vaderag Posted February 18, 2016 Posted February 18, 2016 Does anyone have a list of systems that work well with arcade controls? I.e. Nes will work well as it's 4 way pad and buttons Gamecube will not work well as dual analogue It seems to me that there are a load of edge cases as well... e.g. Amiga - if you can set the games to load automatically (which i presume you can - i havent looked) then they could be controlled with a joystick so would probably work fine I'm in the process of building my cab and I would like to define an "insert pad" fade for systems that don't work with arcade controls.
swimminginthoughts Posted February 18, 2016 Posted February 18, 2016 I started down this road, then just got two wireless controllers that are always connected. Here's what I think I have setup: I don't have any that are arcade controls only, but I have: N64Wii (and Wiiware) Dreamcast Saturn and anything Playstation set as controller only. There are some systems like SNES where you can use either, but with the L & R buttons, it makes it awkward on the control panel so I always use the controller for those. I have it setup so you can use the control panel and then switch to the controller on the fly if you want to.
griffin518 Posted February 18, 2016 Posted February 18, 2016 You could definitely say anything including and prior to SNES/Sega Genesis. A huge percentage of Sony PS1 games work just fine as well. I think it starts to get spotty with N64, PS1, Dreamcast and onward. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
vaderag Posted February 18, 2016 Author Posted February 18, 2016 I started down this road, then just got two wireless controllers that are always connected. Here's what I think I have setup: I don't have any that are arcade controls only, but I have: N64 Wii (and Wiiware) Dreamcast Saturn and anything Playstation set as controller only. There are some systems like SNES where you can use either, but with the L & R buttons, it makes it awkward on the control panel so I always use the controller for those. I have it setup so you can use the control panel and then switch to the controller on the fly if you want to. Out of interest how do you make it so you can switch on the fly?
swimminginthoughts Posted February 18, 2016 Posted February 18, 2016 I set everything up with Joy2Key that I could—that will give you the ability to use the control panel or controllers at the same time. I know people complain about key mappers because they introduce lag but my cabinet only gets played when we're drinking—no one cares and no one is going to play a 15 hour game on my cabinet!
