Xpadder problems
I was wondering if there is a way to get Hyperspin to launch Xpadder every time you open Hyperspin? It seems currently if I don't open Xpadder myself manually before Hyperspin, it doesn't open at all, and I don't get any use of my wireless Xbox 360 controller.
Also, even if I launch Xpadder manually first, and can use the controller in the Hyperspin wheels and while playing emulator games, Xpadder will close itself down within a few minutes and I have no choice but to use the escape button on the keyboard to get all the way out of Hyperspin. I'm not sure why Xpadder would just close like that.
If anyone has any thoughts for either of the above please let me know and thanks in advance. I'm pretty new at this and just trying to get everything running correctly.
You can open HyperHQ (Hyperspin's config utility not HL) and set Xpadder to launch when HyperSpin starts (Under startup options tab). It won't auto start with HS without doing this as HyperLaunch is the only program that launches Xpadder automatically & switches the profiles (When the Keymapper setting is enabled) - so it wont normally kick in until you launch an Emulator/Game. Sorry, not great at explaining things...
Thanks Urban. For the startup program I entered the full path to my Xpadder executable. However I set it to minimized using the arrow and when I leave HyperHQ and open it again that setting is never saved. Do I need to enter something in the params box? If so, would you be able to tell me exactly what? I don't know why my selection on that arrow is not saving. Also, in HLHQ, do I need to setup a profile for each system, or if I have the global profile setup and have each system set to use global settings, should that work? Thanks.
