geopgin Posted November 3, 2015 Posted November 3, 2015 Hey All,  New to hyperspin and have worked through a number of inpedements but have hit an annoyance that I haven't been able to figure out yet. I have HS14 running on windows with a full n64 wheel, however when I copy the hyperspin folder to a usb drive and attach to my shieldtv I have an incomplete wheel, It starts @ 007 but ends at clayfighter 63 1/3, nothin after. The 64 roms launch/work and all the other console wheels are complete. I've yanked off HS and reinstalled but no luck.  I'm sure I'm missing something simple but thought I'd post and get some feedback. Any help would be appreciated.
geopgin Posted November 3, 2015 Author Posted November 3, 2015 As far as I know, looks right and on windows same DB works fine. Its possible there's a character that droid doesn't like. Will take a closer look this evening. Any other ideas?
geopgin Posted November 4, 2015 Author Posted November 4, 2015 There ended it being a issue with the DB, not sure why it worked in windows. I used an xml validator and it turned out that there was an open ended entity..an ampersand (&) without the terminator (
kllngtme Posted November 16, 2015 Posted November 16, 2015 There ended it being a issue with the DB, not sure why it worked in windows. I used an xml validator and it turned out that there was an open ended entity..an ampersand (&) without the terminator ( Well, I guess we are using the same DB file from the hyperspin project torrent... I had the same problem! Stupid Clay Fighter 63 & 1/3... the description only had &, instead of &  Couldn't figure it out for a while.
geopgin Posted November 21, 2015 Author Posted November 21, 2015 @kllngtme  Clayfighters was the first but not the last, I grepped all of the db's and description elements wasn't the only culprit. I also found a bunch in <manufacturer>Â
