carrie1979 Posted January 22, 2016 Posted January 22, 2016 Hi,Rick here,,new here also,have tried so many times to run HS with mame and failed each time,would anyone like to take control of my pc and fix it ?!!!! i have hs,rl,hq set up but i done something wrong and dnt know what,any help would be tip top,,thanks
Spawk Posted January 23, 2016 Posted January 23, 2016 Hi Rick. You need to have a better idea of work flow. Follow these steps when adding any system: 1. Make sure games play and exit from emulator (in your case mame) 2. Make sure you can audit and launch games in RocketLauncher 3. Only when the above two are correct should you then try in HS. Sent from my SGH-I337M using Tapatalk
gigapig Posted January 23, 2016 Posted January 23, 2016 Post your logs, both HyperSpin and RocketLauncher.
