xpadder question
hey guys,
Could someone tell me how to get xpadder to revert to default after I close a game? I got it to switch to a specific controller scheme for a game but when I close it, the controller setup does not change back to the blank setup I need.
If I remember correctly, you have to set up a blank profile in the auto profile for it to revert to once it's done autodetecting the program
okay, where would you point the  blank profile to? for example, the one i set up points to load when a steam game opens
So hyperspin is loosing focus when you exit the emulator? or does xpadder just shut down once you exit the emulator. Check and see if when you exit your emulator xpader is still running or not.
ya its still running. it just has the profile for the steam game loaded. Are you saying i should set a blank profile for hyperspin?
sorry if that makes no sense lol
Just trying to get everything together. You enter HS and you have full control, once you enter your wheel/ emulator and then exit that's when you loose HS control?
No you just have to have a blank profile made, for it to revert to when it's done with your game profile.  If a profile hasn't been created and saved "blank profile", it will never go back to it.
  • 1 month later...
Don't bother using xpadder any more. The new version of HyperSpin Startup Script allows you to control HyperSpin's UI without using a keymapper. But the answer to your question is in this tutorial I created. Skip to the joystick setup part:  https://www.youtube.com/watch?v=__j-kp9rUgE#
