Skeeball_Fanatic Posted January 3, 2016 Posted January 3, 2016 Hi guys I'm trying to set up Daphne and in the tutorial I'm following (pincade on yt) the guy is playing about with the modules folder in his hyperspin folder. I don't know much about this so I'm just following step by step and then I noticed that my HS doesn't actually have a modules folder, let alone all the info that belongs inside it. Do I have to procure this folder or have I missed something? Thanks
rastan Posted January 3, 2016 Posted January 3, 2016 \Hyperspin\Modules Should be there... if not? I don't know what to tell ya....
gigapig Posted January 3, 2016 Posted January 3, 2016 The modules should be in your RocketLauncher folder which I can only assume you are using. More info required.
rastan Posted January 3, 2016 Posted January 3, 2016 On 1/3/2016 at 9:16 AM, gigapig said: The modules should be in your RocketLauncher folder which I can only assume you are using. More info required. I noticed I have a modules folder in my Hyperspin folder as well as in my Rocket launcher Folder...
rastan Posted January 3, 2016 Posted January 3, 2016 On 1/3/2016 at 3:06 PM, agent47 said: The modules folder in the HyperSpin directory is only needed for HyperLaunch. So if you're using RL you can delete the modules folder in the HS directory. kinda figured that... i never used HyperLaunchHQ because when I installed HS.. they said RL was the thing to use since it was updated. Thanks for the INFO.
32assassin Posted January 3, 2016 Posted January 3, 2016 to be more specific, the Modules folder in Hyperspin/Modules are for Hyperlaunch 2 HyperlaunchHQ was or is the GUI for Hyperlaunch3 their are multiple files you can delete from the default Hyperspin install if you are not using Hyperlaunch2 I pointed out witch ones in this post http://www.hyperspin-fe.com/topic/7625-hyperspin-1330-new-user-guide/
Skeeball_Fanatic Posted January 5, 2016 Author Posted January 5, 2016 On 1/3/2016 at 9:16 AM, gigapig said: The modules should be in your RocketLauncher folder which I can only assume you are using. More info required. On 1/3/2016 at 3:06 PM, agent47 said: The modules folder in the HyperSpin directory is only needed for HyperLaunch. So if you're using RL you can delete the modules folder in the HS directory. On 1/3/2016 at 11:04 PM, 32assassin said: to be more specific, the Modules folder in Hyperspin/Modules are for Hyperlaunch 2 HyperlaunchHQ was or is the GUI for Hyperlaunch3 their are multiple files you can delete from the default Hyperspin install if you are not using Hyperlaunch2 I pointed out witch ones in this post http://www.hyperspin-fe.com/topic/7625-hyperspin-1330-new-user-guide/ Thanks a lot guys. I think that settles it. Turns out I didn't need to do that step anyway to get it to work. Although now I've hit another snag that I'm going to make a new thread about (if I don't find an answer in an existing thread) so the fun continues. Cheers all.
