Hyperspin 1.3.3/RocketLauncher troubles
newvillepa
Hello, my name is Crystal, and I am having noob issues. I was launching two emulators (MAME and Stella) perfectly, and now when I select a game in either from the wheel, nothing happens. I'm not sure what I did to screw this up. Here is my Hyperspin log. I waited a minute after launching the Wizard of War game, 06:02:31. I escaped out of the menu at 06:03:42. It's like it hangs at........HyperLaunch Command Line is: C:\hyperspin133\HyperLaunch.exe "MAME" "wow"
06:01:37 PM |  HyperSpin Started
06:01:37 PM |  Going FullScreen
06:01:38 PM |  Checking for updates
06:01:38 PM |  Update Check Complete
06:01:38 PM |  Startup program unavailable
06:01:38 PM |  Playing intro video
06:01:56 PM |  Error intializing joysticks
06:01:56 PM |  Menu Mode is multi
06:01:56 PM |  Loading Main Menu.xml
06:01:56 PM |  Main Menu.xml successfully loaded
06:01:57 PM |  Main Menu wheel loaded successfully
06:02:18 PM |  Loading MAME.xml
06:02:18 PM |  Main Menu.xml successfully loaded
06:02:19 PM |  MAME wheel loaded successfully
06:02:22 PM |  MAME wheel loaded successfully
06:02:23 PM |  MAME wheel loaded successfully
06:02:24 PM |  MAME wheel loaded successfully
06:02:31 PM |  Launching Game
06:02:31 PM |  Using HyperLaunch
06:02:31 PM |  Getting HyperLaunch path
06:02:31 PM |  HyperLaunch located at C:\hyperspin133\HyperLaunch.exe
06:02:31 PM |  Running HyperLaunch.exe
06:02:31 PM |  HyperLaunch Command Line is: C:\hyperspin133\HyperLaunch.exe "MAME" "wow"
06:03:42 PM |  Loading Main Menu.xml
06:03:42 PM |  Main Menu.xml successfully loaded
06:03:43 PM |  Main Menu wheel loaded successfully
06:03:44 PM |  Exit program unavailable
06:03:44 PM |  Quiting Hyperspin
06:03:44 PM |  Bye!
Here is my settings.ini file:
[Main]
Hyperlaunch_Path=C:\RocketLauncher\RocketLauncher.exe
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=MAME
Use_Last_Game=true
[Resolution]
FullScreen=true
Width=800
Height=600
Scanlines_Active=false
Scanlines_Image=
Scanlines_Scale=2
Scanlines_Alpha=0.1
[Optimizer]
CPU_Priority=normal
Quality=HIGH
Image_Smoothing=true
Animated_Backgrounds=true
Inter_Backgrounds=false
Level1_Backgrounds=true
Level2_Backgrounds=true
Level3_Backgrounds=false
Level4_Backgrounds=false
Special_Backgrounds=true
Wait_For_Special=false
Animated_Artworks=true
Level1_Artworks=true
Level2_Artworks=true
[introVideo]
Use_Intro=true
Stop_On_Keypress=true
[sound]
Master_Volume=100
Video_Volume=100
Wheel_Volume=20
Interface_Volume=100
[AttractMode]
Active=true
Time=60
MaxSpinTime=10
HyperSpin=true
Wait_For_Video=false
[Keyboard]
Key_Delay=true
[P1 Controls]
Start=13
Exit=27
Up=38
Down=40
SkipUp=37
SkipDown=39
SkipUpNumber=70
SkipDownNumber=86
HyperSpin=32
Genre=71
Favorites=76
[P2 Controls]
Start=69
Exit=81
Up=87
Down=83
SkipUp=65
SkipDown=68
SkipUpNumber=74
SkipDownNumber=77
HyperSpin=88
Genre=72
Favorites=90
[P1 Joystick]
Enabled=false
Joy=0
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
SkipDown=Analog_Right
SkipUpNumber=Button_3
SkipDownNumber=Button_4
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[P2 Joystick]
Enabled=false
Joy=1
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[Trackball]
Enabled=false
Sensitivity=90
[spinner]
Enabled=false
Sensitivity=90
[startup Program]
Executable=
Paramaters=
Working_Directory=
WinState=
[Exit Program]
Executable=
Paramaters=
Working_Directory=
WinState=NORMAL
[LEDBlinky]
Active=false
Path=
[HiScore]
Active=false
Y=550
Delay=2
[HyperLaunch]
Last_System=
Last_Rom=
Exit_Script_Key=~q & ~s
Exit_Emulator_Key=Esc
Toggle_Cursor_Key=t
MultiGame_Key=NumpadSub
MultiGame_Select_Key=Enter
MultiGame_Exit_Key=Esc
Path_To_Daemontools=
Path_To_CPWizard=
Fade_In_Interrupt_Keys=anykey
Keymapper_Path=
Keymapper_Profiles_Path=C:\hyperspin133\Keymapper Profiles\
Thank you in advance!!!
Thankfully they have a rocketlauncher update tool that goes into hyperspin and adds a bunch of parameters to hyperhq, and changes a bunch of file associations to work with rocketlauncher.  Did you go through their tutorial on rlauncher.com  ?
you can use RL  with Hyperspin 1.3.2 and 1.3.3,  but you have to use the transition tool
you cant use this full path  with 1.3.3
you have to use
C:\RocketLauncher\
the full path was implemented  on the HS 1.4 updated.
if you upgrade to 1.4 you can drag and drop the HS exe into your HS install folder and you should be up and running.  (Assuming everything else is set up correctly)
and you should rename your Hyperspin folder from
Hyperspin133  to  Hyperspin
default(expected) paths and names will make things much easier on you
The only reason1.3 is still available is that 1.4 hasn't been packaged as a full install you should definitely be running 1.4
HyperSpin Website Admin Team
Also Visit EmuMovies.com
