Losing focus!!
hyperspidey
My hyperspin has been working perfectly for a week now, but all of a sudden, when I exit a game (using any emulator) hyperspin is frozen when it returns and I need to click it to continue.. Has anyone experienced this? I reset all of my mame and hyperspin files back to when it was working properly, but no luck! It also happens whether or not Im using my tankstick or directly from my keyboard. Driving me nuts... Any ideas?
In RLUI check your Global -> Settings -> Main Settings -> "Exit" section (top right) -> "Restore Frontend on Exit" setting. If "false," try "Restore." If "Restore," try "Restore and Click."
RocketLauncherUI. You'll want to update... that's extremely dated by a number of years. Musta been a while :P
Are you on windows 10? If so, check when windows did it's last update. A few weeks ago I had a string of problems with programs crashing on exit and with outlook freezing. Uninstalled what was then the last windows update and everything went back to normal.
I am so glad I didn't upgrade my HS PC to Windows 10 after hearing all the issues people are having with it on forums @_@
that happens to me with certain emulators...  not exactly sure why it happens but I know some times if I have bezels or fades set... it also happens.
I have all of my emulators set to restore & click and still get that problem... I'll figure it out sooner or later.
Spent all morning upgrading to rocketlauncher, got it running for Mame but the issue still persists. Uninstalled yesterdays windows updates, no luck there either.. Not sure what to do, abandon hyperspin? This one little bug is going to squash my whole project!
Have you checked your AVirus and Windows Defender to be sure it hasn't quarantined anything?
That can cause behavior similar to what you mention. I thought my whole setup had freaked out for a week until I realized the a WDefender update just got suspicious of HS.
The problem came back and I narrowed it down. Its happening when I plug in the tv as a duplicate display. If you have this problem as well, set your computer to ONLY display on the secondary screen.. Cleared up the problem
Good you got it figured out, hopefully this thread can help someone else out down the road.
I'm surprised you didn't even mention you were running multiple displays.
