Best key config with ipac?
andif
Hey everyone, i noticed that my default key setting on my ipac uses alt and tab, for those of us using the ipac what did you set yours too and then I'm guessing i have to edit the emus and maybe hyper spin / rocket too ? Thanks in advance.
Yes you will have to edit the emulator settings and also hyperspin depending on what your keys are.
Generally you will only need to edit the keys in rocketlauncher if you use the pause feature but don't forget to set your exit key.
I like many others have changed the default ipac keys as I found it interfered with some emulators (e.g. during button smashing ctl and alt).
There is a great bit of info on the rocketlauncher forums and here is the document they mention which I have used with great success.
how do you edit the default ipac keys iNTiGOD?
I use a tool called winipac which is found on the ultimarc website.
https://www.ultimarc.com/download.html
Keep in mind this tool works with 2015 model iPacs.
I did remember using another tool for my last build (about 5years ago).... So if you have an older version there should be something floating around on ultimarc.
Don't forget to save backups of your configs :)
I use a tool called winipac which is found on the ultimarc website.https://www.ultimarc.com/download.html
thanks.....I have the ipac2. I will have to look at the board and make sure it's a 2015 model
I'm lovin my arcade
Here's the link to the older Winipac program in case you need it. This is the one mine uses.
It's really simple to use and you can switch button configurations around in just a couple minutes.
Mostly letters seems to work best for my setup. I also use esc.and enter just in case I get a popup that a program closed unexpectedly. However there are games like mk9 and dead or alive last round that dont play nice with any config.
Sent from my VS986 using Tapatalk
