oldhag270 Posted October 29, 2015 Posted October 29, 2015 File Name: mameuifx x64 No Nag 0.167 File Submitter: oldhag270 File Submitted: 28 Oct 2015 File Category: Other Credits: oldhag270 & MAME Developers &mameuifx Developers Here is mameuifx 0.167 x64 No Nag. Click here to download this file
griffin518 Posted October 29, 2015 Posted October 29, 2015 Here's the MAME change log... a decent number of changes this time, including some HLSL tweaks. http://mamedev.org/releases/whatsnew_0167.txt Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
andyco40 Posted October 29, 2015 Posted October 29, 2015 my light gun sight still disappears with ur compiles even this one.
macaco Posted October 30, 2015 Posted October 30, 2015 my light gun sight still disappears with ur compiles even this one. weird, i've tried the last version .166 on three other cabs (all different hardware) with arcadeguns.com guns. i can enable and disable gun sight. i've tried this compile .167 on my cab as well, same results (enable and disable works fine)
sevenseal Posted October 30, 2015 Posted October 30, 2015 my light gun sight still disappears with ur compiles even this one.do you have your guns setup in the aimtrak config program as mouse/joystick buttons or as just a joystick? make all the different when you have it selected as pure joystick in the firmware, it should be mouse/joy buttons. also do you have dual lightguns check in mame.ini? because if check, it will break lightguns function.... also to mention while unchecked you still get multiple lightguns
andyco40 Posted October 30, 2015 Posted October 30, 2015 just tried still disappears cant play any light gun games cus of this.but if I get the compile from insertmorecoin its ok it works.
oldhag270 Posted November 10, 2015 Author Posted November 10, 2015 andyco40,I don't know why this is happening to you,because the only thing I do for this version is remove the nag screens.On another note is anyone else having trouble downloading this,the file was reported broken and I just want to get to the bottom of it.
sevenseal Posted November 11, 2015 Posted November 11, 2015 andyco40,I don't know why this is happening to you,because the only thing I do for this version is remove the nag screens.On another note is anyone else having trouble downloading this,the file was reported broken and I just want to get to the bottom of it.i tested your version, no issue there
