SORHP Posted December 15, 2015 Posted December 15, 2015 I'm setting up SSIVAE on the ttx platform, and every time I load the game I have to go back into the settings menu and set it on freeplay and change my difficulty setting, I cannot figure out how to make the settings stick... any help? My Arcade Machines...
bobmoo79 Posted December 23, 2015 Posted December 23, 2015 This may be way off the mark but I know some ttx games needed a folder called sv in the game folder to save data. Can't hurt to try it. Let us know how you get on.
Metalzoic Posted December 23, 2015 Posted December 23, 2015 I'm setting up SSIVAE on the ttx platform, and every time I load the game I have to go back into the settings menu and set it on freeplay and change my difficulty setting, I cannot figure out how to make the settings stick... any help? Did you run the game through Arcade PC Loader first to set your settings? I haven't set up SSIVAE for TTX (just because the Ultra PC version is better), but if you set it up in that emu first you can choose your settings, then it should create an .exe in the folder (probably called SSIVAE_Launcher.exe) and that special exe should launch the game with your selected settings, resolution, language etc... At least that's how the others work.
