Bliss Box 4-play compatibility
brudibru
  • Replies 258
Alright gents, it's real, blissbox is set up in hyperspin!
How did I do it?
1. Download joytokey.exe
2. Map your keystrokes to each button using joytokey so that it matches your keys with your emulators
3. Use ghutchs start up script which you can find in the download page and ensure joytokey launches with hyperspin. Be sure to have joytokey start as minimized within joytokey ini
4. Ensure rocketlaunch has xpadder set to false and joytokey as true
5. Profit
How did I do it?
5. Profit
So you need to switch entirely from xpadder to joytokey? Not worth it with 84 systems
Sent from my HTC6535LVW using Tapatalk
Good job finding a solution though!!
That's the thing man, you don't have a lot of work at all. I was the same way man and almost gave up then posit hit me. I could switch to xpadder right now by just making xpadder move from false to true and move joytokey from true to false. It's that simple!!!! Do it, do it now
The set up literally takes like 10 min if you know the button
Wait what? Can you use both at the same time?
I have 67 systems and didn't want to do any remapping either. Just get joytokey. Open the file and based on the joystick button, click the button number like #1, determine what #1 would be in you emulators... Lucky think is all my systems have the same keys in xpadder. Once you save your ini and you autostart the app with hyperspin it just works
Oh so I just launch it... Like via Startup Script? And it'll just work after I create the master config?
You don't need to use xpadder I don't think anymore unless everyone of your systems has a different mapping which I doubt it. For systems like sega saturn, you can just map joytokey buttons with multiple keystrokes. I'm insanely happy right now
Ya man, it's crazy stupid how easy it is.
You sir, deserve a big gold star
FIY if you aren't planning on using the bliss box to control your hyperspin ui then you don't need the startup script (in my case because I use my bartop joysticks to control the hyperspin menu).
I only use joytokey for a handful of consoles that I have gamepad.
Also you may not even need joytokey for retroarch.
I'll let you know what I find.
Interesting, trying to figure out hot to just use bliss box on the consols with controllers. Joytokey rocketlauncher folder probably has the same set up and I'd just need to create a few folders you think?
I wonder if it would be possible to run xpadder and joytokey... In theory it should work.
Post on RL forums
I'm still concerned that the 2 profiles (xpadder + joytokey) are going to conflict... since the joysticks just show up as numbered inputs (button 1, button 2) wouldn't joytokey try to remap your xbox 360 controllers... while xpadder is already doing the same thing...
I'm going to test this myself as of right now I just have joytokey on and it works great. Then I got to thinking, I have pc xpadder profiles that I want to use etc. so I'm going to try the following. Default xpadder as the main setup, then for nes, snes, n64, genesis, sega 32x, ps2, ps1, gamecube will default to joytokey
Hey all. I just wanted to follow up and let anyone that's following this thread know that I received my replacement 4play this weekend and was successfully able to flash atari's 4playfix firmware to all 4 ports. As ulao suggested, it sounds like I got a defective unit the first time around, and he RMA'd it for me accordingly. I recorded the whole process in case it went haywire again. I know ninja wanted some video, but it sounds like you got it installed yourself anyways. So if anyone else wants to see video of the flash process, let me know, and I can post 'em.
Nice one
Now to the last challenge.
Front end = use xpadder
Majority of systems=use xpadder
Nintendo and sega systems use=vjoy for bliss box
There is a trick in rocketlauncher to do this. I'm still on the hunt
I have setup snes to use both my ipac and blissbox (snes controllers) within retroarch.
This is for the older version of RetroArch-v1.0.0.2-64-bit.
Below is a copy of my Super Nintendo.cfg (for retroarch). It includes direct mapping for the blissbox and keys for my ipac (bartop).
input_axis_threshold = "0.500000"
netplay_client_swap_input = "true"
input_descriptor_label_show = "true"
autoconfig_descriptor_label_show = "true"
input_descriptor_hide_unbound = "false"
load_dummy_on_core_shutdown = "true"
fps_show = "false"
libretro_path = ":\cores\bsnes_balanced_libretro.dll"
libretro_directory = ""
libretro_info_path = ":\info/"
cheat_database_path = ""
content_history_dir = ""
rewind_enable = "false"
audio_latency = "64"
audio_sync = "true"
audio_block_frames = "0"
rewind_granularity = "1"
video_shader = ":\shaders/crt/crt-geom.cgp"
video_shader_enable = "true"
video_aspect_ratio = "-1.000000"
video_windowed_fullscreen = "true"
video_scale = "3.000000"
autosave_interval = "0"
video_crop_overscan = "true"
video_scale_integer = "false"
video_smooth = "true"
video_threaded = "false"
video_shared_context = "false"
video_force_srgb_disable = "false"
video_fullscreen = "true"
video_refresh_rate = "59.950001"
video_monitor_index = "0"
video_fullscreen_x = "0"
video_fullscreen_y = "0"
video_driver = "gl"
menu_driver = "rgui"
menu_pause_libretro = "true"
menu_mouse_enable = "false"
video_vsync = "false"
video_hard_sync = "false"
video_hard_sync_frames = "0"
video_frame_delay = "0"
video_black_frame_insertion = "false"
video_disable_composition = "false"
pause_nonactive = "false"
video_swap_interval = "1"
video_gpu_screenshot = "true"
video_rotation = "0"
screenshot_directory = ":\screenshots/"
aspect_ratio_index = "0"
audio_device = ""
video_filter = ""
audio_dsp_plugin = ""
camera_device = ""
camera_allow = "false"
audio_rate_control = "true"
audio_rate_control_delta = "0.005000"
audio_max_timing_skew = "0.050000"
audio_volume = "0.000000"
video_context_driver = ""
audio_driver = "dsound"
audio_enable = "true"
audio_out_rate = "48000"
location_allow = "false"
video_font_size = "48.000000"
video_font_enable = "true"
system_directory = ":\system/"
extraction_directory = ""
resampler_directory = ""
audio_resampler = "sinc"
savefile_directory = "default"
savestate_directory = "default"
video_shader_dir = ":\shaders/"
video_filter_dir = "default"
audio_filter_dir = "default"
content_directory = "default"
assets_directory = "default"
playlist_directory = "default"
rgui_browser_directory = "default"
rgui_config_directory = ":\configs\"
rgui_show_start_screen = "false"
menu_navigation_wraparound_horizontal_enable = "true"
menu_navigation_wraparound_vertical_enable = "true"
game_history_path = ":\configs\retroarch-content-history.txt"
game_history_size = "100"
joypad_autoconfig_dir = ":\autoconfig/"
input_autodetect_enable = "true"
overlay_directory = "default"
input_overlay = ""
input_overlay_opacity = "0.700000"
input_overlay_scale = "1.000000"
video_font_path = ""
video_message_pos_x = "0.050000"
video_message_pos_y = "0.050000"
gamma_correction = "false"
soft_filter_enable = "false"
flicker_filter_enable = "false"
flicker_filter_index = "0"
soft_filter_index = "0"
current_resolution_id = "0"
custom_viewport_width = "960"
custom_viewport_height = "720"
custom_viewport_x = "0"
custom_viewport_y = "0"
block_sram_overwrite = "false"
savestate_auto_index = "false"
savestate_auto_save = "false"
savestate_auto_load = "true"
history_list_enable = "true"
fastforward_ratio = "1.000000"
fastforward_ratio_throttle_enable = "false"
slowmotion_ratio = "3.000000"
config_save_on_exit = "false"
sound_mode = "0"
state_slot = "0"
netplay_spectator_mode_enable = "false"
netplay_mode = "false"
netplay_ip_address = ""
netplay_ip_port = "0"
netplay_delay_frames = "0"
netplay_nickname = ""
user_language = "0"
custom_bgm_enable = "false"
input_driver = "dinput"
input_joypad_driver = "dinput"
input_keyboard_layout = ""
input_device_p1 = "0"
input_player1_joypad_index = "0"
input_libretro_device_p1 = "1"
input_player1_analog_dpad_mode = "0"
input_device_p2 = "0"
input_player2_joypad_index = "1"
input_libretro_device_p2 = "1"
input_player2_analog_dpad_mode = "0"
input_device_p3 = "0"
input_player3_joypad_index = "2"
input_libretro_device_p3 = "1"
input_player3_analog_dpad_mode = "0"
input_device_p4 = "0"
input_player4_joypad_index = "3"
input_libretro_device_p4 = "1"
input_player4_analog_dpad_mode = "0"
input_device_p5 = "0"
input_player5_joypad_index = "4"
input_libretro_device_p5 = "1"
input_player5_analog_dpad_mode = "0"
input_device_p6 = "0"
input_player6_joypad_index = "5"
input_libretro_device_p6 = "1"
input_player6_analog_dpad_mode = "0"
input_device_p7 = "0"
input_player7_joypad_index = "6"
input_libretro_device_p7 = "1"
input_player7_analog_dpad_mode = "0"
input_device_p8 = "0"
input_player8_joypad_index = "7"
input_libretro_device_p8 = "1"
input_player8_analog_dpad_mode = "0"
input_device_p9 = "0"
input_player9_joypad_index = "8"
input_libretro_device_p9 = "1"
input_player9_analog_dpad_mode = "0"
input_device_p10 = "0"
input_player10_joypad_index = "9"
input_libretro_device_p10 = "1"
input_player10_analog_dpad_mode = "0"
input_device_p11 = "0"
input_player11_joypad_index = "10"
input_libretro_device_p11 = "1"
input_player11_analog_dpad_mode = "0"
input_device_p12 = "0"
input_player12_joypad_index = "11"
input_libretro_device_p12 = "1"
input_player12_analog_dpad_mode = "0"
input_device_p13 = "0"
input_player13_joypad_index = "12"
input_libretro_device_p13 = "1"
input_player13_analog_dpad_mode = "0"
input_device_p14 = "0"
input_player14_joypad_index = "13"
input_libretro_device_p14 = "1"
input_player14_analog_dpad_mode = "0"
input_device_p15 = "0"
input_player15_joypad_index = "14"
input_libretro_device_p15 = "1"
input_player15_analog_dpad_mode = "0"
input_device_p16 = "0"
input_player16_joypad_index = "15"
input_libretro_device_p16 = "1"
input_player16_analog_dpad_mode = "0"
input_player1_b = "z"
input_player1_b_btn = "1"
input_player1_b_axis = "nul"
input_player1_y = "v"
input_player1_y_btn = "0"
input_player1_y_axis = "nul"
input_player1_select = "b"
input_player1_select_btn = "4"
input_player1_select_axis = "nul"
input_player1_start = "h"
input_player1_start_btn = "5"
input_player1_start_axis = "nul"
input_player1_up = "up"
input_player1_up_btn = "nul"
input_player1_up_axis = "-1"
input_player1_down = "down"
input_player1_down_btn = "nul"
input_player1_down_axis = "+1"
input_player1_left = "left"
input_player1_left_btn = "nul"
input_player1_left_axis = "-0"
input_player1_right = "right"
input_player1_right_btn = "nul"
input_player1_right_axis = "+0"
input_player1_a = "l"
input_player1_a_btn = "3"
input_player1_a_axis = "nul"
input_player1_x = "j"
input_player1_x_btn = "2"
input_player1_x_axis = "nul"
input_player1_l = "k"
input_player1_l_btn = "6"
input_player1_l_axis = "nul"
input_player1_r = "x"
input_player1_r_btn = "7"
input_player1_r_axis = "nul"
input_player1_l2 = "nul"
input_player1_l2_btn = "nul"
input_player1_l2_axis = "nul"
input_player1_r2 = "nul"
input_player1_r2_btn = "nul"
input_player1_r2_axis = "nul"
input_player1_l3 = "nul"
input_player1_l3_btn = "nul"
input_player1_l3_axis = "nul"
input_player1_r3 = "nul"
input_player1_r3_btn = "nul"
input_player1_r3_axis = "nul"
input_player1_l_x_plus = "nul"
input_player1_l_x_plus_btn = "nul"
input_player1_l_x_plus_axis = "nul"
input_player1_l_x_minus = "nul"
input_player1_l_x_minus_btn = "nul"
input_player1_l_x_minus_axis = "nul"
input_player1_l_y_plus = "nul"
input_player1_l_y_plus_btn = "nul"
input_player1_l_y_plus_axis = "nul"
input_player1_l_y_minus = "nul"
input_player1_l_y_minus_btn = "nul"
input_player1_l_y_minus_axis = "nul"
input_player1_r_x_plus = "nul"
input_player1_r_x_plus_btn = "nul"
input_player1_r_x_plus_axis = "nul"
input_player1_r_x_minus = "nul"
input_player1_r_x_minus_btn = "nul"
input_player1_r_x_minus_axis = "nul"
input_player1_r_y_plus = "nul"
input_player1_r_y_plus_btn = "nul"
input_player1_r_y_plus_axis = "nul"
input_player1_r_y_minus = "nul"
input_player1_r_y_minus_btn = "nul"
input_player1_r_y_minus_axis = "nul"
input_player1_turbo = "nul"
input_player1_turbo_btn = "nul"
input_player1_turbo_axis = "nul"
input_toggle_fast_forward = "nul"
input_toggle_fast_forward_btn = "nul"
input_toggle_fast_forward_axis = "nul"
input_hold_fast_forward = "nul"
input_hold_fast_forward_btn = "nul"
input_hold_fast_forward_axis = "nul"
input_load_state = "f4"
input_load_state_btn = "nul"
input_load_state_axis = "nul"
input_save_state = "f2"
input_save_state_btn = "nul"
input_save_state_axis = "nul"
input_toggle_fullscreen = "nul"
input_toggle_fullscreen_btn = "nul"
input_toggle_fullscreen_axis = "nul"
input_exit_emulator = "escape"
input_exit_emulator_btn = "nul"
input_exit_emulator_axis = "nul"
input_state_slot_increase = "f7"
input_state_slot_increase_btn = "nul"
input_state_slot_increase_axis = "nul"
input_state_slot_decrease = "f6"
input_state_slot_decrease_btn = "nul"
input_state_slot_decrease_axis = "nul"
input_rewind = "nul"
input_rewind_btn = "nul"
input_rewind_axis = "nul"
input_movie_record_toggle = "nul"
input_movie_record_toggle_btn = "nul"
input_movie_record_toggle_axis = "nul"
input_pause_toggle = "nul"
input_pause_toggle_btn = "nul"
input_pause_toggle_axis = "nul"
input_frame_advance = "nul"
input_frame_advance_btn = "nul"
input_frame_advance_axis = "nul"
input_reset = "nul"
input_reset_btn = "nul"
input_reset_axis = "nul"
input_shader_next = "nul"
input_shader_next_btn = "nul"
input_shader_next_axis = "nul"
input_shader_prev = "nul"
input_shader_prev_btn = "nul"
input_shader_prev_axis = "nul"
input_cheat_index_plus = "nul"
input_cheat_index_plus_btn = "nul"
input_cheat_index_plus_axis = "nul"
input_cheat_index_minus = "nul"
input_cheat_index_minus_btn = "nul"
input_cheat_index_minus_axis = "nul"
input_cheat_toggle = "nul"
input_cheat_toggle_btn = "nul"
input_cheat_toggle_axis = "nul"
input_screenshot = "f8"
input_screenshot_btn = "nul"
input_screenshot_axis = "nul"
input_audio_mute = "f9"
input_audio_mute_btn = "nul"
input_audio_mute_axis = "nul"
input_netplay_flip_players = "nul"
input_netplay_flip_players_btn = "nul"
input_netplay_flip_players_axis = "nul"
input_slowmotion = "nul"
input_slowmotion_btn = "nul"
input_slowmotion_axis = "nul"
input_enable_hotkey = "nul"
input_enable_hotkey_btn = "nul"
input_enable_hotkey_axis = "nul"
input_volume_up = "nul"
input_volume_up_btn = "nul"
input_volume_up_axis = "nul"
input_volume_down = "nul"
input_volume_down_btn = "nul"
input_volume_down_axis = "nul"
input_overlay_next = "nul"
input_overlay_next_btn = "nul"
input_overlay_next_axis = "nul"
input_disk_eject_toggle = "nul"
input_disk_eject_toggle_btn = "nul"
input_disk_eject_toggle_axis = "nul"
input_disk_next = "nul"
input_disk_next_btn = "nul"
input_disk_next_axis = "nul"
input_disk_prev = "nul"
input_disk_prev_btn = "nul"
input_disk_prev_axis = "nul"
input_grab_mouse_toggle = "f11"
input_grab_mouse_toggle_btn = "nul"
input_grab_mouse_toggle_axis = "nul"
input_menu_toggle = "f1"
input_menu_toggle_btn = "nul"
input_menu_toggle_axis = "nul"
input_player2_b = "q"
input_player2_b_btn = "1"
input_player2_b_axis = "nul"
input_player2_y = "o"
input_player2_y_btn = "3"
input_player2_y_axis = "nul"
input_player2_select = "m"
input_player2_select_btn = "4"
input_player2_select_axis = "nul"
input_player2_start = "n"
input_player2_start_btn = "5"
input_player2_start_axis = "nul"
input_player2_up = "w"
input_player2_up_btn = "nul"
input_player2_up_axis = "-1"
input_player2_down = "s"
input_player2_down_btn = "nul"
input_player2_down_axis = "+1"
input_player2_left = "a"
input_player2_left_btn = "nul"
input_player2_left_axis = "-0"
input_player2_right = "d"
input_player2_right_btn = "nul"
input_player2_right_axis = "+0"
input_player2_a = "r"
input_player2_a_btn = "3"
input_player2_a_axis = "nul"
input_player2_x = "y"
input_player2_x_btn = "2"
input_player2_x_axis = "nul"
input_player2_l = "f"
input_player2_l_btn = "6"
input_player2_l_axis = "nul"
input_player2_r = "g"
input_player2_r_btn = "7"
input_player2_r_axis = "nul"
input_player2_l2 = "nul"
input_player2_l2_btn = "nul"
input_player2_l2_axis = "nul"
input_player2_r2 = "nul"
input_player2_r2_btn = "nul"
input_player2_r2_axis = "nul"
input_player2_l3 = "nul"
input_player2_l3_btn = "nul"
input_player2_l3_axis = "nul"
input_player2_r3 = "nul"
input_player2_r3_btn = "nul"
input_player2_r3_axis = "nul"
input_player2_l_x_plus = "nul"
input_player2_l_x_plus_btn = "nul"
input_player2_l_x_plus_axis = "nul"
input_player2_l_x_minus = "nul"
input_player2_l_x_minus_btn = "nul"
input_player2_l_x_minus_axis = "nul"
input_player2_l_y_plus = "nul"
input_player2_l_y_plus_btn = "nul"
input_player2_l_y_plus_axis = "nul"
input_player2_l_y_minus = "nul"
input_player2_l_y_minus_btn = "nul"
input_player2_l_y_minus_axis = "nul"
input_player2_r_x_plus = "nul"
input_player2_r_x_plus_btn = "nul"
input_player2_r_x_plus_axis = "nul"
input_player2_r_x_minus = "nul"
input_player2_r_x_minus_btn = "nul"
input_player2_r_x_minus_axis = "nul"
input_player2_r_y_plus = "nul"
input_player2_r_y_plus_btn = "nul"
input_player2_r_y_plus_axis = "nul"
input_player2_r_y_minus = "nul"
input_player2_r_y_minus_btn = "nul"
input_player2_r_y_minus_axis = "nul"
input_player2_turbo = "nul"
input_player2_turbo_btn = "nul"
input_player2_turbo_axis = "nul"
input_player3_b = "nul"
input_player3_b_btn = "nul"
input_player3_b_axis = "nul"
input_player3_y = "nul"
input_player3_y_btn = "nul"
input_player3_y_axis = "nul"
input_player3_select = "nul"
input_player3_select_btn = "nul"
input_player3_select_axis = "nul"
input_player3_start = "nul"
input_player3_start_btn = "nul"
input_player3_start_axis = "nul"
input_player3_up = "nul"
input_player3_up_btn = "nul"
input_player3_up_axis = "nul"
input_player3_down = "nul"
input_player3_down_btn = "nul"
input_player3_down_axis = "nul"
input_player3_left = "nul"
input_player3_left_btn = "nul"
input_player3_left_axis = "nul"
input_player3_right = "nul"
input_player3_right_btn = "nul"
input_player3_right_axis = "nul"
input_player3_a = "nul"
input_player3_a_btn = "nul"
input_player3_a_axis = "nul"
input_player3_x = "nul"
input_player3_x_btn = "nul"
input_player3_x_axis = "nul"
input_player3_l = "nul"
input_player3_l_btn = "nul"
input_player3_l_axis = "nul"
input_player3_r = "nul"
input_player3_r_btn = "nul"
input_player3_r_axis = "nul"
input_player3_l2 = "nul"
input_player3_l2_btn = "nul"
input_player3_l2_axis = "nul"
input_player3_r2 = "nul"
input_player3_r2_btn = "nul"
input_player3_r2_axis = "nul"
input_player3_l3 = "nul"
input_player3_l3_btn = "nul"
input_player3_l3_axis = "nul"
input_player3_r3 = "nul"
input_player3_r3_btn = "nul"
input_player3_r3_axis = "nul"
input_player3_l_x_plus = "nul"
input_player3_l_x_plus_btn = "nul"
input_player3_l_x_plus_axis = "nul"
input_player3_l_x_minus = "nul"
input_player3_l_x_minus_btn = "nul"
input_player3_l_x_minus_axis = "nul"
input_player3_l_y_plus = "nul"
input_player3_l_y_plus_btn = "nul"
input_player3_l_y_plus_axis = "nul"
input_player3_l_y_minus = "nul"
input_player3_l_y_minus_btn = "nul"
input_player3_l_y_minus_axis = "nul"
input_player3_r_x_plus = "nul"
input_player3_r_x_plus_btn = "nul"
input_player3_r_x_plus_axis = "nul"
input_player3_r_x_minus = "nul"
input_player3_r_x_minus_btn = "nul"
input_player3_r_x_minus_axis = "nul"
input_player3_r_y_plus = "nul"
input_player3_r_y_plus_btn = "nul"
input_player3_r_y_plus_axis = "nul"
input_player3_r_y_minus = "nul"
input_player3_r_y_minus_btn = "nul"
input_player3_r_y_minus_axis = "nul"
input_player3_turbo = "nul"
input_player3_turbo_btn = "nul"
input_player3_turbo_axis = "nul"
input_player4_b = "nul"
input_player4_b_btn = "nul"
input_player4_b_axis = "nul"
input_player4_y = "nul"
input_player4_y_btn = "nul"
input_player4_y_axis = "nul"
input_player4_select = "nul"
input_player4_select_btn = "nul"
input_player4_select_axis = "nul"
input_player4_start = "nul"
input_player4_start_btn = "nul"
input_player4_start_axis = "nul"
input_player4_up = "nul"
input_player4_up_btn = "nul"
input_player4_up_axis = "nul"
input_player4_down = "nul"
input_player4_down_btn = "nul"
input_player4_down_axis = "nul"
input_player4_left = "nul"
input_player4_left_btn = "nul"
input_player4_left_axis = "nul"
input_player4_right = "nul"
input_player4_right_btn = "nul"
input_player4_right_axis = "nul"
input_player4_a = "nul"
input_player4_a_btn = "nul"
input_player4_a_axis = "nul"
input_player4_x = "nul"
input_player4_x_btn = "nul"
input_player4_x_axis = "nul"
input_player4_l = "nul"
input_player4_l_btn = "nul"
input_player4_l_axis = "nul"
input_player4_r = "nul"
input_player4_r_btn = "nul"
input_player4_r_axis = "nul"
input_player4_l2 = "nul"
input_player4_l2_btn = "nul"
input_player4_l2_axis = "nul"
input_player4_r2 = "nul"
input_player4_r2_btn = "nul"
input_player4_r2_axis = "nul"
input_player4_l3 = "nul"
input_player4_l3_btn = "nul"
input_player4_l3_axis = "nul"
input_player4_r3 = "nul"
input_player4_r3_btn = "nul"
input_player4_r3_axis = "nul"
input_player4_l_x_plus = "nul"
input_player4_l_x_plus_btn = "nul"
input_player4_l_x_plus_axis = "nul"
input_player4_l_x_minus = "nul"
input_player4_l_x_minus_btn = "nul"
input_player4_l_x_minus_axis = "nul"
input_player4_l_y_plus = "nul"
input_player4_l_y_plus_btn = "nul"
input_player4_l_y_plus_axis = "nul"
input_player4_l_y_minus = "nul"
input_player4_l_y_minus_btn = "nul"
input_player4_l_y_minus_axis = "nul"
input_player4_r_x_plus = "nul"
input_player4_r_x_plus_btn = "nul"
input_player4_r_x_plus_axis = "nul"
input_player4_r_x_minus = "nul"
input_player4_r_x_minus_btn = "nul"
input_player4_r_x_minus_axis = "nul"
input_player4_r_y_plus = "nul"
input_player4_r_y_plus_btn = "nul"
input_player4_r_y_plus_axis = "nul"
input_player4_r_y_minus = "nul"
input_player4_r_y_minus_btn = "nul"
input_player4_r_y_minus_axis = "nul"
input_player4_turbo = "nul"
input_player4_turbo_btn = "nul"
input_player4_turbo_axis = "nul"
input_player5_b = "nul"
input_player5_b_btn = "nul"
input_player5_b_axis = "nul"
input_player5_y = "nul"
input_player5_y_btn = "nul"
input_player5_y_axis = "nul"
input_player5_select = "nul"
input_player5_select_btn = "nul"
input_player5_select_axis = "nul"
input_player5_start = "nul"
input_player5_start_btn = "nul"
input_player5_start_axis = "nul"
input_player5_up = "nul"
input_player5_up_btn = "nul"
input_player5_up_axis = "nul"
input_player5_down = "nul"
input_player5_down_btn = "nul"
input_player5_down_axis = "nul"
input_player5_left = "nul"
input_player5_left_btn = "nul"
input_player5_left_axis = "nul"
input_player5_right = "nul"
input_player5_right_btn = "nul"
input_player5_right_axis = "nul"
input_player5_a = "nul"
input_player5_a_btn = "nul"
input_player5_a_axis = "nul"
input_player5_x = "nul"
input_player5_x_btn = "nul"
input_player5_x_axis = "nul"
input_player5_l = "nul"
input_player5_l_btn = "nul"
input_player5_l_axis = "nul"
input_player5_r = "nul"
input_player5_r_btn = "nul"
input_player5_r_axis = "nul"
input_player5_l2 = "nul"
input_player5_l2_btn = "nul"
input_player5_l2_axis = "nul"
input_player5_r2 = "nul"
input_player5_r2_btn = "nul"
input_player5_r2_axis = "nul"
input_player5_l3 = "nul"
input_player5_l3_btn = "nul"
input_player5_l3_axis = "nul"
input_player5_r3 = "nul"
input_player5_r3_btn = "nul"
input_player5_r3_axis = "nul"
input_player5_l_x_plus = "nul"
input_player5_l_x_plus_btn = "nul"
input_player5_l_x_plus_axis = "nul"
input_player5_l_x_minus = "nul"
input_player5_l_x_minus_btn = "nul"
input_player5_l_x_minus_axis = "nul"
input_player5_l_y_plus = "nul"
input_player5_l_y_plus_btn = "nul"
input_player5_l_y_plus_axis = "nul"
input_player5_l_y_minus = "nul"
input_player5_l_y_minus_btn = "nul"
input_player5_l_y_minus_axis = "nul"
input_player5_r_x_plus = "nul"
input_player5_r_x_plus_btn = "nul"
input_player5_r_x_plus_axis = "nul"
input_player5_r_x_minus = "nul"
input_player5_r_x_minus_btn = "nul"
input_player5_r_x_minus_axis = "nul"
input_player5_r_y_plus = "nul"
input_player5_r_y_plus_btn = "nul"
input_player5_r_y_plus_axis = "nul"
input_player5_r_y_minus = "nul"
input_player5_r_y_minus_btn = "nul"
input_player5_r_y_minus_axis = "nul"
input_player5_turbo = "nul"
input_player5_turbo_btn = "nul"
input_player5_turbo_axis = "nul"
input_player6_b = "nul"
input_player6_b_btn = "nul"
input_player6_b_axis = "nul"
input_player6_y = "nul"
input_player6_y_btn = "nul"
input_player6_y_axis = "nul"
input_player6_select = "nul"
input_player6_select_btn = "nul"
input_player6_select_axis = "nul"
input_player6_start = "nul"
input_player6_start_btn = "nul"
input_player6_start_axis = "nul"
input_player6_up = "nul"
input_player6_up_btn = "nul"
input_player6_up_axis = "nul"
input_player6_down = "nul"
input_player6_down_btn = "nul"
input_player6_down_axis = "nul"
input_player6_left = "nul"
input_player6_left_btn = "nul"
input_player6_left_axis = "nul"
input_player6_right = "nul"
input_player6_right_btn = "nul"
input_player6_right_axis = "nul"
input_player6_a = "nul"
input_player6_a_btn = "nul"
input_player6_a_axis = "nul"
input_player6_x = "nul"
input_player6_x_btn = "nul"
input_player6_x_axis = "nul"
input_player6_l = "nul"
input_player6_l_btn = "nul"
input_player6_l_axis = "nul"
input_player6_r = "nul"
input_player6_r_btn = "nul"
input_player6_r_axis = "nul"
input_player6_l2 = "nul"
input_player6_l2_btn = "nul"
input_player6_l2_axis = "nul"
input_player6_r2 = "nul"
input_player6_r2_btn = "nul"
input_player6_r2_axis = "nul"
input_player6_l3 = "nul"
input_player6_l3_btn = "nul"
input_player6_l3_axis = "nul"
input_player6_r3 = "nul"
input_player6_r3_btn = "nul"
input_player6_r3_axis = "nul"
input_player6_l_x_plus = "nul"
input_player6_l_x_plus_btn = "nul"
input_player6_l_x_plus_axis = "nul"
input_player6_l_x_minus = "nul"
input_player6_l_x_minus_btn = "nul"
input_player6_l_x_minus_axis = "nul"
input_player6_l_y_plus = "nul"
input_player6_l_y_plus_btn = "nul"
input_player6_l_y_plus_axis = "nul"
input_player6_l_y_minus = "nul"
input_player6_l_y_minus_btn = "nul"
input_player6_l_y_minus_axis = "nul"
input_player6_r_x_plus = "nul"
input_player6_r_x_plus_btn = "nul"
input_player6_r_x_plus_axis = "nul"
input_player6_r_x_minus = "nul"
input_player6_r_x_minus_btn = "nul"
input_player6_r_x_minus_axis = "nul"
input_player6_r_y_plus = "nul"
input_player6_r_y_plus_btn = "nul"
input_player6_r_y_plus_axis = "nul"
input_player6_r_y_minus = "nul"
input_player6_r_y_minus_btn = "nul"
input_player6_r_y_minus_axis = "nul"
input_player6_turbo = "nul"
input_player6_turbo_btn = "nul"
input_player6_turbo_axis = "nul"
input_player7_b = "nul"
input_player7_b_btn = "nul"
input_player7_b_axis = "nul"
input_player7_y = "nul"
input_player7_y_btn = "nul"
input_player7_y_axis = "nul"
input_player7_select = "nul"
input_player7_select_btn = "nul"
input_player7_select_axis = "nul"
input_player7_start = "nul"
input_player7_start_btn = "nul"
input_player7_start_axis = "nul"
input_player7_up = "nul"
input_player7_up_btn = "nul"
input_player7_up_axis = "nul"
input_player7_down = "nul"
input_player7_down_btn = "nul"
input_player7_down_axis = "nul"
input_player7_left = "nul"
input_player7_left_btn = "nul"
input_player7_left_axis = "nul"
input_player7_right = "nul"
input_player7_right_btn = "nul"
input_player7_right_axis = "nul"
input_player7_a = "nul"
input_player7_a_btn = "nul"
input_player7_a_axis = "nul"
input_player7_x = "nul"
input_player7_x_btn = "nul"
input_player7_x_axis = "nul"
input_player7_l = "nul"
input_player7_l_btn = "nul"
input_player7_l_axis = "nul"
input_player7_r = "nul"
input_player7_r_btn = "nul"
input_player7_r_axis = "nul"
input_player7_l2 = "nul"
input_player7_l2_btn = "nul"
input_player7_l2_axis = "nul"
input_player7_r2 = "nul"
input_player7_r2_btn = "nul"
input_player7_r2_axis = "nul"
input_player7_l3 = "nul"
input_player7_l3_btn = "nul"
input_player7_l3_axis = "nul"
input_player7_r3 = "nul"
input_player7_r3_btn = "nul"
input_player7_r3_axis = "nul"
input_player7_l_x_plus = "nul"
input_player7_l_x_plus_btn = "nul"
input_player7_l_x_plus_axis = "nul"
input_player7_l_x_minus = "nul"
input_player7_l_x_minus_btn = "nul"
input_player7_l_x_minus_axis = "nul"
input_player7_l_y_plus = "nul"
input_player7_l_y_plus_btn = "nul"
input_player7_l_y_plus_axis = "nul"
input_player7_l_y_minus = "nul"
input_player7_l_y_minus_btn = "nul"
input_player7_l_y_minus_axis = "nul"
input_player7_r_x_plus = "nul"
input_player7_r_x_plus_btn = "nul"
input_player7_r_x_plus_axis = "nul"
input_player7_r_x_minus = "nul"
input_player7_r_x_minus_btn = "nul"
input_player7_r_x_minus_axis = "nul"
input_player7_r_y_plus = "nul"
input_player7_r_y_plus_btn = "nul"
input_player7_r_y_plus_axis = "nul"
input_player7_r_y_minus = "nul"
input_player7_r_y_minus_btn = "nul"
input_player7_r_y_minus_axis = "nul"
input_player7_turbo = "nul"
input_player7_turbo_btn = "nul"
input_player7_turbo_axis = "nul"
input_player8_b = "nul"
input_player8_b_btn = "nul"
input_player8_b_axis = "nul"
input_player8_y = "nul"
input_player8_y_btn = "nul"
input_player8_y_axis = "nul"
input_player8_select = "nul"
input_player8_select_btn = "nul"
input_player8_select_axis = "nul"
input_player8_start = "nul"
input_player8_start_btn = "nul"
input_player8_start_axis = "nul"
input_player8_up = "nul"
input_player8_up_btn = "nul"
input_player8_up_axis = "nul"
input_player8_down = "nul"
input_player8_down_btn = "nul"
input_player8_down_axis = "nul"
input_player8_left = "nul"
input_player8_left_btn = "nul"
input_player8_left_axis = "nul"
input_player8_right = "nul"
input_player8_right_btn = "nul"
input_player8_right_axis = "nul"
input_player8_a = "nul"
input_player8_a_btn = "nul"
input_player8_a_axis = "nul"
input_player8_x = "nul"
input_player8_x_btn = "nul"
input_player8_x_axis = "nul"
input_player8_l = "nul"
input_player8_l_btn = "nul"
input_player8_l_axis = "nul"
input_player8_r = "nul"
input_player8_r_btn = "nul"
input_player8_r_axis = "nul"
input_player8_l2 = "nul"
input_player8_l2_btn = "nul"
input_player8_l2_axis = "nul"
input_player8_r2 = "nul"
input_player8_r2_btn = "nul"
input_player8_r2_axis = "nul"
input_player8_l3 = "nul"
input_player8_l3_btn = "nul"
input_player8_l3_axis = "nul"
input_player8_r3 = "nul"
input_player8_r3_btn = "nul"
input_player8_r3_axis = "nul"
input_player8_l_x_plus = "nul"
input_player8_l_x_plus_btn = "nul"
input_player8_l_x_plus_axis = "nul"
input_player8_l_x_minus = "nul"
input_player8_l_x_minus_btn = "nul"
input_player8_l_x_minus_axis = "nul"
input_player8_l_y_plus = "nul"
input_player8_l_y_plus_btn = "nul"
input_player8_l_y_plus_axis = "nul"
input_player8_l_y_minus = "nul"
input_player8_l_y_minus_btn = "nul"
input_player8_l_y_minus_axis = "nul"
input_player8_r_x_plus = "nul"
input_player8_r_x_plus_btn = "nul"
input_player8_r_x_plus_axis = "nul"
input_player8_r_x_minus = "nul"
input_player8_r_x_minus_btn = "nul"
input_player8_r_x_minus_axis = "nul"
input_player8_r_y_plus = "nul"
input_player8_r_y_plus_btn = "nul"
input_player8_r_y_plus_axis = "nul"
input_player8_r_y_minus = "nul"
input_player8_r_y_minus_btn = "nul"
input_player8_r_y_minus_axis = "nul"
input_player8_turbo = "nul"
input_player8_turbo_btn = "nul"
input_player8_turbo_axis = "nul"
input_player9_b = "nul"
input_player9_b_btn = "nul"
input_player9_b_axis = "nul"
input_player9_y = "nul"
input_player9_y_btn = "nul"
input_player9_y_axis = "nul"
input_player9_select = "nul"
input_player9_select_btn = "nul"
input_player9_select_axis = "nul"
input_player9_start = "nul"
input_player9_start_btn = "nul"
input_player9_start_axis = "nul"
input_player9_up = "nul"
input_player9_up_btn = "nul"
input_player9_up_axis = "nul"
input_player9_down = "nul"
input_player9_down_btn = "nul"
input_player9_down_axis = "nul"
input_player9_left = "nul"
input_player9_left_btn = "nul"
input_player9_left_axis = "nul"
input_player9_right = "nul"
input_player9_right_btn = "nul"
input_player9_right_axis = "nul"
input_player9_a = "nul"
input_player9_a_btn = "nul"
input_player9_a_axis = "nul"
input_player9_x = "nul"
input_player9_x_btn = "nul"
input_player9_x_axis = "nul"
input_player9_l = "nul"
input_player9_l_btn = "nul"
input_player9_l_axis = "nul"
input_player9_r = "nul"
input_player9_r_btn = "nul"
input_player9_r_axis = "nul"
input_player9_l2 = "nul"
input_player9_l2_btn = "nul"
input_player9_l2_axis = "nul"
input_player9_r2 = "nul"
input_player9_r2_btn = "nul"
input_player9_r2_axis = "nul"
input_player9_l3 = "nul"
input_player9_l3_btn = "nul"
input_player9_l3_axis = "nul"
input_player9_r3 = "nul"
input_player9_r3_btn = "nul"
input_player9_r3_axis = "nul"
input_player9_l_x_plus = "nul"
input_player9_l_x_plus_btn = "nul"
input_player9_l_x_plus_axis = "nul"
input_player9_l_x_minus = "nul"
input_player9_l_x_minus_btn = "nul"
input_player9_l_x_minus_axis = "nul"
input_player9_l_y_plus = "nul"
input_player9_l_y_plus_btn = "nul"
input_player9_l_y_plus_axis = "nul"
input_player9_l_y_minus = "nul"
input_player9_l_y_minus_btn = "nul"
input_player9_l_y_minus_axis = "nul"
input_player9_r_x_plus = "nul"
input_player9_r_x_plus_btn = "nul"
input_player9_r_x_plus_axis = "nul"
input_player9_r_x_minus = "nul"
input_player9_r_x_minus_btn = "nul"
input_player9_r_x_minus_axis = "nul"
input_player9_r_y_plus = "nul"
input_player9_r_y_plus_btn = "nul"
input_player9_r_y_plus_axis = "nul"
input_player9_r_y_minus = "nul"
input_player9_r_y_minus_btn = "nul"
input_player9_r_y_minus_axis = "nul"
input_player9_turbo = "nul"
input_player9_turbo_btn = "nul"
input_player9_turbo_axis = "nul"
input_player10_b = "nul"
input_player10_b_btn = "nul"
input_player10_b_axis = "nul"
input_player10_y = "nul"
input_player10_y_btn = "nul"
input_player10_y_axis = "nul"
input_player10_select = "nul"
input_player10_select_btn = "nul"
input_player10_select_axis = "nul"
input_player10_start = "nul"
input_player10_start_btn = "nul"
input_player10_start_axis = "nul"
input_player10_up = "nul"
input_player10_up_btn = "nul"
input_player10_up_axis = "nul"
input_player10_down = "nul"
input_player10_down_btn = "nul"
input_player10_down_axis = "nul"
input_player10_left = "nul"
input_player10_left_btn = "nul"
input_player10_left_axis = "nul"
input_player10_right = "nul"
input_player10_right_btn = "nul"
input_player10_right_axis = "nul"
input_player10_a = "nul"
input_player10_a_btn = "nul"
input_player10_a_axis = "nul"
input_player10_x = "nul"
input_player10_x_btn = "nul"
input_player10_x_axis = "nul"
input_player10_l = "nul"
input_player10_l_btn = "nul"
input_player10_l_axis = "nul"
input_player10_r = "nul"
input_player10_r_btn = "nul"
input_player10_r_axis = "nul"
input_player10_l2 = "nul"
input_player10_l2_btn = "nul"
input_player10_l2_axis = "nul"
input_player10_r2 = "nul"
input_player10_r2_btn = "nul"
input_player10_r2_axis = "nul"
input_player10_l3 = "nul"
input_player10_l3_btn = "nul"
input_player10_l3_axis = "nul"
input_player10_r3 = "nul"
input_player10_r3_btn = "nul"
input_player10_r3_axis = "nul"
input_player10_l_x_plus = "nul"
input_player10_l_x_plus_btn = "nul"
input_player10_l_x_plus_axis = "nul"
input_player10_l_x_minus = "nul"
input_player10_l_x_minus_btn = "nul"
input_player10_l_x_minus_axis = "nul"
input_player10_l_y_plus = "nul"
input_player10_l_y_plus_btn = "nul"
input_player10_l_y_plus_axis = "nul"
input_player10_l_y_minus = "nul"
input_player10_l_y_minus_btn = "nul"
input_player10_l_y_minus_axis = "nul"
input_player10_r_x_plus = "nul"
input_player10_r_x_plus_btn = "nul"
input_player10_r_x_plus_axis = "nul"
input_player10_r_x_minus = "nul"
input_player10_r_x_minus_btn = "nul"
input_player10_r_x_minus_axis = "nul"
input_player10_r_y_plus = "nul"
input_player10_r_y_plus_btn = "nul"
input_player10_r_y_plus_axis = "nul"
input_player10_r_y_minus = "nul"
input_player10_r_y_minus_btn = "nul"
input_player10_r_y_minus_axis = "nul"
input_player10_turbo = "nul"
input_player10_turbo_btn = "nul"
input_player10_turbo_axis = "nul"
input_player11_b = "nul"
input_player11_b_btn = "nul"
input_player11_b_axis = "nul"
input_player11_y = "nul"
input_player11_y_btn = "nul"
input_player11_y_axis = "nul"
input_player11_select = "nul"
input_player11_select_btn = "nul"
input_player11_select_axis = "nul"
input_player11_start = "nul"
input_player11_start_btn = "nul"
input_player11_start_axis = "nul"
input_player11_up = "nul"
input_player11_up_btn = "nul"
input_player11_up_axis = "nul"
input_player11_down = "nul"
input_player11_down_btn = "nul"
input_player11_down_axis = "nul"
input_player11_left = "nul"
input_player11_left_btn = "nul"
input_player11_left_axis = "nul"
input_player11_right = "nul"
input_player11_right_btn = "nul"
input_player11_right_axis = "nul"
input_player11_a = "nul"
input_player11_a_btn = "nul"
input_player11_a_axis = "nul"
input_player11_x = "nul"
input_player11_x_btn = "nul"
input_player11_x_axis = "nul"
input_player11_l = "nul"
input_player11_l_btn = "nul"
input_player11_l_axis = "nul"
input_player11_r = "nul"
input_player11_r_btn = "nul"
input_player11_r_axis = "nul"
input_player11_l2 = "nul"
input_player11_l2_btn = "nul"
input_player11_l2_axis = "nul"
input_player11_r2 = "nul"
input_player11_r2_btn = "nul"
input_player11_r2_axis = "nul"
input_player11_l3 = "nul"
input_player11_l3_btn = "nul"
input_player11_l3_axis = "nul"
input_player11_r3 = "nul"
input_player11_r3_btn = "nul"
input_player11_r3_axis = "nul"
input_player11_l_x_plus = "nul"
input_player11_l_x_plus_btn = "nul"
input_player11_l_x_plus_axis = "nul"
input_player11_l_x_minus = "nul"
input_player11_l_x_minus_btn = "nul"
input_player11_l_x_minus_axis = "nul"
input_player11_l_y_plus = "nul"
input_player11_l_y_plus_btn = "nul"
input_player11_l_y_plus_axis = "nul"
input_player11_l_y_minus = "nul"
input_player11_l_y_minus_btn = "nul"
input_player11_l_y_minus_axis = "nul"
input_player11_r_x_plus = "nul"
input_player11_r_x_plus_btn = "nul"
input_player11_r_x_plus_axis = "nul"
input_player11_r_x_minus = "nul"
input_player11_r_x_minus_btn = "nul"
input_player11_r_x_minus_axis = "nul"
input_player11_r_y_plus = "nul"
input_player11_r_y_plus_btn = "nul"
input_player11_r_y_plus_axis = "nul"
input_player11_r_y_minus = "nul"
input_player11_r_y_minus_btn = "nul"
input_player11_r_y_minus_axis = "nul"
input_player11_turbo = "nul"
input_player11_turbo_btn = "nul"
input_player11_turbo_axis = "nul"
input_player12_b = "nul"
input_player12_b_btn = "nul"
input_player12_b_axis = "nul"
input_player12_y = "nul"
input_player12_y_btn = "nul"
input_player12_y_axis = "nul"
input_player12_select = "nul"
input_player12_select_btn = "nul"
input_player12_select_axis = "nul"
input_player12_start = "nul"
input_player12_start_btn = "nul"
input_player12_start_axis = "nul"
input_player12_up = "nul"
input_player12_up_btn = "nul"
input_player12_up_axis = "nul"
input_player12_down = "nul"
input_player12_down_btn = "nul"
input_player12_down_axis = "nul"
input_player12_left = "nul"
input_player12_left_btn = "nul"
input_player12_left_axis = "nul"
input_player12_right = "nul"
input_player12_right_btn = "nul"
input_player12_right_axis = "nul"
input_player12_a = "nul"
input_player12_a_btn = "nul"
input_player12_a_axis = "nul"
input_player12_x = "nul"
input_player12_x_btn = "nul"
input_player12_x_axis = "nul"
input_player12_l = "nul"
input_player12_l_btn = "nul"
input_player12_l_axis = "nul"
input_player12_r = "nul"
input_player12_r_btn = "nul"
input_player12_r_axis = "nul"
input_player12_l2 = "nul"
input_player12_l2_btn = "nul"
input_player12_l2_axis = "nul"
input_player12_r2 = "nul"
input_player12_r2_btn = "nul"
input_player12_r2_axis = "nul"
input_player12_l3 = "nul"
input_player12_l3_btn = "nul"
input_player12_l3_axis = "nul"
input_player12_r3 = "nul"
input_player12_r3_btn = "nul"
input_player12_r3_axis = "nul"
input_player12_l_x_plus = "nul"
input_player12_l_x_plus_btn = "nul"
input_player12_l_x_plus_axis = "nul"
input_player12_l_x_minus = "nul"
input_player12_l_x_minus_btn = "nul"
input_player12_l_x_minus_axis = "nul"
input_player12_l_y_plus = "nul"
input_player12_l_y_plus_btn = "nul"
input_player12_l_y_plus_axis = "nul"
input_player12_l_y_minus = "nul"
input_player12_l_y_minus_btn = "nul"
input_player12_l_y_minus_axis = "nul"
input_player12_r_x_plus = "nul"
input_player12_r_x_plus_btn = "nul"
input_player12_r_x_plus_axis = "nul"
input_player12_r_x_minus = "nul"
input_player12_r_x_minus_btn = "nul"
input_player12_r_x_minus_axis = "nul"
input_player12_r_y_plus = "nul"
input_player12_r_y_plus_btn = "nul"
input_player12_r_y_plus_axis = "nul"
input_player12_r_y_minus = "nul"
input_player12_r_y_minus_btn = "nul"
input_player12_r_y_minus_axis = "nul"
input_player12_turbo = "nul"
input_player12_turbo_btn = "nul"
input_player12_turbo_axis = "nul"
input_player13_b = "nul"
input_player13_b_btn = "nul"
input_player13_b_axis = "nul"
input_player13_y = "nul"
input_player13_y_btn = "nul"
input_player13_y_axis = "nul"
input_player13_select = "nul"
input_player13_select_btn = "nul"
input_player13_select_axis = "nul"
input_player13_start = "nul"
input_player13_start_btn = "nul"
input_player13_start_axis = "nul"
input_player13_up = "nul"
input_player13_up_btn = "nul"
input_player13_up_axis = "nul"
input_player13_down = "nul"
input_player13_down_btn = "nul"
input_player13_down_axis = "nul"
input_player13_left = "nul"
input_player13_left_btn = "nul"
input_player13_left_axis = "nul"
input_player13_right = "nul"
input_player13_right_btn = "nul"
input_player13_right_axis = "nul"
input_player13_a = "nul"
input_player13_a_btn = "nul"
input_player13_a_axis = "nul"
input_player13_x = "nul"
input_player13_x_btn = "nul"
input_player13_x_axis = "nul"
input_player13_l = "nul"
input_player13_l_btn = "nul"
input_player13_l_axis = "nul"
input_player13_r = "nul"
input_player13_r_btn = "nul"
input_player13_r_axis = "nul"
input_player13_l2 = "nul"
input_player13_l2_btn = "nul"
input_player13_l2_axis = "nul"
input_player13_r2 = "nul"
input_player13_r2_btn = "nul"
input_player13_r2_axis = "nul"
input_player13_l3 = "nul"
input_player13_l3_btn = "nul"
input_player13_l3_axis = "nul"
input_player13_r3 = "nul"
input_player13_r3_btn = "nul"
input_player13_r3_axis = "nul"
input_player13_l_x_plus = "nul"
input_player13_l_x_plus_btn = "nul"
input_player13_l_x_plus_axis = "nul"
input_player13_l_x_minus = "nul"
input_player13_l_x_minus_btn = "nul"
input_player13_l_x_minus_axis = "nul"
input_player13_l_y_plus = "nul"
input_player13_l_y_plus_btn = "nul"
input_player13_l_y_plus_axis = "nul"
input_player13_l_y_minus = "nul"
input_player13_l_y_minus_btn = "nul"
input_player13_l_y_minus_axis = "nul"
input_player13_r_x_plus = "nul"
input_player13_r_x_plus_btn = "nul"
input_player13_r_x_plus_axis = "nul"
input_player13_r_x_minus = "nul"
input_player13_r_x_minus_btn = "nul"
input_player13_r_x_minus_axis = "nul"
input_player13_r_y_plus = "nul"
input_player13_r_y_plus_btn = "nul"
input_player13_r_y_plus_axis = "nul"
input_player13_r_y_minus = "nul"
input_player13_r_y_minus_btn = "nul"
input_player13_r_y_minus_axis = "nul"
input_player13_turbo = "nul"
input_player13_turbo_btn = "nul"
input_player13_turbo_axis = "nul"
input_player14_b = "nul"
input_player14_b_btn = "nul"
input_player14_b_axis = "nul"
input_player14_y = "nul"
input_player14_y_btn = "nul"
input_player14_y_axis = "nul"
input_player14_select = "nul"
input_player14_select_btn = "nul"
input_player14_select_axis = "nul"
input_player14_start = "nul"
input_player14_start_btn = "nul"
input_player14_start_axis = "nul"
input_player14_up = "nul"
input_player14_up_btn = "nul"
input_player14_up_axis = "nul"
input_player14_down = "nul"
input_player14_down_btn = "nul"
input_player14_down_axis = "nul"
input_player14_left = "nul"
input_player14_left_btn = "nul"
input_player14_left_axis = "nul"
input_player14_right = "nul"
input_player14_right_btn = "nul"
input_player14_right_axis = "nul"
input_player14_a = "nul"
input_player14_a_btn = "nul"
input_player14_a_axis = "nul"
input_player14_x = "nul"
input_player14_x_btn = "nul"
input_player14_x_axis = "nul"
input_player14_l = "nul"
input_player14_l_btn = "nul"
input_player14_l_axis = "nul"
input_player14_r = "nul"
input_player14_r_btn = "nul"
input_player14_r_axis = "nul"
input_player14_l2 = "nul"
input_player14_l2_btn = "nul"
input_player14_l2_axis = "nul"
input_player14_r2 = "nul"
input_player14_r2_btn = "nul"
input_player14_r2_axis = "nul"
input_player14_l3 = "nul"
input_player14_l3_btn = "nul"
input_player14_l3_axis = "nul"
input_player14_r3 = "nul"
input_player14_r3_btn = "nul"
input_player14_r3_axis = "nul"
input_player14_l_x_plus = "nul"
input_player14_l_x_plus_btn = "nul"
input_player14_l_x_plus_axis = "nul"
input_player14_l_x_minus = "nul"
input_player14_l_x_minus_btn = "nul"
input_player14_l_x_minus_axis = "nul"
input_player14_l_y_plus = "nul"
input_player14_l_y_plus_btn = "nul"
input_player14_l_y_plus_axis = "nul"
input_player14_l_y_minus = "nul"
input_player14_l_y_minus_btn = "nul"
input_player14_l_y_minus_axis = "nul"
input_player14_r_x_plus = "nul"
input_player14_r_x_plus_btn = "nul"
input_player14_r_x_plus_axis = "nul"
input_player14_r_x_minus = "nul"
input_player14_r_x_minus_btn = "nul"
input_player14_r_x_minus_axis = "nul"
input_player14_r_y_plus = "nul"
input_player14_r_y_plus_btn = "nul"
input_player14_r_y_plus_axis = "nul"
input_player14_r_y_minus = "nul"
input_player14_r_y_minus_btn = "nul"
input_player14_r_y_minus_axis = "nul"
input_player14_turbo = "nul"
input_player14_turbo_btn = "nul"
input_player14_turbo_axis = "nul"
input_player15_b = "nul"
input_player15_b_btn = "nul"
input_player15_b_axis = "nul"
input_player15_y = "nul"
input_player15_y_btn = "nul"
input_player15_y_axis = "nul"
input_player15_select = "nul"
input_player15_select_btn = "nul"
input_player15_select_axis = "nul"
input_player15_start = "nul"
input_player15_start_btn = "nul"
input_player15_start_axis = "nul"
input_player15_up = "nul"
input_player15_up_btn = "nul"
input_player15_up_axis = "nul"
input_player15_down = "nul"
input_player15_down_btn = "nul"
input_player15_down_axis = "nul"
input_player15_left = "nul"
input_player15_left_btn = "nul"
input_player15_left_axis = "nul"
input_player15_right = "nul"
input_player15_right_btn = "nul"
input_player15_right_axis = "nul"
input_player15_a = "nul"
input_player15_a_btn = "nul"
input_player15_a_axis = "nul"
input_player15_x = "nul"
input_player15_x_btn = "nul"
input_player15_x_axis = "nul"
input_player15_l = "nul"
input_player15_l_btn = "nul"
input_player15_l_axis = "nul"
input_player15_r = "nul"
input_player15_r_btn = "nul"
input_player15_r_axis = "nul"
input_player15_l2 = "nul"
input_player15_l2_btn = "nul"
input_player15_l2_axis = "nul"
input_player15_r2 = "nul"
input_player15_r2_btn = "nul"
input_player15_r2_axis = "nul"
input_player15_l3 = "nul"
input_player15_l3_btn = "nul"
input_player15_l3_axis = "nul"
input_player15_r3 = "nul"
input_player15_r3_btn = "nul"
input_player15_r3_axis = "nul"
input_player15_l_x_plus = "nul"
input_player15_l_x_plus_btn = "nul"
input_player15_l_x_plus_axis = "nul"
input_player15_l_x_minus = "nul"
input_player15_l_x_minus_btn = "nul"
input_player15_l_x_minus_axis = "nul"
input_player15_l_y_plus = "nul"
input_player15_l_y_plus_btn = "nul"
input_player15_l_y_plus_axis = "nul"
input_player15_l_y_minus = "nul"
input_player15_l_y_minus_btn = "nul"
input_player15_l_y_minus_axis = "nul"
input_player15_r_x_plus = "nul"
input_player15_r_x_plus_btn = "nul"
input_player15_r_x_plus_axis = "nul"
input_player15_r_x_minus = "nul"
input_player15_r_x_minus_btn = "nul"
input_player15_r_x_minus_axis = "nul"
input_player15_r_y_plus = "nul"
input_player15_r_y_plus_btn = "nul"
input_player15_r_y_plus_axis = "nul"
input_player15_r_y_minus = "nul"
input_player15_r_y_minus_btn = "nul"
input_player15_r_y_minus_axis = "nul"
input_player15_turbo = "nul"
input_player15_turbo_btn = "nul"
input_player15_turbo_axis = "nul"
input_player16_b = "nul"
input_player16_b_btn = "nul"
input_player16_b_axis = "nul"
input_player16_y = "nul"
input_player16_y_btn = "nul"
input_player16_y_axis = "nul"
input_player16_select = "nul"
input_player16_select_btn = "nul"
input_player16_select_axis = "nul"
input_player16_start = "nul"
input_player16_start_btn = "nul"
input_player16_start_axis = "nul"
input_player16_up = "nul"
input_player16_up_btn = "nul"
input_player16_up_axis = "nul"
input_player16_down = "nul"
input_player16_down_btn = "nul"
input_player16_down_axis = "nul"
input_player16_left = "nul"
input_player16_left_btn = "nul"
input_player16_left_axis = "nul"
input_player16_right = "nul"
input_player16_right_btn = "nul"
input_player16_right_axis = "nul"
input_player16_a = "nul"
input_player16_a_btn = "nul"
input_player16_a_axis = "nul"
input_player16_x = "nul"
input_player16_x_btn = "nul"
input_player16_x_axis = "nul"
input_player16_l = "nul"
input_player16_l_btn = "nul"
input_player16_l_axis = "nul"
input_player16_r = "nul"
input_player16_r_btn = "nul"
input_player16_r_axis = "nul"
input_player16_l2 = "nul"
input_player16_l2_btn = "nul"
input_player16_l2_axis = "nul"
input_player16_r2 = "nul"
input_player16_r2_btn = "nul"
input_player16_r2_axis = "nul"
input_player16_l3 = "nul"
input_player16_l3_btn = "nul"
input_player16_l3_axis = "nul"
input_player16_r3 = "nul"
input_player16_r3_btn = "nul"
input_player16_r3_axis = "nul"
input_player16_l_x_plus = "nul"
input_player16_l_x_plus_btn = "nul"
input_player16_l_x_plus_axis = "nul"
input_player16_l_x_minus = "nul"
input_player16_l_x_minus_btn = "nul"
input_player16_l_x_minus_axis = "nul"
input_player16_l_y_plus = "nul"
input_player16_l_y_plus_btn = "nul"
input_player16_l_y_plus_axis = "nul"
input_player16_l_y_minus = "nul"
input_player16_l_y_minus_btn = "nul"
input_player16_l_y_minus_axis = "nul"
input_player16_r_x_plus = "nul"
input_player16_r_x_plus_btn = "nul"
input_player16_r_x_plus_axis = "nul"
input_player16_r_x_minus = "nul"
input_player16_r_x_minus_btn = "nul"
input_player16_r_x_minus_axis = "nul"
input_player16_r_y_plus = "nul"
input_player16_r_y_plus_btn = "nul"
input_player16_r_y_plus_axis = "nul"
input_player16_r_y_minus = "nul"
input_player16_r_y_minus_btn = "nul"
input_player16_r_y_minus_axis = "nul"
input_player16_turbo = "nul"
input_player16_turbo_btn = "nul"
input_player16_turbo_axis = "nul"
core_specific_config = "false"
libretro_log_level = "0"
log_verbosity = "false"
perfcnt_enable = "false"
archive_mode = "0"
I have also setup Sega Saturn controls for SSF.
As we know SSF only supports key mapping therefore I needed to use joytokey to map controls to my blissbox.
Below is a copy of my  SSF.ini (goes in the ssf emulator folder).
# CardridgeID
# 00 = none
# 21 = Backup RAM Cartridge
# 5a = 1MBytes RAM Cartridge
# 5c = 4MBytes RAM Cartridge
# Areacode
# 1 = Japan
# 2 = Taiwan, Korea, Philippines
# 4 = America, Canada, Brazil
# c = Europe, Australia, South Africa
[Peripheral]
SaturnBIOS="C:\Hyperspin\Emulators\Sega Saturn\Sega Satun Bioses\Sega Saturn BIOS v1.00 (US).bin"
STVBIOS=""
CDDrive="0"
CartridgeID="5c"
Areacode="4"
DataCartridgeEnable="0"
DataCartridge=""
[Screen]
Scanline="1"
ScanlineRatio="50"
DisableFullscreenScanline="0"
AutoFieldSkip="1"
EnforceAspectRatioWindow="1"
EnforceAspectRatioFullscreen="1"
WideScreen="0"
VSynchWaitWindow="1"
VSynchWaitFullscreen="1"
FixedWindowResolution="1"
FixedFullscreenResolution="0"
BilinearFiltering="1"
StretchScreen="1"
FullSize="1"
FullscreenDisplay="0"
VSynchWait="0"
[Sound]
LinearFiltering="1"
DoublePrecision="0"
Mute="0"
Volume="1.00"
VolumeAdd="0.25"
BufferSize="2"
[Program1]
DisableInput="1"
FlipThread="0"
VDP1DrawThread="0"
VDP1ThreadNumber="1"
VDP1ThreadAlwaysRunning="0"
VDP1Division="1"
VDP2DrawThread="1"
VDP2ThreadNumber="11"
SoundThread="1"
CDBlockThread="0"
CDBlockNoWait="0"
ScanlineBaseTiming="0"
DSPThread="0"
DSPThreadAlwaysRunning="0"
DSPDynamicRecompile="1"
Priority="2"
VDP1ExclusiveCPU="0"
VDP2MultiThread="1"
[Program2]
CDDriveReadSectors="8"
DotClock="2.50"
BlockClock="80"
CheckSlaveSH2IdleLoop="1"
SlaveSH2Speed="90"
SH2RecompileBlockInstructions="40"
CDSectorNumbersPerSecond="150"
SH2RecompileBufferSize="8"
SH2RecompileBlockNumber="40000"
AlternativeSH2Recompile="0"
CheckMemoryAccess="0"
[Program3]
CheckSpritePriority="0"
CheckCyclePattern="1"
VDP2RAMRevisionAccess="1"
VDP2RAMWriteTiming="0"
VDP2RAMWriteTimingBufferSize="24"
MemoryAccessWait="0"
SH2Cache="0"
EnableInstructionCache="0"
BusWait="0"
BusWaitClock="1"
SH2DMARealTransfer="0"
SCUDMADelayInterrupt="0"
CDTrackIndex="0"
BranchInstructionClock="0"
[Program4]
CDAccessLED="1"
NoBIOS="1"
HookBackupLibrary="1"
EnableFDD="0"
MeshTranslucent="0"
Deinterlace="0"
EmulateSpeedAdd="0.50"
68000Type="0"
ShowRegister="0"
EnableCDImage="0"
CDImage=""
[SSFV]
FrameRate="30"
KeyFrameInterval="60"
QuantumLevel="1"
HalfSize="1"
Thread="1"
[SpeedTest]
Enable="0"
Draw="1"
CDBlockNoWait="1"
Time="300"
SingleCPU="0"
[Input]
PortFlag0="0"
PortFlag1="0"
PadType0_0="0"
PadType0_1="5"
PadType0_2="5"
PadType0_3="5"
PadType0_4="5"
PadType0_5="5"
PadType1_0="0"
PadType1_1="5"
PadType1_2="5"
PadType1_3="5"
PadType1_4="5"
PadType1_5="5"
Pad0_0_0="2/200/2/208/2/203/2/205/2/44/2/38/2/45/2/47/2/36/2/37/2/23/2/46/2/35/0/0/0/0/0/0/0/0/0/0/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25"
Pad0_0_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_0_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_0_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_1_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_1_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_1_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_1_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_2_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_2_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_2_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_2_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_3_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_3_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_3_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_3_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_4_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_4_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_4_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_4_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_5_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_5_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_5_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad0_5_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_0_0="2/17/2/31/2/30/2/32/2/16/2/19/2/34/2/24/2/21/2/33/2/20/2/22/2/49/0/0/0/0/0/0/0/0/0/0/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25/2/25"
Pad1_0_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_0_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_0_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_1_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_1_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_1_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_1_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_2_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_2_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_2_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_2_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_3_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_3_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_3_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_3_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_4_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_4_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_4_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_4_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_5_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_5_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_5_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Pad1_5_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid0_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid0_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid0_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid0_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid0_4="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid0_5="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid1_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid1_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid1_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid1_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid1_4="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
Rapid1_5="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
VariableRapid0_0="0"
VariableRapid0_1="0"
VariableRapid0_2="0"
VariableRapid0_3="0"
VariableRapid0_4="0"
VariableRapid0_5="0"
VariableRapid1_0="0"
VariableRapid1_1="0"
VariableRapid1_2="0"
VariableRapid1_3="0"
VariableRapid1_4="0"
VariableRapid1_5="0"
EnableRapid="0"
[Other]
SMEM0="0"
SMEM1="0"
SMEM2="0"
SMEM3="0"
DateFlag="0"
SSDate0="2015"
SSDate1="12"
SSDate2="6"
SSDate3="5"
SSDate4="22"
SSDate5="41"
SSDate6="54"
SSDate7="34"
ScreenMode="1"
WindowSize="2"
WindowX="16"
WindowY="8"
ROMFolder=".\"
Below is a copy of my joytokey mapping.
This goes in RocketLauncher\Profiles\JoyToKey\Sega Saturn\Sega Saturn.cfg
[General]
FileVersion=57
NumberOfJoysticks=2
DisplayMode=2
UseDiagonalInput=0
UsePOV8Way=0
Threshold=20
Threshold2=20
KeySendMode=0
NumberOfButtons=32
SoundFile=
ImageFile=
[Joystick 1]
Axis1n=1, 25:00:00:00, 0.000, 0, 0
Axis1p=1, 27:00:00:00, 0.000, 0, 0
Axis2n=1, 26:00:00:00, 0.000, 0, 0
Axis2p=1, 28:00:00:00, 0.000, 0, 0
Button01=1, 5A:00:00:00, 0.000, 0, 0
Button02=1, 4C:00:00:00, 0.000, 0, 0
Button03=1, 56:00:00:00, 0.000, 0, 0
Button04=1, 4A:00:00:00, 0.000, 0, 0
Button06=1, 48:00:00:00, 0.000, 0, 0
Button07=1, 49:00:00:00, 0.000, 0, 0
Button08=1, 43:00:00:00, 0.000, 0, 0
Button09=1, 4B:00:00:00, 0.000, 0, 0
Button10=1, 58:00:00:00, 0.000, 0, 0
[Joystick 2]
Axis1n=1, 41:00:00:00, 0.000, 0, 0
Axis1p=1, 44:00:00:00, 0.000, 0, 0
Axis2n=1, 57:00:00:00, 0.000, 0, 0
Axis2p=1, 53:00:00:00, 0.000, 0, 0
Button01=1, 51:00:00:00, 0.000, 0, 0
Button02=1, 52:00:00:00, 0.000, 0, 0
Button03=1, 4F:00:00:00, 0.000, 0, 0
Button04=1, 59:00:00:00, 0.000, 0, 0
Button06=1, 4E:00:00:00, 0.000, 0, 0
Button07=1, 54:00:00:00, 0.000, 0, 0
Button08=1, 55:00:00:00, 0.000, 0, 0
Button09=1, 46:00:00:00, 0.000, 0, 0
Button10=1, 47:00:00:00, 0.000, 0, 0
Just thought I would share my files.
fps_show = "false"
audio_sync = "true"
video_driver = "gl"
audio_device = ""
video_filter = ""
camera_device = ""
input_overlay = ""
sound_mode = "0"
state_slot = "0"
user_language = "0"
input_device_p13 = %2
Does it also work with Xbox 360?
Sent from my HTC6535LVW using Tapatalk
How are you connecting up the 360 controller newoski??
Doubt it would work as the button order would be different.
Take the plunge and let me know.
How are people finding compatibility with the NES controllers. I'm finding that I have to constantly press the reset button for 2-3 controllers to register correctly otherwise the "a" button only registers as a direction input. Could be the controllers?? I've ordered another from ebay to test.
Also has anyone had much experience with the current aftermarket nes controllers (non-USB)? I purchased a USB pad about 5 years ago and it was a poor copy. Just wondering what they are like now??
