HS main wheel speed and space
shitoken
After set the HS to run in full screen mode the wheel turn speed is slow and each  system wheel is too close to each other without space and some even nearly on top of others.
How can I adjust ?
You can change the size of the displayed wheel images in HHQ... that might space them out a bit more
I have adjusted the space already by changing the size of each wheel small, but the wheel still spin slow compare with 1.3v.
If I replaced it with HS1.3 speed turn like a fan. But 1.4 speed like a wind mill.
