ctrguy Posted December 4, 2015 Posted December 4, 2015 Hi guys. I have all my nes roms with custom file names and im trying to create a XML to match them. HyperROM2XML creates a list just fine, but It will only show about 10 or so games on the wheel when loaded through hyperspin android. However, it will show all the games on the wheel when loaded on PC. For some reason its not loading up all the games on android. I also tried Dons list generator but I cant get it to generate a XML file with my custom rom filenames. What am I doing wrong?
reznnate Posted December 4, 2015 Posted December 4, 2015 This is probably an issue with non-standard xml characters. If you notice the list stops right before a game that has an & in it's name, remove it, change it to & in the xml file, and that should do it.
ctrguy Posted December 5, 2015 Author Posted December 5, 2015 This is probably an issue with non-standard xml characters. If you notice the list stops right before a game that has an & in it's name, remove it, change it to & in the xml file, and that should do it. That worked! Thank you!
djdaveoc Posted December 13, 2015 Posted December 13, 2015 Where is the post describing the non-supported characters? Thank you
