Dolphin crashes from Hyperspin
MarkWingens
Hi this is my first post,
for a couple of months now i have been creating my HyperSpin setup.
There is one emulator that keeps bugging me.
This is Dolphin. I want to use it for gamecube emulation, my problem is:
When i choose a game from within hyperspin the screen turns black (as it should) then Windows error comes up from: dolphin.exe is not responding.
When i run the same game from the emulator instead of using Hyperspin then the game runs perfectly.
I tried Dolphin 3.5 and 4.0 both of them have the same problem.
My hardware:
Asus H81-T
Intel Core i7-4770K
16GB RAM
Onboard Graphics
120GB mSATA SSD & 500 GB Seagate SSHD
Windows 10 Home 64-Bit
Full-HD Resolution (1920x1080)
Can any one help me?
Hard to say without knowing what all is running in your setup, and what versions.
The module in my RL states "v4.0 r6928" so I would stick to that particular version as it will have been tested and will work for sure.
It runs from emulator, so settings are good there, does it run through rocketlauncher (hyperlaunch if you're still using that)? If no, then it is most likely a setting in RL. If yes, then it is most likely a setting in HyperHQ.
I watched That YouTube video. before i started. I still use hyperlaunch. I've red About rocketlauncher is That one better?
HL is no longer in development. RL is the natural successor. It looks just the same but has many improvements. And it will auto update itself.
Sent from my SGH-I337M using Tapatalk
I tought Dolphin wasn't compatible with Hyperspin
Works fine.
I am running rocketlauncher now, when i use rocketlauncherUI i get no problems when i run in from hyperspin the emulator stops working and crashes when i tries to load the rom.
Any thoughts?
This is the log file:
07:35:41 PM |  HyperSpin Started
07:35:41 PM |  Going FullScreen
07:35:41 PM |  Checking for updates
07:35:41 PM |  Update Check Complete
07:35:41 PM |  Startup program unavailable
07:35:41 PM |  Error intializing joysticks
07:35:41 PM |  Menu Mode is multi
07:35:41 PM |  Loading Main Menu.xml
07:35:41 PM |  Main Menu.xml successfully loaded
07:35:42 PM |  Main Menu wheel loaded successfully
07:35:45 PM |  Loading Nintendo GameCube.xml
07:35:46 PM |  Main Menu.xml successfully loaded
07:35:46 PM |  Nintendo GameCube wheel loaded successfully
07:35:48 PM |  Launching Game
07:35:48 PM |  Using HyperLaunch
07:35:48 PM |  Getting Launcher path
07:35:48 PM |  Launcher located at D:\RocketLauncher\RocketLauncher.exe
07:35:48 PM |  Running Launcher
07:35:48 PM |  Launcher Command Line is: D:\RocketLauncher\RocketLauncher.exe "Nintendo GameCube" "the Legend of Zelda Twilight Princess"
07:35:57 PM |  Quiting Hyperspin
07:35:57 PM |  Bye!
