04 Posted September 4, 2015 Author Posted September 4, 2015 I try all the combinations! EXECUTION: Normal PC GAME: Enabled EXECUTION: HyperLaunch PC GAME: Enabled EXECUTION: HyperLaunch PC GAME: Disabled EXECUTION: Normal PC GAME: Disabled The first combination (image below) works, but launch the editor of Future Pinball: While if I launch a table throw RocketLauncher, the table start for play, no editor open! If in "Execution" I select Hyperlaunch, Hyperspin do nothing. Maybe, to me, HyperHQ has to be edited to launch throw RocketLauncher, but I dont know how! Any ideas???
Metalzoic Posted September 4, 2015 Posted September 4, 2015 Did you recently upgrade your setup or set it up from scratch? I don't remember what the setup process for Future Pinball stuff was at all.
32assassin Posted September 4, 2015 Posted September 4, 2015 if you set your HyperHQ execution to normal, you are disabling the use of rocketlauncher. you need to keep the execution on Hyperlaunch if you can launch your tables with rocketlauncher, and nothing happens with hyperspin then their is something wrong with your hyperspin to rocketlauncher set up. are you using Hyperspin 1.3 or 1.4? post your Hyperspin log
Kiro04 Posted September 5, 2015 Author Posted September 5, 2015 On 9/4/2015 at 2:20 PM, Metalzoic said: Did you recently upgrade your setup or set it up from scratch? I don't remember what the setup process for Future Pinball stuff was at all. I recently upgrade HP and HL to RL... On 9/4/2015 at 7:28 PM, 32assassin said: if you set your HyperHQ execution to normal, you are disabling the use of rocketlauncher. you need to keep the execution on Hyperlaunch if you can launch your tables with rocketlauncher, and nothing happens with hyperspin then their is something wrong with your hyperspin to rocketlauncher set up. are you using Hyperspin 1.3 or 1.4? post your Hyperspin log I'm using HP 1.3.2.0. and RL. The HP log: 08:47:20 PM | HyperSpin Started 08:47:20 PM | Going FullScreen 08:47:20 PM | Checking for updates 08:47:20 PM | Update Check Complete 08:47:20 PM | Startup program unavailable 08:47:20 PM | Playing intro video 08:47:22 PM | Error intializing joysticks 08:47:22 PM | Menu Mode is multi 08:47:22 PM | Loading Main Menu.xml 08:47:24 PM | Main Menu.xml successfully loaded 08:47:25 PM | Main Menu wheel loaded successfully 08:47:28 PM | Loading Future Pinball.xml 08:47:28 PM | Main Menu.xml successfully loaded 08:47:28 PM | Future Pinball wheel loaded successfully 08:47:32 PM | Future Pinball wheel loaded successfully 08:47:37 PM | Launching Game 08:47:37 PM | Using HyperLaunch 08:47:37 PM | Getting HyperLaunch path 08:47:37 PM | HyperLaunch located at C:\Hyperspin\HyperLaunch.exe 08:47:37 PM | Running HyperLaunch.exe 08:47:37 PM | HyperLaunch Command Line is: C:\Hyperspin\HyperLaunch.exe "Future Pinball" "Fifth Element, The" 08:47:43 PM | Loading Main Menu.xml 08:47:43 PM | Main Menu.xml successfully loaded 08:47:43 PM | Main Menu wheel loaded successfully 08:47:45 PM | Exit program unavailable 08:47:45 PM | Quiting Hyperspin 08:47:45 PM | Bye! and this is the HL log: [code] 08:53:46 p.m. | HyperLaunch v2.25c 08:53:46 p.m. | System Specs: HyperSpin Dir: C:\Hyperspin OS: WIN_XP OS Language: 0409 OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1024x768 (1024x740 work) HyperSpin Res: 1024x768 AHK Version: 1.1.07.03 08:53:46 p.m. | HyperLaunch received "Future Pinball" and "Fifth Element, The" 08:53:46 p.m. | INI Keys read 08:53:46 p.m. | Possible duplicate launch. is already running, closing HyperLaunch I still have HL in the HP folder, for that reason I was saying that maybe I have to change to RL; but I don't know how!!! Thanks for the answers! Juan Manuel
Kiro04 Posted September 5, 2015 Author Posted September 5, 2015 I GOT IT WORKING!!!!!!!! (Yes, I'm screaming!) Finally! After try other combinations, I select another system in HyperHQ (Atari 2600) and copy the set up, got it working at last! I don't know why I get closed by the fact I must use it like a PC Game! Now it run perfectly from Hyperspin... Thanks for your answers guys! They help to resolve this mess! Regards! Juan Manuel
32assassin Posted September 5, 2015 Posted September 5, 2015 I knew what your problem was, that's why I asked what version of hyperspin you where using. if you are using version 1.3 you will need to run the Rocketlauncher to HS version 1.3 utility. if you where using version 1.4, all you had to do is set your execution to Hyperlaunch.
