Konamito Posted November 7, 2015 Posted November 7, 2015 Just a dumb question, maybe, but how do I set Disk B when using Famicom Disk System with RetroArch emulator? MSXBlog Tenerife Go Retro
phulshof Posted November 7, 2015 Posted November 7, 2015 Which core is it using? Under MAME (MESS) you can simply press SPACE (button 3) if you use the famitwin console.
Konamito Posted November 7, 2015 Author Posted November 7, 2015 Which core is it using? Under MAME (MESS) you can simply press SPACE (button 3) if you use the famitwin console. I'm using fceumm_libretro core. I've defined "l" as Eject_Toggle_Key in Module settings but it doesn't work... If I remember correctly, you press "Q" Nope, this one does not work for me... MSXBlog Tenerife Go Retro
Awakened Posted November 8, 2015 Posted November 8, 2015 In the Nestopia core it's whatever you bind your L button to. input_player1_l_btn in your cfg. I would think it'd be the same in FCEUmm, but I never use that core since it's less accurate.
Styphelus Posted November 10, 2015 Posted November 10, 2015 Sorry. It's not "Q" - it's "W" if you are using retroarch and nestopia (i was close) I just checked. If you use the Nestopia core, the default key is "W" When the message pops up, just press "W" and wait a little bit. it will change disk. it's a bit slow.
Konamito Posted November 10, 2015 Author Posted November 10, 2015 At the end I did it with Nestopia emulator itself. The default ky for Disk side change is H. My nestopia module in RetroArch wasn't capable of loading any game... Thanks for your help! MSXBlog Tenerife Go Retro
Awakened Posted November 11, 2015 Posted November 11, 2015 The Nestopia core needs disksys.rom in your RetroArch system directory for FDS games.
