reznnate Posted January 8, 2016 Posted January 8, 2016 Woo hoo!! Grab the latest nightly and then use these settings in your .ini file exe=org.dolphinemu.dolphinemu/org.dolphinemu.dolphinemu.activities.MainActivity parameters=AutoStartFile
reznnate Posted January 17, 2016 Author Posted January 17, 2016 Annnnnd... it appears they broke it again (build 8717). Haven't had a chance to figure out why yet... Build 8608 did work if you want to confirm your wheel works.
reznnate Posted January 17, 2016 Author Posted January 17, 2016 Okay, figured it out. They changed it to: exe=org.dolphinemu.dolphinemu/org.dolphinemu.dolphinemu.ui.main.MainActivity parameters=AutoStartFile
Sting Posted January 20, 2016 Posted January 20, 2016 Does it have a double config like Retroarch??? My Shield TV controller doesn't work when loaded through Hyperspin, but automatically works when loaded through Dolphin App :/
reznnate Posted January 20, 2016 Author Posted January 20, 2016 On 1/20/2016 at 12:48 PM, Sting said: Does it have a double config like Retroarch??? My Shield TV controller doesn't work when loaded through Hyperspin, but automatically works when loaded through Dolphin App :/ I haven't run into this (YET) but they nightly builds seem to be in flux so nothing would surprise me.
Sting Posted January 20, 2016 Posted January 20, 2016 I'll play about with the settings and try a few versions
badhemi Posted February 8, 2016 Posted February 8, 2016 Any word on dolphin.? My controller doesn't work. Only to get side menu. Thanks
mihaliousa Posted February 9, 2016 Posted February 9, 2016 Which nightly version of dolphin is worling? Have dowmloaded several ones but none for them can be intslled on my shield tablet.
Sting Posted February 9, 2016 Posted February 9, 2016 Did you uninstall any previous versions first???
badhemi Posted February 9, 2016 Posted February 9, 2016 On 2/9/2016 at 10:24 PM, Sting said: Did you uninstall any previous versions first???no I first installed latest nightly and the controller doesn't work in game except menu. Then I uninstalled and tried 4.0 stable and the controller setting in menu worked but when I try to launch in hyperspin it says parameter is wrong. Thanks
reznnate Posted February 10, 2016 Author Posted February 10, 2016 The controller setup isn't defined by default. You need to setup the controller button mapping before launching any games.
ShaunB1980 Posted February 10, 2016 Posted February 10, 2016 I am new to this but I asked for an update b/c I just installed the latest nightly and there are no options to configure controllers, it just says Gamecub controllers but when I click on them nothing happens. I can get the Wii roms to load and load from Hyperspin but their is no controller input. I just ordered a Dolphinbar b/c the latest build has support for it now on android. https://forums.dolphin-emu.org/Thread-dolphin-bar-supportWell I just went to look to download and earlier version and saw a new version released today and comments mention the UI for controllers and Dolphinbarhttps://buildbot.dolphin-emu.org/builders/release-android/builds/172If todays release doesnt fix it then here is a fix for the button mappings I am about to try after I get the kids to bed:https://forums.dolphin-emu.org/Thread-missing-wii-mappings Quote Ta sonic. For anyone reading this with the same problem downgrade to an earlier build, map the buttons how you would like and copy them from the dolphin folder.Go back to the latest build run it once then paste the files back in. Works A treat keep up the good work im available to test titles if needed.
reznnate Posted February 10, 2016 Author Posted February 10, 2016 Sorry guys, I see the issue now. They've evolved the GUI tremendously and now it appears the button mapping isn't available. Either grab an older build, modify the .ini file/settings directly, or wait for imminent fix.
ShaunB1980 Posted February 10, 2016 Posted February 10, 2016 I just wanted to update, that today's release now shows the Wiimote menus and in game the only buttons that work bring up side menu and when I select settings nothing happens. http://dl.dolphin-emu.org/builds/dolphin-master-4.0-8886.apk However I still do not see an option to map buttons ? I am very new to dolphin, so if someone else can update to the latest apk and test to see what I am doing wrong MarioKart says unalbe to write to memory ?
badhemi Posted February 10, 2016 Posted February 10, 2016 On 2/10/2016 at 12:29 AM, reznnate said: The controller setup isn't defined by default. You need to setup the controller button mapping before launching any games.it won't let me it says controller settings coming soon
badhemi Posted February 10, 2016 Posted February 10, 2016 On 2/10/2016 at 1:14 AM, ShaunB1980 said: I just wanted to update, that today's release now shows the Wiimote menus and in game the only buttons that work bring up side menu and when I select settings nothing happens. http://dl.dolphin-emu.org/builds/dolphin-master-4.0-8886.apk However I still do not see an option to map buttons ? I am very new to dolphin, so if someone else can update to the latest apk and test to see what I am doing wrong MarioKart says unalbe to write to memory ? Same thing for me
badhemi Posted February 10, 2016 Posted February 10, 2016 On 2/10/2016 at 12:56 AM, reznnate said: Sorry guys, I see the issue now. They've evolved the GUI tremendously and now it appears the button mapping isn't available. Either grab an older build, modify the .ini file/settings directly, or wait for imminent fix. rez I tried the earlier build and changed the ini settings to main instead of ui.main and it has error on hyperspin for emulator
badhemi Posted February 10, 2016 Posted February 10, 2016 Well I downloaded the stable 1.4 set my input settings then moved the config files so I could uninstall and reinstall latest build. When I opened a game in hyperspin the game loaded and the controller worked but the game was slooooooow. Tried different cou and video setting with no luck.
reznnate Posted February 10, 2016 Author Posted February 10, 2016 Some games are still slow and frankly, recent builds of the emulator have gotten slower. I just tested the latest nightly Dolphin build and it's working well with Hyperspin.
badhemi Posted February 10, 2016 Posted February 10, 2016 On 2/10/2016 at 4:37 AM, reznnate said: Some games are still slow and frankly, recent builds of the emulator have gotten slower. I just tested the latest nightly Dolphin build and it's working well with Hyperspin.I loaded the same game before and after and it was perfect with new build. Just slow with the new config files pasted to it
ShaunB1980 Posted February 10, 2016 Posted February 10, 2016 I did eventually get the WiiMote to work using the DolphinBar on the Shield, so the kids/wife can use their Wii motes on the family hyperspin machine. Hey Rez, nice to meet you. Are you able to launch right into a Wii game from Hyperspin or to the select a game screen on Dolphin ?
reznnate Posted February 10, 2016 Author Posted February 10, 2016 On 2/10/2016 at 5:05 AM, ShaunB1980 said: Are you able to launch right into a Wii game from Hyperspin or to the select a game screen on Dolphin ? Yes, I can launch direclty into a Wii game from Hyperspin. If it's only loading the emulator app, you might be using the older exe/param setting.
