Cougar888 Posted December 9, 2015 Posted December 9, 2015 Hi guys, I can't seem to get my joysticks to control the HS menus. I have set up the controls in HyperHQ but nothing works when I boot up HS. Everything works in my emulators such as Mame. I'm using HS 1.4 with RocketLauncher. My cab OS is Win XP 32bit Hope someone can help
Metalzoic Posted December 9, 2015 Posted December 9, 2015 I believe that's because HS doesn't work with analog joysticks/trackballs/spinners etc... You need to use a different program such as xpadder (I think) to create a profile to use when in the HS menu system. There are a ton of topics about control profiles, but not sure if there are any specific to U360's. I'm planning on upgrading to them myself so hopefully you get some solid info in this topic. I'm also going to have to buy or build a USB cut-off switch so I can use these joysticks with emulators that normally won't work with it.
Cougar888 Posted December 9, 2015 Author Posted December 9, 2015 Hi, I've fixed it using joytokey. I found a great tutorial and all is sorted. They are great joysticks!
Metalzoic Posted December 9, 2015 Posted December 9, 2015 Hi, I've fixed it using joytokey. I found a great tutorial and all is sorted. They are great joysticks! Nice. Link to the tutorial? And if anyone knows of a button or toggle USB cut-off switch that would be great too.
gigapig Posted December 9, 2015 Posted December 9, 2015 Hi, I've fixed it using joytokey. I found a great tutorial and all is sorted. They are great joysticks! Yes please link to the tutorial, I would like to get a U 360 some day. I do find it odd why HyperSpin 1.4 did not work with it as joystick, spinner and track ball was fixed in that version.
Cougar888 Posted December 9, 2015 Author Posted December 9, 2015 Here is the link guys! I hope it helps you as much as it helped me FF past the stuff for the first 4:20mins if you've already downloaded Joytokey. I didn't set the RocketLauncher (HyperLaunch) or System keys FYI
Metalzoic Posted December 10, 2015 Posted December 10, 2015 Here is the link guys! I hope it helps you as much as it helped me FF past the stuff for the first 4:20mins if you've already downloaded Joytokey. I didn't set the RocketLauncher (HyperLaunch) or System keys FYI Ah thanks. I thought you meant you found a tutorial specific to U360's though. Did you get the rotary attachment for them too?
Metalzoic Posted December 10, 2015 Posted December 10, 2015 What do you need the USB cut-off for? If it's for enabling/disabling a device when certain games/systems are launched that can be done using the User Functions in RL. I wrote one for someone to enable/disable the Dolphin bar when certain games/systems were launched. I don't know what you're referring to with "user functions". I wanted the cutoff switch to act as if I'm pulling the controller out of the PC. I had wrote a script that would use DevCon to enable/disable joystick drivers with a combo-key press, but it no longer works in Win 10. Plus I'm not sure it would work the same with the U360 still plugged in.
Metalzoic Posted December 10, 2015 Posted December 10, 2015 In the RocketLauncher/Lib directory there's a User Functions.ahk which you can modify to run custom scripts. When I wrote the dolphin bar code (which also used devcon to enable/disable the device) I placed it in there with conditionals so it would only be enabled or disabled when certain games or systems were started in RL. Doing it that way just negates the need for an external bat/vbs/ahk script as it's all self contained in RL. That's cool. I had a thread months ago about anyone knowing how to use that feature and specifically how to use it with DevCon and I got no response. I also couldn't find any instructions on how to set it up to auto-launch. If your script works with Win 10 can you share it and how you set it up?
Cougar888 Posted December 10, 2015 Author Posted December 10, 2015 Ah thanks. I thought you meant you found a tutorial specific to U360's though. Did you get the rotary attachment for them too? The tutorial works for joysticks in general, it just shows you how to use JoytoKey and set it up in RL and HS. My 360's are working great now I build my cab in 2012 and I don't think the rotary part was out then. What does it do?
Metalzoic Posted December 10, 2015 Posted December 10, 2015 I can test it in Win10 tomorrow and if it works I can modify it for what you need and set it up. Thanks. After upgrading to win 10 my script shows DevCon working in the dos command line (drivers enabled, drivers disabled etc...), but in device manager it doesn't actually make the change. Worked perfect before I upgraded and when I went looking it seemed that this DevCon version (I'm using the 64bit version) is still the correct one for Win 10. Bummed.
Metalzoic Posted December 10, 2015 Posted December 10, 2015 The tutorial works for joysticks in general, it just shows you how to use JoytoKey and set it up in RL and HS. My 360's are working great now I build my cab in 2012 and I don't think the rotary part was out then. What does it do? The rotary lets the U360 also function as a rotary joystick so it spins left/right for games that used that to aim. Like Heavy Barrel, the Ikari Warriors Games, Gondomania etc... If you built your cab in 2012, does that mean you used a different frontend before and just recently tried Hyperspin in it? What front did you use before?
Cougar888 Posted December 10, 2015 Author Posted December 10, 2015 Just looked and I built it in 2011! Didn't realise it was that long ago! I used HyperSpin from the start. I made my own themes too.. It was a lot harder back then LOL My cab should be in the user cab section on here I think Edit: It's on this page: http://www.hyperspin-fe.com/topic/632-my-hyperspin-arcade-bartop-cab/page-2?hl=%2Bcougar+%2Bcade#entry23745
Metalzoic Posted December 10, 2015 Posted December 10, 2015 Just looked and I built it in 2011! Didn't realise it was that long ago! I used HyperSpin from the start. I made my own themes too.. It was a lot harder back then LOL My cab should be in the user cab section on here I think Nice. If you've used Hyperspin from the start, then how is it you just now noticed your U360's don't work with it? Or had you never hooked them up before now?
Cougar888 Posted December 10, 2015 Author Posted December 10, 2015 Haha! That was a different build before RL and all the cool stuff. It was all .ahk and modules and most things were awful to get running I've just redone everything from the ground up to make the install neater and more simple but had no idea how to set things up. I've been watching the Simply Austin tutorials on YouTube and that guy is great at them! He also gives loads of help in he comments! I need to get used to the new HyperTheme next so I can re-do my cab themes
gigapig Posted December 10, 2015 Posted December 10, 2015 Cougar, did you do any custom mapping with the 360 or are most games already set up for 4 or 8 way? Also did you buy any additional items like restrictor plates? It seems great for £37 and to have no noise and precision. Thanks
Cougar888 Posted December 10, 2015 Author Posted December 10, 2015 Cougar, did you do any custom mapping with the 360 or are most games already set up for 4 or 8 way? Also did you buy any additional items like restrictor plates? It seems great for £37 and to have no noise and precision. Thanks No custom mapping, just done some game mapping in the various Emu's.. Mame SF2 etc. No restrictor plates, never had a need for them, Pac-Man, Q-Bert etc seem to work great as is. They are great sticks but I would say get the stiffer springs, I have the default ones and they are a little weak
Metalzoic Posted December 11, 2015 Posted December 11, 2015 No custom mapping, just done some game mapping in the various Emu's.. Mame SF2 etc. No restrictor plates, never had a need for them, Pac-Man, Q-Bert etc seem to work great as is. They are great sticks but I would say get the stiffer springs, I have the default ones and they are a little weak I've made a few topics before asking q's about these joysticks. Never got any answers so now I'll ask you. -Do you have them plugged in both USB (for analog and mouse) and wired into an iPac? -Is the program for mimicking different joysticks (2-way, 4-way, diag etc,...) quick and easy to use? -How exactly do you set it so that it loads the correct joystick profile when a game launches? How does it load back to a "normal" HS profile after you close a game? -Can you set it per system or just per game/rom? -Found anything that they don't work quite right with besides HS?
Cougar888 Posted December 11, 2015 Author Posted December 11, 2015 I have them plugged into 2 USB ports on the motherboard, no iPac etc and never used the mouse option. I've never used the mapping software but it does seem really easy to set up. I just use the joysticks as is, I've never had a problem with different games. I've never a problem with them at all to be honest. Only niggle is the spring, like I said the default one is a bit light.. I don't mind it but you can get stiffer ones I believe
