rastan Posted November 27, 2015 Posted November 27, 2015 I never did it before so I'm a bit unsure how to actually do it... I know you have to actually add the new emulator in the Emulator setting by clicking the magnify glass and searching for the emulator .exe file (I got that part) but I get confused when it comes to selecting the module... when I click to add the module the list empty. I want to add MAME as the emulator but not sure what to do after I add the emulator... any guides? or suggestions?
Yeuxkes Posted November 27, 2015 Posted November 27, 2015 Better post this to RocketLauncher forum. Although they come visit these forums sometimes, this is clearly a RocketLauncher related issue.
rastan Posted November 28, 2015 Author Posted November 28, 2015 Figured it out... just added "Technos Aracde" to the Mame.ahk
Metalzoic Posted November 28, 2015 Posted November 28, 2015 Technos arcade? When you say you're adding the emulator do you mean you're actually adding it as a system (like Technos Classics) and using MAME as the emulator? How many games do they have in the XML (I'm guessing you decided to try out Dons tools)?
rastan Posted November 28, 2015 Author Posted November 28, 2015 Yeah, just adding it as a system and using MAME as the emulator.. but I didn't know I had to add the system name to the .ahk if it wasn't already included.. I thought I had to actually go thru the entire process of clicking the magnify glass and adding mame again, etc. didn't realize it was as simple as adding the system name to the MAME.AHK, one of the reasons I like using Hyperspin and the fact that I started mines from scratch... I got to learn a lot about how HS actually works underneath the hood. Definitely gonna give DON's list splitter a try when I get a chance.. would be nice to build some custom XML's... I just downloaded the XML from Hyperspin's downloads. http://www.hyperspin-fe.com/files/file/10350-technos-arcade-database-xml/ Basically Technos classics... I scrolled thru the games and to be honest I didn't see any reason to have a separate wheel just for them... I'll just play them from the MAME wheel.
Metalzoic Posted November 28, 2015 Posted November 28, 2015 I do it the opposite. Instead of adding the system to MAME.ahk I add Emulator=MAME to the system ini. I never even tried doing it your way (which is probably better). I'll go check Dons to see how many games exist for Technos. What else is worth checking? Gaeleco? Sammy? Stern? Sega... I just realized they probably have a ton of non-model 2, 3, Naomi etc... games. EDIT: Technos looks like 71 games and some classics. DDragon, Combatribes, Dodge Ball etc... Worth a Wheel for me if I had a Main Menu theme.
