Atari 5200 wont work? 2600 and 7800 do.
demonseed
Hey guys
I got atari 2600 and 7800 running easily with retrorarch... however 5200 wont run? I run a game and it just stays on HS.  In RL all games show fine etc.....any suggestions?
[code]
22:06:32:220 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com)
22:06:32:230 | RL |  WARNING  | +16    | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
22:06:32:540 | RL |     INFO  | +312   | Main - System Specs:
					RocketLauncher Dir: E:\Rocketlauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8016.31 MB
					Free Memory: 3591.66 MB
					Used Memory: 4424.656 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: Intel(R) HD Graphics
					GPU 1 RAM: -1924.00 MB
					GPU 1 Driver Version: 9.17.10.3347
					Sound 1 Device: High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: High Definition Audio Device
					Sound 2 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x856 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe
					AHK Version: 1.1.09.04
					Unicode: No
22:06:32:550 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists
22:06:32:550 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.4
					LegalCopyright          	©2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2063360 bytes
					Created:			5/23/2015 - 10:53:13 PM
					Modified:			11/26/2015 - 12:43:10 AM
22:06:32:560 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Array.ahk exists
22:06:32:570 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:580 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			4924 bytes
					Created:			11/26/2015 - 12:43:11 AM
					Modified:			11/26/2015 - 12:43:11 AM
22:06:32:580 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists
22:06:32:590 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:590 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5077 bytes
					Created:			5/24/2015 - 8:27:48 AM
					Modified:			11/26/2015 - 12:42:57 AM
22:06:32:590 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists
22:06:32:610 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Created:			5/24/2015 - 8:26:42 AM
					Modified:			1/2/2014 - 10:27:34 PM
22:06:32:610 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR_L.ahk exists
22:06:32:620 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:620 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Created:			9/6/2015 - 8:32:14 PM
					Modified:			9/6/2015 - 8:32:14 PM
22:06:32:630 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists
22:06:32:630 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:640 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
					Created:			5/24/2015 - 8:26:30 AM
					Modified:			4/29/2013 - 1:56:02 PM
22:06:32:640 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists
22:06:32:640 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:650 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			88789 bytes
					Created:			5/24/2015 - 7:02:39 AM
					Modified:			1/13/2013 - 5:07:30 PM
22:06:32:650 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists
22:06:32:660 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:660 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5895 bytes
					Created:			5/24/2015 - 8:25:59 AM
					Modified:			6/28/2015 - 6:41:33 AM
22:06:32:670 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
22:06:32:670 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists
22:06:32:690 | RL |   DEBUG1  | +32    | CheckFile - Attributes:
					File Size:			13090816 bytes
					Created:			5/24/2015 - 8:25:19 AM
					Modified:			1/6/2015 - 9:20:42 PM
22:06:32:690 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists
22:06:32:720 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			5/24/2015 - 8:24:07 AM
					Modified:			6/14/2013 - 2:06:21 PM
22:06:32:730 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists
22:06:32:730 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:730 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
					Created:			5/24/2015 - 8:27:37 AM
					Modified:			12/23/2014 - 11:02:37 PM
22:06:32:740 | RL |   DEBUG1  | +15    | Java.ahk Version: 1.0.0
22:06:32:740 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists
22:06:32:740 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:750 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			9203 bytes
					Created:			5/24/2015 - 8:26:08 AM
					Modified:			5/5/2013 - 2:22:25 PM
22:06:32:750 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists
22:06:32:760 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:770 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			4904 bytes
					Created:			5/24/2015 - 8:26:27 AM
					Modified:			3/22/2015 - 2:51:41 PM
22:06:32:770 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
22:06:32:770 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists
22:06:32:780 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:780 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
					Created:			5/24/2015 - 8:28:09 AM
					Modified:			5/8/2014 - 3:06:39 AM
22:06:32:780 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists
22:06:32:790 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:790 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
					Created:			5/24/2015 - 8:28:04 AM
					Modified:			6/5/2013 - 6:56:23 PM
22:06:32:800 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists
22:06:32:820 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.5717.6837
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.5717.6837
					CompanyName             	Markovtsev Vadim
					File Size:			167424 bytes
					Created:			5/24/2015 - 8:27:30 AM
					Modified:			11/26/2015 - 12:43:04 AM
22:06:32:820 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists
22:06:32:830 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:840 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5347 bytes
					Created:			5/24/2015 - 8:28:20 AM
					Modified:			3/22/2015 - 2:52:25 PM
22:06:32:840 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
22:06:32:840 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists
22:06:32:850 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
22:06:32:850 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
					Created:			5/24/2015 - 8:26:53 AM
					Modified:			3/1/2013 - 9:05:47 PM
22:06:32:860 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists
22:06:32:880 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:880 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Created:			5/24/2015 - 8:28:38 AM
					Modified:			1/13/2015 - 8:16:56 PM
22:06:32:890 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
22:06:32:890 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists
22:06:32:900 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:910 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			29149 bytes
					Created:			5/29/2015 - 11:47:30 PM
					Modified:			11/26/2015 - 12:42:55 AM
22:06:32:920 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.2
22:06:32:920 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists
22:06:32:950 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:960 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			104277 bytes
					Created:			5/24/2015 - 8:28:01 AM
22:06:32:960 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.7
22:06:32:960 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists
22:06:32:980 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:32:990 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			38251 bytes
					Created:			5/24/2015 - 8:26:50 AM
					Modified:			11/26/2015 - 12:43:06 AM
22:06:32:990 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.4
22:06:32:990 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists
22:06:32:000 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:000 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1065 bytes
					Created:			5/24/2015 - 8:27:38 AM
					Modified:			11/26/2015 - 12:43:12 AM
22:06:33:000 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.2
22:06:33:010 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists
22:06:33:010 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:020 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			81174 bytes
					Created:			5/24/2015 - 8:27:41 AM
22:06:33:040 | RL |   DEBUG1  | +16    | Fade Animations.ahk Version: 1.1.10
22:06:33:040 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists
22:06:33:050 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:060 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Created:			5/24/2015 - 8:28:11 AM
					Modified:			5/30/2015 - 9:18:27 PM
22:06:33:060 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
22:06:33:060 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists
22:06:33:070 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:070 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
					Created:			5/24/2015 - 8:26:35 AM
					Modified:			5/30/2015 - 9:18:57 PM
22:06:33:080 | RL |   DEBUG1  | +16    | Keymapper Init.ahk Version: 1.0.4
22:06:33:080 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists
22:06:33:100 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:100 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			40753 bytes
					Created:			5/24/2015 - 8:24:03 AM
					Modified:			9/6/2015 - 8:32:13 PM
22:06:33:110 | RL |   DEBUG1  | +16    | MultiGame.ahk Version: 1.0.8
22:06:33:110 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists
22:06:33:110 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:120 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
					Created:			5/24/2015 - 8:28:32 AM
					Modified:			4/14/2013 - 1:33:19 PM
22:06:33:120 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
22:06:33:120 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists
22:06:33:140 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:150 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			66452 bytes
					Created:			5/24/2015 - 8:23:41 AM
					Modified:			11/26/2015 - 12:42:52 AM
22:06:33:160 | RL |   DEBUG1  | +16    | MultiPlayer.ahk Version: 1.0.7
22:06:33:160 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists
22:06:33:260 | RL |   DEBUG1  | +93    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:260 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392193 bytes
					Created:			5/24/2015 - 8:26:19 AM
					Modified:			11/26/2015 - 12:43:03 AM
22:06:33:270 | RL |   DEBUG1  | +16    | Pause.ahk Version: 1.1.5
22:06:33:270 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists
22:06:33:270 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:280 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			553 bytes
					Created:			5/24/2015 - 8:24:21 AM
					Modified:			9/6/2015 - 8:31:51 PM
22:06:33:280 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
22:06:33:280 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists
22:06:33:290 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:300 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			10025 bytes
					Created:			5/24/2015 - 8:24:18 AM
					Modified:			9/6/2015 - 8:31:55 PM
22:06:33:300 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
22:06:33:300 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists
22:06:33:350 | RL |   DEBUG1  | +47    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:350 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			74101 bytes
					Modified:			11/26/2015 - 12:42:54 AM
22:06:33:350 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.6
22:06:33:350 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists
22:06:33:360 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:370 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			139893 bytes
					Modified:			11/26/2015 - 12:43:02 AM
22:06:33:370 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.5
22:06:33:370 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists
22:06:33:380 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:380 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26143 bytes
					Created:			5/24/2015 - 8:26:45 AM
					Modified:			4/9/2015 - 4:16:56 AM
22:06:33:390 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
22:06:33:390 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists
22:06:33:390 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:400 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			33 bytes
					Modified:			12/23/2014 - 11:23:48 PM
22:06:33:400 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
22:06:33:400 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists
22:06:33:410 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:410 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			18329 bytes
					Created:			5/29/2015 - 11:47:33 PM
					Modified:			11/26/2015 - 12:42:58 AM
22:06:33:420 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.3
22:06:33:420 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists
22:06:33:440 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:440 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26540 bytes
					Created:			5/24/2015 - 8:28:26 AM
					Modified:			9/6/2015 - 8:32:04 PM
22:06:33:450 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
22:06:33:450 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists
22:06:33:470 | RL |   DEBUG1  | +32    | CRC Check - CRC matches, this is an official unedited Library.
22:06:33:470 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1063 bytes
					Created:			5/24/2015 - 8:26:46 AM
					Modified:			9/6/2015 - 8:31:50 PM
22:06:33:480 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
22:06:33:490 | RL |   DEBUG1  | +15    | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: E:\Hyperspin\HyperSpin.exe
22:06:33:490 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "Atari 5200 Space Dungeon (USA)"
22:06:33:490 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "Space Dungeon (USA)"
22:06:33:500 | RL |   DEBUG1  | +16    | Main - dbName: Space Dungeon (USA)
22:06:33:500 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
22:06:33:500 | RL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1440 h900
22:06:33:500 | RL |     INFO  | +0     | Main - RocketLauncher received "Atari 5200" and "Space Dungeon (USA)"
22:06:33:520 | RL |     INFO  | +15    | Main - Did not find a "E:\Rocketlauncher\Settings\Atari 5200\Game Options.ini" file, skipping any game-specific options.
22:06:33:530 | RL |     INFO  | +0     | Main - Space Dungeon (USA) is using the default emulator: RetroArch
22:06:33:530 | RL |     INFO  | +0     | Main - Checking for a [RetroArch] section in E:\Rocketlauncher\Settings\Atari 5200\Emulators.ini
22:06:33:530 | RL |     INFO  | +0     | Main - Checking for a [RetroArch] section in E:\Rocketlauncher\Settings\Global Emulators.ini
22:06:33:540 | RL |     INFO  | +16    | Main - Found [RetroArch] in E:\Rocketlauncher\Settings\Global Emulators.ini
22:06:33:540 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Modules\RetroArch\RetroArch.ahk exists
22:06:33:540 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			45403 bytes
					Created:			5/24/2015 - 8:28:10 AM
22:06:33:560 | RL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
22:06:33:570 | RL |     INFO  | +15    | Main - Space Dungeon (USA) will use module: E:\Rocketlauncher\Modules\RetroArch\RetroArch.ahk
22:06:33:600 | RL |     INFO  | +31    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
22:06:33:600 | RL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\Retroarch\retroarch.exe exists
22:06:33:610 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			1655808 bytes
					Created:			8/16/2015 - 9:32:24 AM
					Modified:			7/19/2015 - 12:21:23 AM
22:06:33:610 | RL |     INFO  | +0     | Main - INI Keys read
22:06:33:620 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists
22:06:33:620 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	15.06 beta
					InternalName            	7z
					LegalCopyright          	Copyright (c) 1999-2015 Igor Pavlov
					ProductVersion          	15.06 beta
					File Size:			262144 bytes
					Created:			5/24/2015 - 8:26:40 AM
					Modified:			11/26/2015 - 12:42:56 AM
22:06:33:630 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists
22:06:33:630 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	7z Plugin
					InternalName            	7z
					OriginalFilename        	7z.dll
					File Size:			1012224 bytes
					Created:			5/24/2015 - 8:28:28 AM
					Modified:			11/26/2015 - 12:43:05 AM
22:06:33:640 | RL |     INFO  | +15    | Main - "Space Dungeon (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
22:06:33:650 | RL |     INFO  | +0     | CheckPaths - Started
22:06:33:650 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200\Space Dungeon (USA).7z
22:06:33:660 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200\Space Dungeon (USA)\Space Dungeon (USA).7z
22:06:33:660 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
22:06:33:660 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200\Space Dungeon (USA).zip
22:06:33:660 | RL |     INFO  | +0     | CheckPaths - Found rom: E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200\Space Dungeon (USA).zip
22:06:33:660 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: Space Dungeon (USA)
22:06:33:670 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200
22:06:33:670 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
22:06:33:670 | RL |     INFO  | +0     | CheckPaths - Ended
22:06:33:670 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 2
					pluginPath = E:\Rocketlauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit =
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.4
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = E:\Rocketlauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID = 1820
					frontendPath = E:\Hyperspin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = E:
					exitEmulatorKey = ~Esc|H3:1joy6
					restoreFE = Restore and Click
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = E:\Hyperspin\Emulators\Retroarch\retroarch.exe
					emuPath = E:\Hyperspin\Emulators\Retroarch
					emuName = RetroArch
					emuExt = exe
					romPath = E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200
					romPathFromIni = E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = 7z|zip|sfc|gba|gb|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|cue|iso|ccd|chd|bin|rar|iso|cue|cso|img
					executable = retroarch.exe
					systemDbName = Atari 5200
					systemName = Atari 5200
					dbPath =
					dbName = Space Dungeon (USA)
					dbExt =
					romName = Space Dungeon (USA)
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = E:\Rocketlauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = true
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = true
					rlDebugConsoleStdout = 7
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = 1
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath =
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutTransitionAnimation = LegacyFadeOutTransition
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 5
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = true
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = false
					fadeImgPath = E:\Rocketlauncher\Media\Fade
					RLDataPath = E:\Rocketlauncher\Data
					RLMediaPath = E:\Rocketlauncher\Media
					RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error
					modulesPath = E:\Rocketlauncher\Modules
					moduleFullName = E:\Rocketlauncher\Modules\RetroArch\RetroArch.ahk
					moduleName = RetroArch
					modulePath = E:\Rocketlauncher\Modules\RetroArch
					moduleExtension = ahk
					moduleExtensionsPath = E:\Rocketlauncher\Module Extensions
					libPath = E:\Rocketlauncher\Lib
					7zEnabled = true
					7zPath = E:\Rocketlauncher\Module Extensions\7z.exe
					7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = false
					pauseKey = m
					pauseBackToMenuBarKey = n
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = true
					keymapperAHKMethod = External
					keymapper = xpadder
					xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe
					joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
					keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder
					keymapperFrontEndProfileName = RocketLauncherUI
					keymapperFrontEndProfile = xpadder
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = true
					joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI
					defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default
					systemProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200
					xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default
					emuProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200\RetroArch
					romProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Space Dungeon (USA)
					RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher
					blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI
					ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default
					ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\Atari 5200
					ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\Atari 5200\RetroArch
					ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\Atari 5200\Space Dungeon (USA)
					ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini
22:06:33:690 | RL |     INFO  | +31    | BuildScript - Loaded XHotkey Init.ahk scripts
22:06:33:711 | RL |     INFO  | +16    | BuildScript - Loaded Keymapper Init.ahk scripts
22:06:33:731 | RL |     INFO  | +15    | BuildScript - Loaded Statistics Init.ahk scripts
22:06:33:731 | RL |  WARNING  | +0     | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found
22:06:33:731 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
22:06:33:741 | RL |     INFO  | +16    | BuildScript - Validating module
22:06:33:741 | RL |     INFO  | +0     | BuildScript - Validation complete
22:06:33:751 | RL |     INFO  | +15    | BuildScript - Module:
					MEmu = RetroArch
					MEmuV =  v05-11-2015 Nightly
					MURL = http://themaister.net/retroarch.html
					MAuthor = djvj,zerojay
					MVersion = 2.3.3
					MCRC = A2F3BE90
					iCRC = 42C3B552
					MID = 635038268922229162
					MSystem = "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System 2","Capcom Play System 3","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
					; Notes:
					; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working!
					; Devs stated they will never add support for mounted images (like via DT)
					; Fullscreen is controlled via the module setting in RocketLauncherUI
					; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe).
					; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect
					; Enable 7z support for archived roms
					; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1
					; LibRetro DLLs:
					; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/
					; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system.
					; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores
					; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270
					; SRM files:
					; srm are stored in a "srm" dir in the emu folder. Each system ran through retroarch gets its own folder inside srm
					; Save states:
					; Save states are stored in a "save" dir in the emu folder. Each system ran through retroarch gets its own folder inside save
					; Config files:
					; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI.
					; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg).
					; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg
					; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg.
					; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config.
					; MultiGame:
					; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch.
					; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind.
					; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12.
					; MESS:
					; MESS BIOS roms should be placed in the system\mess folder
					; System Specific Notes:
					; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine.
					; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these.
					; NEC TurboGrafx-CD - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode.
					; MAME: The nag screen patch has been removed from the MAME core as of some point in March. We will be investigating our options for this. For MAME-based systems, make sure to set 7z use to false as MAME needs zip files.
					; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory.
					StartModule()
					BezelGUI()
					FadeInStart()
					; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
					; 1 - Official System Name in RocketLauncher
					; 2 - Short name used only for easy referencing within module
					; 3 - Default core
					; 4 - The system ID MESS core recognizes
					Log("Module - Started building the " . MEmu . " object",4)
					mTypeVar=
						( LTrim
						AAE|LibRetro_AAE|mame_libretro
						Acorn BBC Micro|LibRetro_BBCB|mess_libretro|bbcb
						Amstrad CPC|LibRetro_CPC|mess_libretro|cpc464
						Amstrad GX4000|LibRetro_GX4K|mess_libretro|gx4000
						APF Imagination Machine|LibRetro_APF|mess_libretro|apfimag
						Apple IIGS|LibRetro_AIIGS|mess_libretro|apple2gs
						Applied Technology MicroBee|LibRetro_MBEE|mess_libretro|mbeeic
						Atari 2600|LibRetro_2600|stella_libretro|a2600
						Atari 5200|LibRetro_5200|mess_libretro|a5200
						Atari 7800|LibRetro_7800|prosystem_libretro|a7800
						Atari 8-Bit|LibRetro_ATARI8|mess_libretro|a800
						Atari Classics|LibRetro_ACLS|mame_libretro
						Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar
						Atari Lynx|LibRetro_LYNX|handy_libretro|lynx
						Atari ST|LibRetro_ST|hatari_libretro
						Atari XEGS|LibRetro_XEGS|mess_libretro|xegs
						Bally Astrocade|LibRetro_BAST|mess_libretro|astrocde
						Bandai Gundam RX-78|LibRetro_BGRX|mess_libretro|rx78
						Bandai Super Vision 8000|LibRetro_SV8K|mess_libretro|sv8000
						Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan
						Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor
						Canon X07|LibRetro_CX07|mess_libretro|x07
						Capcom Classics|LibRetro_CAPC|mame_libretro
						Capcom Play System|LibRetro_CPS1|fba_cores_cps1_libretro
						Capcom Play System 2|LibRetro_CPS2|fba_cores_cps2_libretro
						Capcom Play System 3|LibRetro_CPS3|mame_libretro
						Casio PV-1000|LibRetro_CAS1K|mess_libretro|pv1000
						Casio PV-2000|LibRetro_CAS2K|mess_libretro|pv2000
						Cave|LibRetro_CAVE|mame_libretro
						Coleco ADAM|LibRetro_ADAM|mess_libretro|adam
						ColecoVision|LibRetro_COLEC|mess_libretro|coleco
						Commodore Amiga|LibRetro_PUAE|puae_libretro
						Commodore Max Machine|LibRetro_CMAX|mess_libretro|vic10
						Creatronic Mega Duck|LibRetro_DUCK|mess_libretro|megaduck
						Data East Classics|LibRetro_DATA|mame_libretro
						Dragon Data Dragon|LibRetro_DRAG64|mess_libretro|dragon64
						Elektronika BK|LibRetro_EBK|mess_libretro|bk0010
						Elektronska Industrija Pecom 64|LibRetro_P64|mess_libretro|pecom64
						Emerson Arcadia 2001|LibRetro_A2001|mess_libretro|arcadia
						Entex Adventure Vision|LibRetro_AVISION|mess_libretro|advision
						Epoch Game Pocket Computer|LibRetro_GPCKET|mess_libretro|gamepock
						Epoch Super Cassette Vision|LibRetro_SCV|mess_libretro|scv
						Exidy Sorcerer|LibRetro_SORCR|mess_libretro|sorcerer
						Fairchild Channel F|LibRetro_CHANF|mess_libretro|channelf
						Final Burn Alpha|LibRetro_FBA|fb_alpha_libretro
						Funtech Super Acan|LibRetro_SACAN|mess_libretro|supracan
						GamePark 32|LibRetro_GP32|mess_libretro|gp32
						GCE Vectrex|LibRetro_VECTX|mess_libretro|vectrex
						Hartung Game Master|LibRetro_GMASTR|mess_libretro|gmaster
						Interton VC 4000|LibRetro_VC4K|mess_libretro|vc4000
						Irem Classics|LibRetro_IREM|mame_libretro
						JungleTac Sport Vii|LibRetro_SPORTV|mess_libretro|vii
						Konami Classics|LibRetro_KONC|mame_libretro
						Magnavox Odyssey 2|LibRetro_ODYS2|mess_libretro|odyssey2
						MAME|LibRetro_MAME|mame_libretro
						Matra & Hachette Alice|LibRetro_ALICE|mess_libretro|alice32
						Mattel Aquarius|LibRetro_AQUA|mess_libretro|aquarius
						Mattel Intellivision|LibRetro_INTV|mess_libretro|intv
						MGT Sam Coupe|LibRetro_SAMCP|mess_libretro|
						Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro
						Microsoft MSX|LibRetro_MSX|bluemsx_libretro
						Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro
						Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro
						Midway Classics|LibRetro_MIDC|mame_libretro
						Namco Classics|LibRetro_NAMC|mame_libretro
						Namco System 22|LibRetro_NAM2|mame_libretro
						NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce
						NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce
						NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro
						NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx
						NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16
						NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16
						Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64
						Nintendo 64DD|LibRetro_N64|mupen64plus_libretro
						Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro
						Nintendo Classics|LibRetro_NINC|mame_libretro
						Nintendo DS|LibRetro_DS|desmume_libretro
						Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes
						Nintendo Famicom|LibRetro_NFAM|nestopia_libretro
						Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom
						Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy
						Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba
						Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor
						Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy
						Nintendo Game & Watch|LibRetro_GW|gw_libretro
						Nintendo Pokemon Mini|LibRetro_POKE|mess_libretro|pokemini
						Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro
						Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro
						Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro
						Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro
						Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy
						Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro
						Panasonic 3DO|LibRetro_3DO|4do_libretro
						Philips CD-i|LibRetro_CDI|mess_libretro|cdimono1
						Philips Videopac|LibRetro_PVID|mess_libretro|videopac
						RCA Studio II|LibRetro_STUD2|mess_libretro|studio2
						SCUMMVM|LibRetro_SCUMM|scummvm_libretro
						Sega 32X|LibRetro_32X|picodrive_libretro|32x
						Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd
						Sega Classics|LibRetro_SEGC|mame_libretro
						Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear
						Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis
						Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro
						Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms
						Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv
						Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro
						Sega Pico|LibRetro_PICO|picodrive_libretro
						Sega Saturn|LibRetro_SAT|yabause_libretro
						Sega Saturn Japan|LibRetro_SAT|yabause_libretro
						Sega SC-3000|LibRetro_SC3K|mess_libretro|sc3000
						Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro
						Sega ST-V|LibRetro_STV|mame_libretro
						Sega VMU|LibRetro_SVMU|mess_libretro|svmu
						Sharp X1|LibRetro_SX1|mess_libretro|x1
						Sinclair ZX Spectrum|LibRetro_SPECZX|mess_libretro|spectrum
						SNK Classics|LibRetro_SNKC|mame_libretro
						SNK Neo Geo|LibRetro_NEO|fb_alpha_libretro
						SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes
						SNK Neo Geo CD|LibRetro_NEOCD|mess_libretro|neocdz
						SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro
						SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp
						SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc
						Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psx
						Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro
						Sony PocketStation|LibRetro_POCKS|mess_libretro|pockstat
						Sony PSP|LibRetro_PSP|ppsspp_libretro
						Sord M5|LibRetro_SORD|mess_libretro|m5
						Spectravideo|LibRetro_SV328|mess_libretro|svi328n
						Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes
						Taito Classics|LibRetro_TAIC|mame_libretro
						Tandy TRS-80 Color Computer|LibRetro_TRS80|mess_libretro|coco3
						Technos|LibRetro_TECHN|mame_libretro
						Texas Instruments TI 99-4A|LibRetro_TI99|mess_libretro|ti99_4a
						Thomson MO5|LibRetro_MO5|mess_libretro|mo5
						Thomson TO7|LibRetro_TO7|mess_libretro|to7
						Tiger Game.com|LibRetro_TCOM|mess_libretro|gamecom
						Tiki-100|LibRetro_TIKI|mess_libretro|kontiki
						Tomy Tutor|LibRetro_TOMY|mess_libretro|tutor
						VTech CreatiVision|LibRetro_VTECH|mess_libretro|crvision
						Watara Supervision|LibRetro_SUPRV|mess_libretro|svision
						Williams Classics|LibRetro_WILLS|mame_libretro
					mType := Object()
					Loop, Parse, mTypeVar, `n, `r
						obj := {}
						Loop, Parse, A_LoopField, |
							If A_Index = 1
								obj.System := A_LoopField
							Else If A_Index = 2
								obj.ID := A_LoopField
							Else If A_Index = 3
								obj.Core := A_LoopField
							Else	; 4
								obj.MessID := A_LoopField
						mType.Insert(obj["System"], obj)
					Log("Module - Finished building the " . MEmu . " object",4)
					; For easier use throughout the module
					retroSystem := mType[systemName].System
					retroID := mType[systemName].ID
					retroCore := mType[systemName].Core
					retroMessID := mType[systemName].MessID
					If !retroSystem
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName)
					If !retroCore
						ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.")
					core := IniReadCheck(settingsFile, systemName, "LibRetro_Core",retroCore,,1)
					configFolder := IniReadCheck(settingsFile, "Settings", "ConfigFolder",emuPath . "\config",,1)
					messRomPath := IniReadCheck(settingsFile, "Settings", "MESS_BIOS_Roms_Folder",,,1)
					hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)
					ejectToggleKey := IniReadCheck(settingsFile, "Settings", "Eject_Toggle_Key",,,1)
					nextDiskKey := IniReadCheck(settingsFile, "Settings", "Next_Disk_Key",,,1)
					prevDiskKey := IniReadCheck(settingsFile, "Settings", "Previous_Disk_Key",,,1)
					superGB := IniReadCheck(settingsFile, systemName . "|" . romName, "SuperGameBoy","false",,1)
					enableNetworkPlay := IniReadCheck(settingsFile, "Network|" . romName, "Enable_Network_Play","false",,1)
					overlay := IniReadCheck(settingsFile, systemName . "|" . romName, "Overlay",,,1)
					videoShader := IniReadCheck(settingsFile, systemName . "|" . romName, "VideoShader",,,1)
					aspectRatioIndex := IniReadCheck(settingsFile, systemName . "|" . romName, "AspectRatioIndex",,,1)
					customViewportWidth := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportWidth",,,1)
					customViewportHeight := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportHeight",,,1)
					customViewportX := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportX",,,1)
					customViewportY := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportY",,,1)
					stretchToFillBezel := IniReadCheck(settingsFile, systemName . "|" . romName, "StretchToFillBezel","false",,1)
					rotation := IniReadCheck(settingsFile, systemName . "|" . romName, "Rotation",0,,1)
					cropOverscan := IniReadCheck(settingsFile, systemName . "|" . romName, "CropOverscan",,,1)
					threadedVideo := IniReadCheck(settingsFile, systemName . "|" . romName, "ThreadedVideo",,,1)
					vSync := IniReadCheck(settingsFile, systemName . "|" . romName, "VSync",,,1)
					integerScale := IniReadCheck(settingsFile, systemName . "|" . romName, "IntegerScale",,,1)
					configurationPerCore := IniReadCheck(settingsFile, systemName . "|" . romName, "ConfigurationPerCore","false",,1)
					configFolder := GetFullName(configFolder)
					messRomPath := GetFullName(messRomPath)
					overlay := GetFullName(overlay)
					videoShader := GetFullName(videoShader)
					rotateBezel := false
					If (retroID = "LibRetro_SGB" || superGB = "true")	; if system or rom is set to use Super Game Boy
					{	superGB = true	; setting this just in case it's false and the system is Nintendo Super Game Boy
						sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system")
						CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system")
						retroID := "LibRetro_SGB"	; switching to Super Game Boy mode
						retroSystem := "Nintendo Super Game Boy"
					; Find the dll for this system
					libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll")
					; Find the cfg file to use
					If !FileExist(configFolder)
						ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder . """")
					globalRetroCfg := emuPath . "\retroarch.cfg"
					systemRetroCfg := configFolder . "\" . retroSystem . ".cfg"
					coreRetroCfg := configFolder . "\" . core . ".dll.cfg"
					Log("Module - Global cfg should be: " . globalRetroCfg,4)
					Log("Module - System cfg should be: " . systemRetroCfg,4)
					Log("Module - Core cfg should be: " . coreRetroCfg,4)
					foundCfg :=
					If FileExist(systemRetroCfg) {	; check for system cfg first
						retroCFGFile := systemRetroCfg
						foundCfg := 1
						Log("Module - Found a System cfg!",4)
					} Else If FileExist(coreRetroCfg) {	; 2nd option is a core config
						retroCFGFile := coreRetroCfg
						foundCfg := 1
						Log("Module - Found a Core cfg!",4)
					} Else If FileExist(globalRetroCfg) {	; 3rd is global cfg
						retroCFGFile := globalRetroCfg
						foundCfg := 1
						Log("Module - Found a Global cfg!",4)
					If !foundCfg
						Log("Module - Could not find a cfg file to update settings. RetroArch will make one for you.",2)
					Else {
						Log("Module - " . MEmu . " is using " . retroCFGFile . " as its config file.")
						retroCFG := LoadProperties(retroCFGFile)
					If rotation In 1,3 ; use vertical bezel if RA rotation is set to 90 or 270 degrees
						rotateBezel := true
					If RegExMatch(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") {		; these systems require the retroarch settings to be read
						retroSysDir := ReadProperty(retroCFG,"system_directory")	; read value
						retroSysDir := ConvertRetroCFGKey(retroSysDir)	; remove dbl quotes
						StringLeft, retroSysDirLeft, retroSysDir, 2
						If (retroSysDirLeft = ":\") {	; if retroarch is set to use a default folder
							StringTrimLeft, retroSysDir, retroSysDir, 1
							Log("Module - RetroArch is using a relative system path: """ . retroSysDir . """")
							retroSysDir := emuPath . retroSysDir
						If !retroSysDir
							ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.")
						StringRight, checkForSlash, retroSysDir, 1
						If (checkForSlash = "\")	; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders
							StringTrimRight, retroSysDir, retroSysDir, 1
					If (RegExMatch(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX") || RegExMatch(retroID, "LibRetro_NES") && (InStr(core, "nestopia_libretro"))) {	; these systems will use an ini to store game specific settings
						sysSettingsFile := CheckSysFile(modulePath . "\" . systemName . ".ini")	; create the ini if it does not exist
						coreOptionsCFGFile := CheckFile((If configurationPerCore = "true" ? configFolder . "\retroarch-core-options.cfg" : emuPath . "\retroarch-core-options.cfg"), "Could not find retroarch-core-options.cfg in retroarch directory: """ . (If configurationPerCore = "true" ? configFolder : emuPath) . """")
						coreOptionsCFG := LoadProperties(coreOptionsCFGFile)
						If InStr(retroID, "LibRetro_N64") {	; Nintendo 64
							mupenGfx := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Gfx_Plugin", "auto",,1)
							mupenRsp := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_RSP_Plugin", "auto",,1)
							mupenCpu := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_CPU_Core", "dynamic_recompiler",,1)
							mupenPak1 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_1", "memory",,1)
							mupenPak2 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_2", "memory",,1)
							mupenPak3 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_3", "memory",,1)
							mupenPak4 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_4", "memory",,1)
							mupenGfxAccur := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Gfx_Accuracy", "high",,1)
							mupenExpMem := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Disable_Exp_Memory", "no",,1)
							mupenTexturFilt := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Texture_Filtering", "nearest",,1)
							mupenViRefresh := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_VI_Refresh", "2200",,1)
							mupenFramerate := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Framerate", "fullspeed",,1)
							mupenResolution := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Resolution", "640x480",,1)
							mupenPolyOffstFctr := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Polygon_Offset_Factor", "-3.0",,1)
							mupenPolyOffstUnts := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Polygon_Offset_Units", "-3.0",,1)
							mupenViOverlay := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_VI_Overlay", "disabled",,1)
							mupenAnalogDzone := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Analog_Deadzone", "15",,1)
							WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1)
							WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1)
							WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1)
							WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1)
							WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1)
							WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1)
							WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1)
							WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1)
							WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1)
							WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1)
							WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1)
							WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1)
							WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1)
						} Else If InStr(retroID, "LibRetro_NES") {		; these systems will use an ini to store game specific settings
							If InStr(core, "nestopia_libretro") {	; Nestopia
								nestopiaBlargg := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Blargg_NTSC_Filter", "disabled",,1)
								nestopiaPalette := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Palette", "canonical",,1)
								nestopiaNoSprteLimit := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Remove_Sprites_Limit", "disabled",,1)
								WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1)
								WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1)
								WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1)
						} Else If InStr(retroID, "LibRetro_LYNX") {	; Atari Lynx
							If InStr(core, "handy_libretro") {   ; Handy
								handyRotate := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Handy_Rotation", "None",,1)
								If InStr(handyRotate, "240") or InStr(handyRotate, "90")
									rotateBezel := true
								WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1)
						} Else If InStr(retroID, "LibRetro_PSX") {	; Sony PlayStation
							psxCdImageCache := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_CD_Image_Cache", """enabled""",,1)
							psxMemcardHandling := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_Memcard_Handling", """libretro""",,1)
							psxDualshockAnalogToggle := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_Dualshock_Analog_Toggle", """enabled""",,1)
							WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1)
							WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1)
							WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1)
						SaveProperties(coreOptionsCFGFile, coreOptionsCFG)
					hideEmuObj := Object("ahk_class ConsoleWindowClass",0,"RetroArch ahk_class RetroArch",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					mgM3UPath:= romPath . "\" . romTable[1,4] . ".m3u"
					mgRomExtensions := "cue|iso|ccd"
					mgValidExtension := false
					Loop, parse, mgRomExtensions, |
						If (romExtension = "." . A_LoopField)
							mgValidExtension := true
					If (InStr(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated
						m3uRomIndex := Object()
						mgType := romTable[1,6] . " "
						mgMaxIndex := romTable.MaxIndex()
						mgRomIndex := 0
						If FileExist(mgM3UPath)
							FileDelete, %mgM3UPath%
						Loop %mgMaxIndex% {
							If (romTable[A_Index, 3] = romName) {
								tempType := romTable[A_Index, 5]
								StringTrimLeft, mgRomIndex, tempType, StrLen(mgType)
								Log ("Found rom index in rom set in romTable: " . mgRomIndex)
								break
						If (mgRomIndex > 0) {
							tempRomIndex := mgRomIndex
							Loop %mgMaxIndex% {
								mgTypeIndex := mgType . tempRomIndex
								m3uRomIndex.Insert(tempRomIndex)
								Loop %mgMaxIndex% {
									If (romTable[A_Index, 5] = mgTypeIndex) {
										tempRomPath := romTable[A_Index, 1]
										FileAppend, %tempRomPath%`n, %mgM3UPath%
										Log("Appending rom path to m3u: " . tempRomPath)
										break
								If (tempRomIndex < mgMaxIndex)
									tempRomIndex++
								Else
									tempRomIndex := 1
					; MESS core options
					messParam1 :=
					messParam2 :=
					messParam3 :=
					If InStr(core, "mess") {	; if a mess core is used
						Log("Module - Retroarch MESS mode enabled")
						If !retroMessID
							ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MESS LibRetro core")
						Else
							Log("Module - MESS mode using a known ident: " . retroMessID)
						If !messRomPath
							ScriptError("Please set the RetroArch module setting ""MESS_BIOS_Roms_Folder"" to the folder that contains your MESS BIOS roms to use MESS with RetroArch.")
						messParam1 :=
						messParam2 := " -rompath \" . """" . messRomPath . "\" . """"
						; Build a key/value object containing the different messParam3 choices
						messP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","svi328n","cass","pecom64","cass","svmu","quik","gamecom","cart1","mbeeic","quik1")
						messParam3 := messP3[retroMessID]	; search object for the retroMessID pair
						messParam3 := " -" . (If messParam3 ? messParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
						If retroMessID = mbeeic ; Applied Technology MicroBee
						{	microbeeModel := IniReadCheck(messSysINI, romName, "MicroBee_Model","mbeeic",,1)
									If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56
										ScriptError("This is not a known MicroBee model value: " . microbeeModel)
									Else If (microbeeModel != "mbeeic")
										retroMessID := microbeeModel
									If romExtension in .mwb,.com,.bee
										mediaDeviceType := "quik1"
									Else If romExtension in .wav,.tap
										mediaDeviceType := "cass"
									Else If romExtension in .rom
										mediaDeviceType := "cart"
									Else If romExtension in .dsk
										mediaDeviceType := "flop1"
									Else	; .bin format
										mediaDeviceType := "quik2"
									messParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
						fullRomPath := messParam1 . messParam2 . messParam3
					} Else If (superGB = "true") {
						Log("Module - Retroarch Super Game Boy mode enabled")
						fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """"
					} Else {
						Log("Module - Retroarch standard mode enabled")
						fullRomPath := " """ . romPath . "\" . romName . romExtension . """"
					If retroID = LibRetro_NFDS	; Nintendo Famicom Disk System
					{	IfNotExist, %retroSysDir%\disksys.rom
							ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If retroID = LibRetro_SCD	; Sega CD
					{	If romExtension Not In .bin,.cue,.iso
							ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension)
						IfNotExist, %retroSysDir%\bios_CD_E.bin
							ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
						IfNotExist, %retroSysDir%\bios_CD_U.bin
							ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
						IfNotExist, %retroSysDir%\bios_CD_J.bin
							ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If retroID in LibRetro_PCECD,LibRetro_TGCD	; NEC PC Engine-CD and NEC TurboGrafx-CD
					{	If romExtension Not In .ccd,.cue
							ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension)
						IfNotExist, %retroSysDir%\syscard3.pce
							ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If retroID = LibRetro_PCFX
						IfNotExist, %retroSysDir%\pcfx.bios
							ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					networkSession :=
					If (enableNetworkPlay = "true") {
						Log("Module - Network Multi-Player is an available option for " . dbName,4)
						netplayNickname := IniReadCheck(settingsFile, "Network", "NetPlay_Nickname","Player",,1)
						getWANIP := IniReadCheck(settingsFile, "Network", "Get_WAN_IP","false",,1)
						If (getWANIP = "true")
							myPublicIP := GetPublicIP()
						Log("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE",2)
						defaultServerIP := IniReadCheck(settingsFile, "Network", "Default_Server_IP", myPublicIP,,1)
						defaultServerPort := IniReadCheck(settingsFile, "Network", "Default_Server_Port",,,1)
						lastIP := IniReadCheck(settingsFile, "Network", "Last_IP", defaultServerIP,,1)	; does not need to be on the ISD
						lastPort := IniReadCheck(settingsFile, "Network", "Last_Port", defaultServerPort,,1)	; does not need to be on the ISD
						mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,,0)
						If (mpMenuStatus = -1) {	; if user exited menu early
							Log("Module - Cancelled MultiPlayer Menu. Exiting module.",2)
							ExitModule()
						If networkSession {
							Log("Module - Using a Network for " . dbName,4)
							IniWrite, %networkPort%, %settingsFile%, Network, Last_Port
							; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort%
							If (networkType = "client") {
								IniWrite, %networkIP%, %settingsFile%, Network, Last_IP	; Save last used IP and Port for quicker launching next time
								netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """"	; -C = connect as client
							} Else {	; server
								netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """"	; -H = host as server
							Log("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """",4)
						} Else
							Log("Module - User chose Single Player mode for this session",4)
					BezelStart(,,(If rotateBezel ? 1:""))
					If foundCfg {
						If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath)
							customViewportWidth := bezelScreenWidth
							customViewportHeight := bezelScreenHeight
							customViewportX := 0
							customViewportY := 0
							aspectRatioIndex := 22
							Log("Stretching viewport to fit bezel")
						retroCFG := LoadProperties(retroCFGFile)	; load the config into memory
						raCfgHasChanges :=
						WriteRetroProperty("input_overlay", overlay)
						WriteRetroProperty("video_shader", videoShader)
						WriteRetroProperty("aspect_ratio_index", aspectRatioIndex)
						WriteRetroProperty("custom_viewport_width", customViewportWidth)
						WriteRetroProperty("custom_viewport_height", customViewportHeight)
						WriteRetroProperty("custom_viewport_x", customViewportX)
						WriteRetroProperty("custom_viewport_y", customViewportY)
						WriteRetroProperty("video_rotation", rotation)
						WriteRetroProperty("video_crop_overscan", cropOverscan)
						WriteRetroProperty("video_threaded", threadedVideo)
						WriteRetroProperty("video_vsync", vSync)
						WriteRetroProperty("video_scale_integer", integerScale)
						WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey)
						WriteRetroProperty("input_disk_next", nextDiskKey)
						WriteRetroProperty("input_disk_prev", prevDiskKey)
							Loop, 8	; Loop 8 times for 8 controllers
							{	p%A_Index%ControllerType := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "P" . A_Index . "_Controller_Type", 517,,1)
								WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType)
						If raCfgHasChanges {
							Log("Module - Saving changed settings to: """ . retroCFGFile . """")
							SaveProperties(retroCFGFile, retroCFG)
					fullscreen := If fullscreen = "true" ? " -f" : ""
					srmPath := emuPath . "\srm\" . retroSystem	; path for this system's srm files
					saveStatePath := emuPath . "\save\" . retroSystem	; path for this system's save state files
					retroCFGFile := If foundCfg ? " -c """ . retroCFGFile . """" : ""
					IfNotExist, %srmPath%
						FileCreateDir, %srmPath% ; creating srm dir if it doesn't exist
					IfNotExist, %saveStatePath%
						FileCreateDir, %saveStatePath% ; creating save dir if it doesn't exist
					HideEmuStart()	; This fully ensures windows are completely hidden even faster than winwait
						Run(executable . " """ . (retroMessID ? retroMessID : "") . fullRomPath . """ " . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide")
					} Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case.
						Run(executable . " " . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . fullRomPath . netCommand, emuPath, "Hide")
					} Else If FileExist(mgM3UPath) {
						Run(executable . " " . """" . mgM3UPath . """" . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide")
					} Else {
						Run(executable . " " . fullRomPath . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide")
					mpMenuStatus :=
					If networkSession {
						canceledServerWait := false
						multiplayerMenuExit := false
						SetTimer, NetworkConnectedCheck, 500
						If (networkType = "server") {
							Log("Module - Waiting for a client to connect to your server")
							mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.")
						} Else {	; client
							Log("Module - Trying to contact the server to establish a connection.")
							mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...")
						If (mpMenuStatus = -1) {	; if user exited menu early before a client connected
							Log("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.",2)
							If Process("Exist", executable)
								Process("Close", executable)	; must close process as the exe is waiting for a client to connect and no window was drawn yet
							ExitModule()
						} Else {	; blank response from MultiPlayerMenu, exited properly
							Log("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server")
							WinWait("RetroArch ahk_class RetroArch")
							WinWaitActive("RetroArch ahk_class RetroArch")
						SetTimer, NetworkConnectedCheck, Off
					} Else {	; single player
					If hideConsole = true
						WinSet, Transparent, On, ahk_class ConsoleWindowClass	; makes the console window transparent so you don't see it on exit
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					; Writes new properties into the retroCFG if defined by user
					WriteRetroProperty(key,value="") {
						If (value != "") {
							Global retroCFG,raCfgHasChanges
							WriteProperty(retroCFG, key, value,1,1)
							raCfgHasChanges := 1
					; Used to convert between RetroArch keys and usable data
					ConvertRetroCFGKey(txt,direction="read"){
						Global emuPath
						If direction = read
						{	StringTrimLeft,newtxt,txt,1	; removes the " from the left of the txt
							StringTrimRight,newtxt,newtxt,1	; removes the " from the right of the txt
							relativeCheck := SubStr(newtxt, 1, 1)
							If InStr(relativeCheck,":") {	; if the path contains a ":" then it is a relative path
								Log("ConvertRetroCFGKey - " . newtxt . " is a relative path",4)
								StringTrimLeft,newtxt,newtxt,1	; removes the : from the left of the txt
								newtxt := AbsoluteFromRelative(emuPath, "." . newtxt)	; convert relative to absolute
							If InStr(newtxt,"/")
								StringReplace,newtxt,newtxt,/,\,1	; replaces all forward slashes with backslashes
						} Else If direction = write
						{	newtxt = "%txt%"	; wraps the txt with ""
							If InStr(newtxt,"\")
								StringReplace,newtxt,newtxt,\,/,1	; replaces all backslashes with forward slashes
						} Else
							ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.")
						Log("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt,4)
						Return newtxt
					; This will simply create a new blank ini if one does not exist
					CheckSysFile(file){
						IfNotExist, %file%
							FileAppend,, %file%
						Return file
					MultiGame:
						SetKeyDelay(100)
						WinActivate, ahk_class RetroArch
						Send, {%ejectToggleKey% down}{%ejectToggleKey% up}	; eject disc in Retroarch
						If (!mgLastRomIndex) {
							mgLastRomIndex := mgRomIndex
						selectedRomIndex := 0
						StringTrimLeft, selectedRomIndex, selectedRomNum, StrLen(mgType)
						Loop %mgMaxIndex% {
							If (m3uRomIndex[A_index] = mgLastRomIndex) {
								tempLastRomIndex := A_index
								Log("Temp last index: " . tempLastRomIndex)
							If (m3uRomIndex[A_index] = selectedRomIndex) {
								tempSelectedRomIndex := A_index
								Log("temp selected index: " . tempSelectedRomIndex)
						mgNewIndex := tempLastRomIndex - tempSelectedRomIndex
						If (mgNewIndex < 0) {
							mgNewIndex := mgNewIndex * -1
							Loop %mgNewIndex% {
								Log("Sending the next disk key: " . nextDiskKey)
								Send, {%nextDiskKey% down}{%nextDiskKey% up}
						} Else If (mgNewIndex > 0) {
							Loop %mgNewIndex% {
								Log("Sending the previous disk key: " . mgNewIndex)
								Send, {%prevDiskKey% down}{%prevDiskKey% up}
						Send, {%ejectToggleKey% down}{%ejectToggleKey% up}	; close disc in Retroarch
						mgLastRomIndex := selectedRomIndex
					Return
					NetworkConnectedCheck:
						If clientConnected
							multiplayerMenuExit := true
						Else If WinExist("RetroArch ahk_class RetroArch") {
							Log("Module - RetroArch session started, closing the MultiPlayer menu",4)
					Return
					CloseProcess:
						FadeOutStart()
						WinClose("RetroArch ahk_class RetroArch")
					Return
22:06:33:771 | RL |     INFO  | +16    | BuildScript - Loaded Multi-Player scripts
22:06:33:781 | RL |     INFO  | +16    | BuildScript - Loaded Statistics.ahk script
22:06:33:781 | RL |  WARNING  | +0     | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found
22:06:33:791 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
22:06:33:801 | RL |     INFO  | +15    | Main - Module is built
22:06:33:801 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists
22:06:33:801 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Created:			5/24/2015 - 8:28:11 AM
					Modified:			4/19/2013 - 6:16:32 PM
22:06:33:811 | RL |     INFO  | +0     | Main - Running module
22:06:33:811 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
22:06:33:931 | MD |     INFO  | +N/A   | Module initialized
22:06:33:931 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
22:06:33:961 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
22:06:33:961 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
22:06:33:961 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
22:06:33:991 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
22:06:33:021 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Ended
22:06:34:021 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
22:06:34:021 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy6 not in TableKeyGroups ~Esc,
22:06:34:051 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 1 check
22:06:34:051 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
22:06:34:051 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label
22:06:34:081 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Ended
22:06:34:091 | MD |   DEBUG2  | +0     | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in E:\Rocketlauncher\Settings\Atari 5200\Games JoyIDs.ini under section [Space Dungeon (USA)]
22:06:34:091 | MD |     INFO  | +0     | LoadPreferredControllers - Started
22:06:34:091 | MD |   DEBUG2  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows)
22:06:34:091 | MD |   DEBUG2  | +0     | LoadPreferredControllers - Creating a list of currently connected joysticks
22:06:34:091 | MD |     INFO  | +0     | GetJoystickArray - Started
22:06:34:131 | MD |   DEBUG2  | +47    | GetJoystickArray - Joysticks Detected: 1000000000000000
22:06:34:131 | MD |     INFO  | +0     | GetJoystickGUID - Started
22:06:34:131 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
22:06:34:161 | MD |   DEBUG2  | +31    | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
22:06:34:161 | MD |     INFO  | +0     | GetJoystickArray - Ended
22:06:34:161 | MD |   DEBUG2  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000
22:06:34:161 | MD |     INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
22:06:34:193 | MD |     INFO  | +31    | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
22:06:34:193 | MD |     INFO  | +0     | ChangeJoystickID - Started
22:06:34:223 | MD |   DEBUG2  | +31    | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000
22:06:34:223 | MD |     INFO  | +0     | ChangeJoystickID - Ended
22:06:34:223 | MD |     INFO  | +0     | LoadPreferredControllers - Ended
22:06:34:253 | MD |     INFO  | +32    | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists
22:06:34:253 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1178624 bytes
					Created:			6/16/2015 - 11:46:34 AM
					Modified:			2/2/2014 - 3:10:38 PM
22:06:34:253 | MD |     INFO  | +0     | Keymapper - Loading xpadder
22:06:34:263 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
22:06:34:263 | MD |     INFO  | +0     | GetJoystickArray - Started
22:06:34:283 | MD |   DEBUG2  | +31    | GetJoystickArray - Joysticks Detected: 1000000000000000
22:06:34:283 | MD |     INFO  | +0     | GetJoystickGUID - Started
22:06:34:293 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
22:06:34:293 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
22:06:34:313 | MD |     INFO  | +31    | GetJoystickArray - Ended
22:06:34:313 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe"
22:06:34:313 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
22:06:34:313 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
22:06:34:323 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Space Dungeon (USA)|E:\Rocketlauncher\Profiles\xpadder\Atari 5200\RetroArch|E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
22:06:34:323 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Space Dungeon (USA)\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:06:34:323 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Space Dungeon (USA)\p1.xpadderprofile
22:06:34:323 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\RetroArch\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:06:34:323 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\RetroArch\p1.xpadderprofile
22:06:34:343 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:06:34:343 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default\p1.xpadderprofile
22:06:34:343 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:06:34:343 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
22:06:34:343 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
22:06:34:353 | MD |     INFO  | +0     | RunXpadder - Started
22:06:34:353 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
22:06:34:353 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
22:06:34:353 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
22:06:34:453 | MD |   DEBUG1  | +109   | Run - "Xpadder.exe /C" Process ID: 5900
22:06:34:453 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
22:06:34:453 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
22:06:34:679 | MD |   DEBUG2  | +219   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
22:06:34:679 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
22:06:34:679 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
22:06:34:741 | MD |   DEBUG1  | +62    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 4576
22:06:34:741 | MD |     INFO  | +0     | RunXpadder - Ended
22:06:34:741 | MD |     INFO  | +0     | RunKeymapper - Ended
22:06:34:741 | MD |     INFO  | +0     | Keymapper - Loading External AHK Keymapping
22:06:34:741 | MD |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists
22:06:34:741 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	AhkLauncher
					FileVersion             	1.0.0.0
					InternalName            	AhkLauncher.exe
					LegalCopyright          	Copyright ©  2013
					OriginalFilename        	AhkLauncher.exe
					ProductName             	AhkLauncher
					ProductVersion          	1.0.0.0
					File Size:			11264 bytes
					Created:			5/24/2015 - 8:28:06 AM
					Modified:			9/4/2013 - 6:30:52 PM
22:06:34:773 | MD |     INFO  | +31    | RunAHKKeymapper - Started
22:06:34:773 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Loading Space Dungeon (USA), RetroArch, Atari 5200, or _Default AHK Keymapper profile
22:06:34:773 | MD |     INFO  | +0     | GetAHKProfile - Started
22:06:34:773 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Atari 5200\Space Dungeon (USA).ahk
22:06:34:773 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Atari 5200\RetroArch.ahk
22:06:34:773 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Atari 5200.ahk
22:06:34:804 | MD |   DEBUG2  | +32    | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk
22:06:34:804 | MD |     INFO  | +0     | GetAHKProfile - Ended and no profile found
22:06:34:804 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
22:06:34:804 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
22:06:34:804 | MD |     INFO  | +0     | RunAHKKeymapper - Ended
22:06:34:804 | MD |     INFO  | +0     | StartModule - Started
22:06:34:804 | MD |     INFO  | +0     | StartModule - MEmu: RetroArch
					MEmuV: v05-11-2015 Nightly
					MURL: http://themaister.net/retroarch.html
					MAuthor: djvj,zerojay
					MVersion: 2.3.3
					MCRC: A2F3BE90
					iCRC: 42C3B552
					MID:
					MSystem: "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System 2","Capcom Play System 3","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
22:06:34:835 | MD |     INFO  | +31    | StartModule - You have a supported System Name for this module: "Atari 5200"
22:06:34:835 | RL |  WARNING  | +1030  | HyperSpin.exe was displaced to x22 y22 w1080 h624 by RetroArch. It is probably running in true fullscreen mode.
22:06:34:835 | MD |     INFO  | +0     | PluginInit - Started
22:06:34:835 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
22:06:34:835 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Databases\Atari 5200\Atari 5200.xml exists
22:06:34:835 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			24008 bytes
					Created:			5/20/2015 - 5:19:45 PM
					Modified:			8/8/2012 - 7:11:33 PM
22:06:34:866 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
22:06:34:866 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
22:06:34:866 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
22:06:34:866 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Space Dungeon (USA)"
22:06:34:897 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Cloneof
22:06:34:897 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
22:06:34:897 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
22:06:34:897 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "Atari"
22:06:34:897 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
22:06:34:897 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Year" with a value: "1983"
22:06:34:897 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
22:06:34:897 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Action"
22:06:34:929 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Rating
22:06:34:930 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "HSRS - GA (General Audience)"
22:06:34:930 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Genre | GameInfo Value: Action
					GameInfo Label: Manufacturer | GameInfo Value: Atari
					GameInfo Label: Name | GameInfo Value: Space Dungeon (USA)
					GameInfo Label: Rating | GameInfo Value: HSRS - GA (General Audience)
					GameInfo Label: Year | GameInfo Value: 1983
22:06:34:930 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
22:06:34:930 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
22:06:34:930 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: E:\Hyperspin\Media\Atari 5200\Images\Wheel\Space Dungeon (USA).png
22:06:34:930 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: E:\Hyperspin\Media\Main Menu\Images\Wheel\Atari 5200.png
22:06:34:930 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: System Logo | Asset Path1:  E:\Hyperspin\Media\Main Menu\Images\Wheel\Atari 5200.png | Asset Extension1:  png | Asset Type1:  system
22:06:34:930 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
22:06:34:961 | MD |   DEBUG1  | +32    | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
22:06:34:961 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: E:\Hyperspin\Media\Atari 5200\Images\Artwork1\Space Dungeon (USA).png
22:06:34:961 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: E:\Hyperspin\Media\Atari 5200\Images\Artwork2\Space Dungeon (USA).png
22:06:34:961 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: E:\Hyperspin\Media\Atari 5200\Images\Artwork3\Space Dungeon (USA).png
22:06:34:961 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: E:\Hyperspin\Media\Atari 5200\Images\Artwork4\Space Dungeon (USA).png
22:06:34:961 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: E:\Hyperspin\Media\Atari 5200\Images\Letters
22:06:35:023 | MD |   DEBUG1  | +62    | BuildAssetsTable - Searching for a Other: E:\Hyperspin\Media\Atari 5200\Images\Other
22:06:35:023 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  E:\Hyperspin\Media\Atari 5200\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  E:\Hyperspin\Media\Atari 5200\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  E:\Hyperspin\Media\Atari 5200\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  E:\Hyperspin\Media\Atari 5200\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  E:\Hyperspin\Media\Atari 5200\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  E:\Hyperspin\Media\Atari 5200\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  E:\Hyperspin\Media\Atari 5200\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  E:\Hyperspin\Media\Atari 5200\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  E:\Hyperspin\Media\Atari 5200\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  E:\Hyperspin\Media\Atari 5200\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  E:\Hyperspin\Media\Atari 5200\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  E:\Hyperspin\Media\Atari 5200\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  E:\Hyperspin\Media\Atari 5200\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  E:\Hyperspin\Media\Atari 5200\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  E:\Hyperspin\Media\Atari 5200\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  E:\Hyperspin\Media\Atari 5200\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  E:\Hyperspin\Media\Atari 5200\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  E:\Hyperspin\Media\Atari 5200\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  E:\Hyperspin\Media\Atari 5200\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  E:\Hyperspin\Media\Atari 5200\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  E:\Hyperspin\Media\Atari 5200\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  E:\Hyperspin\Media\Atari 5200\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  E:\Hyperspin\Media\Atari 5200\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  E:\Hyperspin\Media\Atari 5200\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  E:\Hyperspin\Media\Atari 5200\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  E:\Hyperspin\Media\Atari 5200\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  E:\Hyperspin\Media\Atari 5200\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  E:\Hyperspin\Media\Atari 5200\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  E:\Hyperspin\Media\Atari 5200\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  E:\Hyperspin\Media\Atari 5200\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  E:\Hyperspin\Media\Atari 5200\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  E:\Hyperspin\Media\Atari 5200\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  E:\Hyperspin\Media\Atari 5200\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  E:\Hyperspin\Media\Atari 5200\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  E:\Hyperspin\Media\Atari 5200\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  E:\Hyperspin\Media\Atari 5200\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  E:\Hyperspin\Media\Atari 5200\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  E:\Hyperspin\Media\Atari 5200\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  E:\Hyperspin\Media\Atari 5200\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  E:\Hyperspin\Media\Atari 5200\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
22:06:35:023 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
22:06:35:023 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
22:06:35:023 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: E:\Hyperspin\Media\Atari 5200\Video\Space Dungeon (USA).*
22:06:35:054 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a System Video: E:\Hyperspin\Media\Main Menu\Video\Atari 5200.*
22:06:35:054 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: System Video | Asset Path1:  E:\Hyperspin\Media\Main Menu\Video\Atari 5200.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
22:06:35:054 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
22:06:35:086 | MD |     INFO  | +31    | PluginInit - Ended
22:06:35:086 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Space Dungeon (USA)
22:06:35:086 | MD |     INFO  | +0     | Hiding mouse cursor
22:06:35:117 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Started
22:06:35:117 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy6,
22:06:35:117 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
22:06:35:117 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
22:06:35:148 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
22:06:35:148 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
22:06:35:148 | MD |     INFO  | +0     | StartModule - Ended
22:06:35:179 | MD |   DEBUG1  | +31    | Module - Started building the RetroArch object
22:06:35:179 | MD |   DEBUG1  | +0     | Module - Finished building the RetroArch object
22:06:35:210 | MD |     INFO  | +31    | Module Setting - [Atari 5200] - LibRetro_Core: mess_libretro
22:06:35:210 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
22:06:35:242 | MD |     INFO  | +31    | Module Setting - [Settings] - ConfigFolder: E:\Hyperspin\Emulators\Retroarch\config
22:06:35:242 | MD |     INFO  | +0     | Module Setting - [Settings] - MESS_BIOS_Roms_Folder: E:\Hyperspin\Emulators\Retroarch\system\mess
22:06:35:242 | MD |     INFO  | +0     | Module Setting - [Settings] - HideConsole: true
22:06:35:273 | MD |     INFO  | +32    | Module Setting - [Settings] - Eject_Toggle_Key:
22:06:35:273 | MD |     INFO  | +0     | Module Setting - [Settings] - Next_Disk_Key:
22:06:35:273 | MD |     INFO  | +0     | Module Setting - [Settings] - Previous_Disk_Key:
22:06:35:304 | MD |     INFO  | +31    | Module Setting - [Atari 5200] - SuperGameBoy: false
22:06:35:304 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - SuperGameBoy: false
22:06:35:304 | MD |     INFO  | +0     | Module Setting - [Network] - Enable_Network_Play: false
22:06:35:335 | MD |     INFO  | +31    | Module Setting - [Space Dungeon (USA)] - Enable_Network_Play: false
22:06:35:335 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - Overlay:
22:06:35:335 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - Overlay:
22:06:35:335 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - VideoShader:
22:06:35:335 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - VideoShader:
22:06:35:335 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - AspectRatioIndex:
22:06:35:366 | MD |     INFO  | +31    | Module Setting - [Space Dungeon (USA)] - AspectRatioIndex:
22:06:35:366 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - CustomViewportWidth:
22:06:35:366 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - CustomViewportWidth:
22:06:35:366 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - CustomViewportHeight:
22:06:35:366 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - CustomViewportHeight:
22:06:35:398 | MD |     INFO  | +31    | Module Setting - [Atari 5200] - CustomViewportX:
22:06:35:398 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - CustomViewportX:
22:06:35:398 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - CustomViewportY:
22:06:35:398 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - CustomViewportY:
22:06:35:398 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - StretchToFillBezel: false
22:06:35:398 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - StretchToFillBezel: false
22:06:35:429 | MD |     INFO  | +32    | Module Setting - [Atari 5200] - Rotation: 0
22:06:35:429 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - Rotation: 0
22:06:35:429 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - CropOverscan:
22:06:35:429 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - CropOverscan:
22:06:35:429 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - ThreadedVideo:
22:06:35:460 | MD |     INFO  | +31    | Module Setting - [Space Dungeon (USA)] - ThreadedVideo:
22:06:35:460 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - VSync:
22:06:35:460 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - VSync:
22:06:35:460 | MD |     INFO  | +0     | Module Setting - [Atari 5200] - IntegerScale:
22:06:35:460 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - IntegerScale:
22:06:35:491 | MD |     INFO  | +31    | Module Setting - [Atari 5200] - ConfigurationPerCore: false
22:06:35:491 | MD |     INFO  | +0     | Module Setting - [Space Dungeon (USA)] - ConfigurationPerCore: false
22:06:35:491 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\Retroarch\cores\mess_libretro.dll exists
22:06:35:491 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			53157888 bytes
					Created:			8/16/2015 - 8:27:43 PM
					Modified:			8/16/2015 - 9:15:59 PM
22:06:35:491 | MD |   DEBUG1  | +0     | Module - Global cfg should be: E:\Hyperspin\Emulators\Retroarch\retroarch.cfg
22:06:35:522 | MD |   DEBUG1  | +31    | Module - System cfg should be: E:\Hyperspin\Emulators\Retroarch\config\Atari 5200.cfg
22:06:35:522 | MD |   DEBUG1  | +0     | Module - Core cfg should be: E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg
22:06:35:522 | MD |   DEBUG1  | +0     | Module - Found a Core cfg!
22:06:35:522 | MD |     INFO  | +0     | Module - RetroArch is using E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg as its config file.
22:06:35:522 | MD |   DEBUG1  | +0     | LoadProperties - Started and loading this cfg into memory: E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg
22:06:35:554 | MD |   DEBUG1  | +31    | LoadProperties - Ended
22:06:35:554 | MD |     INFO  | +0     | 7z - Started, received E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200\Space Dungeon (USA).zip. If rom is an archive, it will extract to C:\Users\Lenovo\AppData\Local\Temp\HS
22:06:35:554 | MD |   DEBUG1  | +0     | 7z - Using Standard method to extract this rom
22:06:35:585 | MD |   DEBUG1  | +32    | 7z - ".zip" found in .zip,.rar,.7z,.lzh,.gzip,.tar
22:06:35:585 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200\Space Dungeon (USA).zip exists
22:06:35:616 | MD |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			10888 bytes
					Created:			5/21/2015 - 1:38:44 AM
					Modified:			3/7/2010 - 10:47:59 AM
22:06:35:694 | MD |     INFO  | +78    | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "Space Dungeon (USA).a52"
22:06:35:742 | MD |   DEBUG1  | +47    | 7z - Invoked COM Object, ROM extracted size: 16384 bytes
22:06:35:742 | MD |   DEBUG1  | +0     | 7z - Checking if this archive has already been extracted in C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA)
22:06:35:742 | MD |   DEBUG1  | +0     | 7z - File does not already exist in C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA), proceeding to extract it.
22:06:35:742 | MD |   DEBUG1  | +0     | 7z - File found in archive
22:06:35:742 | MD |     INFO  | +0     | 7z - Extracted path of rom will be 81 in length and within the 255 character limit.
22:06:35:742 | MD |     INFO  | +0     | 7z - The 7zExtractPath has 144122 MB of free space which is enough to extract this game: 0 MB
22:06:35:773 | MD |   DEBUG1  | +31    | 7z - Logging is debug or higher, dumping 7z Extraction info to log
22:06:35:773 | MD |   DEBUG1  | +0     | 7z - Starting 7z extraction of E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200\Space Dungeon (USA).zip  to C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA)
22:06:35:804 | MD |     INFO  | +31    | Process - Wait 7z.exe 2
22:06:35:804 | MD |   DEBUG1  | +0     | 7z - Starting 7zTimeout Timer
22:06:35:835 | MD |   DEBUG1  | +31    | Extracting file:		|	Percentage Extracted:   0%
22:06:35:945 | MD |   DEBUG1  | +109   | Extracting file:	Space Dungeon (USA).a52	|	Percentage Extracted: 100%
22:06:36:054 | MD |   DEBUG1  | +110   | 7zTimeout - 7z.exe is no longer running
22:06:36:054 | MD |   DEBUG1  | +0     | Extracting file:	Space Dungeon (USA).a52	|	Percentage Extracted: 100%
22:06:36:054 | MD |   DEBUG1  | +0     | 7z - 7z.exe returned a percentage >= 100, assuming extraction is complete
22:06:36:085 | MD |   DEBUG1  | +31    | 7z - Finished 7z extraction
22:06:36:085 | MD |   DEBUG1  | +0     | 7z - Found file in C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA)\Space Dungeon (USA).a52
22:06:36:085 | MD |   DEBUG1  | +0     | 7z - romPath changed from "E:\Hyperspin\Emulators\Retroarch\roms\Atari 5200" to "C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA)"
22:06:36:085 | MD |   DEBUG1  | +0     | 7z - romName changed from "Space Dungeon (USA)" to "Space Dungeon (USA)"
22:06:36:085 | MD |   DEBUG1  | +0     | 7z - romExtension changed from ".zip" to ".a52"
22:06:36:085 | MD |     INFO  | +0     | 7z - Ended
22:06:36:116 | MD |     INFO  | +31    | Module - Retroarch MESS mode enabled
22:06:36:116 | MD |     INFO  | +0     | Module - MESS mode using a known ident: a5200
22:06:36:116 | MD |   DEBUG1  | +0     | LoadProperties - Started and loading this cfg into memory: E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg
22:06:36:147 | MD |   DEBUG1  | +31    | LoadProperties - Ended
22:06:36:147 | MD |   DEBUG1  | +0     | WriteProperty - Started
22:06:36:147 | MD |   DEBUG1  | +0     | WriteProperty - Ended
22:06:36:179 | MD |     INFO  | +31    | Module - Saving changed settings to: "E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg"
22:06:36:179 | MD |   DEBUG1  | +0     | SaveProperties - Started and saving this cfg to disk: E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg
22:06:36:210 | MD |   DEBUG1  | +32    | SaveProperties - Ended
22:06:36:210 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Emulators\Retroarch\retroarch.exe "a5200 -rompath \"E:\Hyperspin\Emulators\Retroarch\system\mess\" -cart \"C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA)\Space Dungeon (USA).a52\""  -f -c "E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg" -L "E:\Hyperspin\Emulators\Retroarch\cores\mess_libretro.dll" -s "E:\Hyperspin\Emulators\Retroarch\srm\Atari 5200\Space Dungeon (USA).srm" -S "E:\Hyperspin\Emulators\Retroarch\save\Atari 5200\Space Dungeon (USA).state"
22:06:36:272 | MD |   DEBUG1  | +62    | Run - "retroarch.exe "a5200 -rompath \"E:\Hyperspin\Emulators\Retroarch\system\mess\" -cart \"C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA)\Space Dungeon (USA).a52\""  -f -c "E:\Hyperspin\Emulators\Retroarch\config\mess_libretro.dll.cfg" -L "E:\Hyperspin\Emulators\Retroarch\cores\mess_libretro.dll" -s "E:\Hyperspin\Emulators\Retroarch\srm\Atari 5200\Space Dungeon (USA).srm" -S "E:\Hyperspin\Emulators\Retroarch\save\Atari 5200\Space Dungeon (USA).state"" Process ID: 1908
22:06:36:272 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: E:\Hyperspin\Emulators\Retroarch\system\mess | Class: CabinetWClass | State: 1 | X: -4 | Y: -4 | Width: 1448 | Height: 864 | Window HWND: 0xc067e | Process ID: 1460 | Process Path: C:\Windows\explorer.exe
22:06:36:303 | MD |     INFO  | +31    | WinWait - Waiting for "RetroArch ahk_class RetroArch"
22:06:36:964 | MD |   DEBUG1  | +671   | GetActiveWindowStatus - Title: RetroArch | Class: RetroArch | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0xb4044c | Process ID: 1908 | Process Path: E:\Hyperspin\Emulators\Retroarch\retroarch.exe
22:06:36:968 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RetroArch | Class: RetroArch | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0xb4044c | Process ID: 1908 | Process Path: E:\Hyperspin\Emulators\Retroarch\retroarch.exe
22:06:36:969 | MD |     INFO  | +0     | WinWaitActive - Waiting for "RetroArch ahk_class RetroArch"
22:06:37:080 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: RetroArch | Class: RetroArch | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0xb4044c | Process ID: 1908 | Process Path: E:\Hyperspin\Emulators\Retroarch\retroarch.exe
22:06:37:111 | MD |     INFO  | +31    | Process - WaitClose retroarch.exe
22:06:37:545 | MD |     INFO  | +437   | 7zCleanUp - Started
22:06:37:623 | MD |   DEBUG1  | +78    | 7zCleanUp - Deleted C:\Users\Lenovo\AppData\Local\Temp\HS\Space Dungeon (USA)
22:06:37:623 | MD |     INFO  | +0     | 7zCleanUp - Ended
22:06:37:623 | MD |     INFO  | +0     | ExitModule - Started
22:06:37:623 | MD |     INFO  | +0     | Starting Updating Statistics:
22:06:37:623 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
22:06:37:623 | MD |   DEBUG2  | +0     | gameSectionStartTime:283252965
22:06:37:654 | MD |   DEBUG2  | +31    | ElapsedTime:2
22:06:37:654 | MD |   DEBUG2  | +0     | Statistics cleared game name: Space Dungeon
22:06:37:748 | MD |   DEBUG2  | +94    | Loaded game statistics from ini files:
					Number_of_Times_Played: 0
					Last_Time_Played: 0
					Average_Time_Played: 0
					Total_Time_Played: 0
					System_Total_Played_Time: 8
					Total_Global_Played_Time: 10059
22:06:37:748 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 1
					Last_Time_Played: Tuesday December 1, 2015 10:06:35 PM
					Average_Time_Played: 2
					Total_Time_Played: 2
					System_Total_Played_Time: 10
					Total_Global_Played_Time: 10061
22:06:37:811 | MD |     INFO  | +62    | Game section statistics updated.
22:06:37:811 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
22:06:37:811 | MD |     INFO  | +0     | GetJoystickArray - Started
22:06:37:811 | MD |   DEBUG2  | +0     | GetJoystickArray - Joysticks Detected: 1000000000000000
22:06:37:811 | MD |     INFO  | +0     | GetJoystickGUID - Started
22:06:37:811 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
22:06:37:842 | MD |   DEBUG2  | +32    | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
22:06:37:842 | MD |     INFO  | +0     | GetJoystickArray - Ended
22:06:37:842 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
22:06:37:842 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
22:06:37:842 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
22:06:37:842 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:06:37:873 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
22:06:37:873 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
22:06:37:873 | MD |     INFO  | +0     | RunXpadder - Started
22:06:37:904 | MD |     INFO  | +31    | Process - Exist JoyToKey.exe
22:06:37:936 | MD |   DEBUG2  | +31    | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
22:06:37:936 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
22:06:37:982 | MD |   DEBUG1  | +47    | Run - "Xpadder.exe /C" Process ID: 4432
22:06:37:982 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
22:06:37:982 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
22:06:38:232 | MD |   DEBUG2  | +250   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
22:06:38:232 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
22:06:38:263 | MD |     INFO  | +31    | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M
22:06:38:294 | MD |   DEBUG1  | +31    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M" Process ID: 264
22:06:38:294 | MD |     INFO  | +0     | RunXpadder - Ended
22:06:38:294 | MD |     INFO  | +0     | RunKeymapper - Ended
22:06:38:294 | MD |     INFO  | +0     | RunAHKKeymapper - Started
22:06:38:294 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Unloading AhkLauncher
22:06:38:294 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
22:06:38:294 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
22:06:38:326 | MD |     INFO  | +31    | RunAHKKeymapper - Ended
22:06:38:326 | MD |     INFO  | +0     | Restoring mouse cursor
22:06:38:326 | MD |     INFO  | +0     | ExitModule - Ended
22:06:38:326 | MD |     INFO  | +0     | End of Module Logs
22:06:38:404 | RL |     INFO  | +3572  | Main - Module ended, exiting RocketLauncher normally
22:06:38:404 | RL |     INFO  | +0     | ExitScript - Started
22:06:38:404 | RL |   DEBUG1  | +0     | ExitScript - Restoring HyperSpin.exe to x0 y0 w1440 h900
22:06:38:575 | RL |   DEBUG1  | +172   | ExitScript - Restoring and Clicking HyperSpin.exe to attempt to put it into focus
22:06:38:575 | RL |   DEBUG1  | +0     | ExitScript - Checking what application is currently in focus.
22:06:38:575 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
22:06:38:591 | RL |     INFO  | +15    | ExitScript - Ended
[/code]
Atari 5200 with Retroarch means using the MESS core if I recall.  Using the MESS core is a nuissance, I suggest using the Kat5200, which will run most games.
Yeap. Can confirm. Kat5200 is the way to go. Either way, you are much better off just using Mess instead of Retroarch. Just went through the same thing 2 weeks ago.
I finally got an award! Lol. I know I am on the last leg if my setup and so excited to finish!! I am so sorry for so many questions. I have tried in rl ui first it does nothing. I tested kat5200 a bit and it is working in ui but on exit goes to grey GUI ill work on It more...
I have not propely figured this one out, but i only get i to run unzipped/ZIPPED, not 7zipped as i downloaded it from pd, doesnt work with 7z enabled for some wierd reason..
Colecovision games also has to be softlist named, zipped, and 7z set to false in RL, but that one is the same with mame for me, disabling software list doesnt help..
Also, set RL to use the mame core, not the mess one.
  • 3 weeks later...
I personally prefer Altirra for Atari 8Bit and 5200. It's kinda weird to configure at first but works really great once you have it setup. The controls wouldn't work right for me on the latest version (was missing down arrow as an option?) but the version before that works fine.
having issues myself on kat5200 (latest version).  i assign all the controls and they seem to work in game but the start and reset buttons do not work to what i have them assigned to, the standard 1 and 5 for P2, and 2 and 6 for P2.
