badhemi Posted January 30, 2016 Posted January 30, 2016 Hello I got mame 2003 in retroarch to play my AAE games but can't get it to work in hyperspin. What would be the parameter? I put mame_2003_libretro_android_so. With no lucky!!!
Sting Posted January 30, 2016 Posted January 30, 2016 Have you tried (cores/mame2003_libretro_android.so)
badhemi Posted January 30, 2016 Author Posted January 30, 2016 Have you tried (cores/mame2003_libretro_android.so)yes that's what I put. I copied over mame 4 droid from my MAME ini but that didn't work either which is weird. When I click on AAE wheel it just kicks me right back out doesn't show games. [exeinfo] path=H:\hyperspin\Emulators\AAE\ rompath=/storage/usbdrive/Games/AAE/roms userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=zip parameters=cores/mame_2003_libretro_android.so searchsubfolders=true pcgame=false winstate = HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only = false themes_only = true wheels_only = false roms_only = false [themes] use_parent_vids=true use_parent_themes=true animate_out_default=false reload_backgrounds=true [wheel] alpha=.15 small_alpha = 1 style = normal speed = high pin_center_width = 500 horz_wheel_y = 512 vert_wheel_position=right y_rotation = right norm_large = 360 norm_small = 230 vert_large = 400 vert_small = 240 pin_large = 500 pin_small = 200 horz_large = 240 horz_small = 150 letter_wheel_x = 800 letter_wheel_y = 384 text_width = 700 text_font = Style2 small_text_width = 260 large_text_width = 400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance = 0 shadow_angle = 45 shadow_color=0x000000 shadow_alpha = 1 shadow_blur = 0 [pointer] animated=true x = 975 y = 384 [video defaults] path=H:\hyperspin\Media\Mame\Video\ [sounds] game_sounds = true wheel_click = true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=false remove_info_text=true use_last_game=true last_game=thunderl random_game=false start_on_favorites=false [special Art A] default=true active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [special Art C] active=false x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active = true show_year = true show_manf = true show_description = true text_color1 = 0xFFFFFF text_color2 = 0xFFFFFF stroke_color = 0x000000 text_font = Style3 text1_textsize = 26 text1_strokesize = 7 text1_x = 32 text1_y = 610 text2_textsize = 36 text2_strokesize = 8 text2_x = 30 text2_y = 640
badhemi Posted January 30, 2016 Author Posted January 30, 2016 I see you said mame2003 not mame_2003. I'll try that when I get home thanks sting.
reznnate Posted January 30, 2016 Posted January 30, 2016 One idea is that perhaps the rom names for AAE PC emulator are different from MAME. I don't think this is true. I THINK they match. So my other suggestion is to confirm if your AAE wheel has a basic default theme. If, so you'd want to disable your filter: themes_only = true to false
badhemi Posted January 30, 2016 Author Posted January 30, 2016 One idea is that perhaps the rom names for AAE PC emulator are different from MAME. I don't think this is true. I THINK they match. So my other suggestion is to confirm if your AAE wheel has a basic default theme. If, so you'd want to disable your filter: themes_only = true to false I have AAE in there own roms. Games/AAE/roms in pc game, database ect. I tried retroarch to mame2003 and it didn't work so I changed it back to mame4droid. I tried filter and no go. I'm confused as why this won't work.
reznnate Posted January 30, 2016 Posted January 30, 2016 So can you clarify what isn't working? Are games running in retroarch and mame4droid outside of RA? Are games not showing up in wheel?
badhemi Posted January 31, 2016 Author Posted January 31, 2016 So can you clarify what isn't working? Are games running in retroarch and mame4droid outside of RA? Are games not showing up in wheel? Sent from my Nexus 6P using Tapatalk yes they play outside. When I open hyperspin and go to AAE wheel and click it it just kicks back out doesn't show games
reznnate Posted January 31, 2016 Posted January 31, 2016 The theme filter set to true might have caused that. This exact aae wheel setup works with PC Hyperspin?
badhemi Posted January 31, 2016 Author Posted January 31, 2016 The theme filter set to true might have caused that. This exact aae wheel setup works with PC Hyperspin?no it doesn't work in pc. I tried the filter change. In scratching my head on this one
reznnate Posted January 31, 2016 Posted January 31, 2016 If you can setup ADB to capture a log, that might help your debug effort. But I'd just triple check the filenames, folders all match in /databases, /settings, and /media. If all of the filters are off, the emulator and rom settings don't matter YET.
badhemi Posted January 31, 2016 Author Posted January 31, 2016 If you can setup ADB to capture a log, that might help your debug effort. But I'd just triple check the filenames, folders all match in /databases, /settings, and /media. If all of the filters are off, the emulator and rom settings don't matter YET. I'm a rookie at all this. Not familiar with what your saying.
reznnate Posted January 31, 2016 Posted January 31, 2016 No problem. Google 'Android adb logcat' for more info if you are up to it. Must enable developer mode too (tap settings->about->build 7 times). Enable adb debugging. On Shield ATV, you can connect WiFi after confirming security check over USB.Otherwise, just ensure all names of files and folders match.
badhemi Posted January 31, 2016 Author Posted January 31, 2016 No problem. Google 'Android adb logcat' for more info if you are up to it. Must enable developer mode too (tap settings->about->build 7 times). Enable adb debugging. On Shield ATV, you can connect WiFi after confirming security check over USB. Otherwise, just ensure all names of files and folders match. Sent from my Nexus 6P using Tapatalk Thanks I appreciate all your help. Anyone get turbographics 's to work on Android.? I got it to open games then load on hyperspin thru retroarch but screen is black
reznnate Posted January 31, 2016 Posted January 31, 2016 Weird PCE/turbo graphics works fine for me with Retroarch core.
badhemi Posted January 31, 2016 Author Posted January 31, 2016 Weird PCE/turbo graphics works fine for me with Retroarch core. Sent from my Nexus 6P using Tapatalk that works but I meant turbographics CD Damn auto spell correct.
reznnate Posted January 31, 2016 Posted January 31, 2016 Cd works too but likely has bios dependency. Need those files in retroarch 'system' folder.
badhemi Posted January 31, 2016 Author Posted January 31, 2016 Cd works too but likely has bios dependency. Need those files in retroarch 'system' folder.which emulator you using? Also where can I find reicadt nightly build to fix my game launch so it loads in hyperspin instead of going to reicast
reznnate Posted January 31, 2016 Posted January 31, 2016 There is a sticky post in the emulators forum with links to nightly builds of important emulators. Regarding PC Engine, sounds like you got lucky and the .ini file does exist. Perhaps you copied from somewhere else and it had the proper parameters.
badhemi Posted February 1, 2016 Author Posted February 1, 2016 No problem. Google 'Android adb logcat' for more info if you are up to it. Must enable developer mode too (tap settings->about->build 7 times). Enable adb debugging. On Shield ATV, you can connect WiFi after confirming security check over USB. Otherwise, just ensure all names of files and folders match. fixed the AAE on pc. Found no data base in ini. Lucky there was a back up copy. Now hopefully I can get it running in android
badhemi Posted February 1, 2016 Author Posted February 1, 2016 Well I got it going on android but it quickly loads game then kicks back out to AAE wheel
reznnate Posted February 1, 2016 Posted February 1, 2016 probably a rom version mismatch.. try each of the mame emulator versions and if that doesn't work, you'll need to copy working mame romset manually. If you go through this pain, please post the fixes for me!
badhemi Posted February 1, 2016 Author Posted February 1, 2016 probably a rom version mismatch.. try each of the mame emulator versions and if that doesn't work, you'll need to copy working mame romset manually. If you go through this pain, please post the fixes for me! ok right now it's on mame4droid. I'll try mame 2003.
badhemi Posted February 1, 2016 Author Posted February 1, 2016 Well I tried mame 2003 and 90% of games load and play. 20 % screens black. And 70% have no sound. So I'm getting somewhere. I'll try other mames
