vaderag Posted January 15, 2016 Posted January 15, 2016 I have an issue - i've just set up Hyperspin and Rocket Launcher for Mame and everything seems to be working fine. However... it only works on first rom and then nothing happens for follow ups. I've found out the reason is that HyperLaunch is now exiting, and when I close the process everything works fine again. HOWEVER... I'm supposed to be using RocketLauncher... my Settings.ini says it should: [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=MAME Hyperlaunch_Path=C:\RocketLauncher\RocketLauncher.exe But clearly it's not... If i delete the HyperLaunch file then it says it can't find it... Any ideas?
kylecp1979 Posted January 15, 2016 Posted January 15, 2016 Is you hyperHQ set to use rocketlauncer or hyperHQ to launch mame? open hyper HQ and select the mame wheel and see what check box is checked
vaderag Posted January 15, 2016 Author Posted January 15, 2016 Are you using HyperSpin 1.4? Yep, i believe so Yes, everything set in Hyper HQ - HyperLaunch is set (but the ini points to RL)
alcoatjez Posted January 15, 2016 Posted January 15, 2016 Check my reply at the RL forums Verstuurd vanaf mijn GT-I9195 met Tapatalk
vaderag Posted January 15, 2016 Author Posted January 15, 2016 Check my reply at the RL forums Verstuurd vanaf mijn GT-I9195 met Tapatalk I wish i'd made that mistake, but unfortunately it's linked to HyperSpin http://prntscr.com/9qi2zy
vaderag Posted January 15, 2016 Author Posted January 15, 2016 You should verify that you're using HS 1.4. HS 1.3 wasn't meant to use anything but HL so if you're still on 1.3 the typical 1.4 configuration will not work. If you hover your mouse over the HyperSpin.exe for a few seconds the "File version" will tell you what version you're using. You can also right click the exe, select Properties, and look for the version on the Details tab. Dangnammit. I'd downloaded the Zip, extracted it, but to the wrong place... copying over right now and will test...
vaderag Posted January 15, 2016 Author Posted January 15, 2016 Okay, so a step in the right direction! BUT now I get a different issue... An error after selecting a game saying "Cannot Find C:\RocketLauncher\RocketLauncherUI\Databases\Mame.xml" Now... initially, that didnt exist. BUT I have no issues loading the games direct from RL... However, for sake of argument, i've copied over the xml from my HS folder and still get the same issue... EDIT: Nevermind - i missed a Mame folder after the Databases... works now Not sure why it needs the duplicate there, but nevermind!! Thanks for all the help!!
vaderag Posted January 15, 2016 Author Posted January 15, 2016 I've already done that... still wanted the xml..
vaderag Posted January 15, 2016 Author Posted January 15, 2016 Yeah, its def set there... (just double checked, but it was one of the first things I did...) What else might cause that then?
vaderag Posted January 15, 2016 Author Posted January 15, 2016 Sorry to keep asking but I want to make sure that we understand each other. You have it set just like the first image? I ask because you said it was one of the first things you did and setting it like shown in the second one is one of the first steps in the tutorial. Not having it set like the first is the only thing I know of that will cause that error. Thank you for persevering. I really should pay slightly more attention!! You were totally right - I had done the second screenshot but not the first - it now works without that xml Thank you again
