juicelee Posted January 10, 2016 Posted January 10, 2016 hello, i have a problem with some of the namco games running at 99% frame rate (ie pac land ,metro cross). i am using the latest mameuifx 169. i am trying to run hlsl ,which i think is the problem. i used my on board graphics card to run glsl before because of this problem. i have just brought a gtx 750ti and done a fresh install of mame and would like to use hlsl if possible. thanks my pc specs should be powerful enough i7 3770k 16 gb ram asus sabertooth gtx750 ti
joe35car Posted January 10, 2016 Posted January 10, 2016 That's because Pac-land and Metro-Cross runs at 60.606061 Hz. Make sure your monitor refresh rate is more then 60 Hz.
juicelee Posted January 11, 2016 Author Posted January 11, 2016 i am running 60hz 1080p tv , so stuck on 60hz max , i just turned of sync to monitor refresh rate and that solved that problem, so thank you very much mate
