Bruiserh89 Posted March 22, 2016 Posted March 22, 2016 Hey guys. This seems a strange one to me. All of a sudden I cant exit out of hyperspin emulators using the esc button. I have to Ctl alt delete and close the program. I cant find any forum threads that addresses this and dont know how to fault find. Any ideas?
Metalzoic Posted March 22, 2016 Posted March 22, 2016 If you are using RocketLauncher have you check to make sure the exit button didn't get changed in the RL settings?
Bruiserh89 Posted March 22, 2016 Author Posted March 22, 2016 If you are using RocketLauncher have you check to make sure the exit button didn't get changed in the RL settings? Thanks. Do I look in the Global RL ini? It says exit is set to escape [Desktop] Hide_Cursor=false Hide_Desktop=false Hide_Taskbar=false Hide_Emu=false Hide_Front_End=false [Settings] Rom_Match_Extension=false Block_Input=0 Error_Level_Reporting=false Lock_Launch=false Screen_Rotation_Angle=0 Mode_Rotation_Angle= Set_Resolution= [Exit] Restore_Front_End_On_Exit=false Exit_Emulator_Key=~Esc Restore_Resolution_On_Exit=false [Virtual Drive] Virtual_Drive_Enabled=true Virtual_Drive_Use_SCSI=true [CPWizard] CPWizard_Enabled=false CPWizard_Delay=8000 CPWizard_Params=-minimized -timeout 9000 CPWizard_Close_On_Exit=false [Ultimarc] ServoStik_Enabled=false ServoStik_Exit_Mode=false UltraMap_Enabled=false [LEDBlinky] LEDBlinky_Enabled=false LEDBlinky_System_Name= [Fade] Fade_In=false Fade_In_Duration=500 Fade_In_Transition_Animation=DefaultAnimateFadeIn Fade_In_Delay=0 Fade_In_Exit_Delay=0 Fade_Out=false Fade_Out_Extra_Screen=false Fade_Out_Duration=500 Fade_Out_Transition_Animation=DefaultAnimateFadeOut Fade_Out_Delay=0 Fade_Out_Exit_Delay=0 Fade_Layer_Interpolation=7 Fade_Mute_Emulator=false Fade_Use_Backgrounds=false Fade_Base_Resolution_Width=1920 Fade_Base_Resolution_Height=1080 Fade_Layer_1_Color=FF000000 Fade_Layer_1_Align_Image=Stretch and Lose Aspect Fade_Layer_2_Alignment=Stretch and Lose Aspect Fade_Layer_2_X=0 Fade_Layer_2_Y=0 Fade_Layer_2_Adjust=1 Fade_Layer_2_Padding=0 Fade_Layer_2_Prefix=Extra Layer 1 - Console Fade_Layer_3_Alignment=Center Fade_Layer_3_X=450 Fade_Layer_3_Y=450 Fade_Layer_3_Adjust=1 Fade_Layer_3_Padding=0 Fade_Layer_3_Speed=750 Fade_Layer_3_Animation=DefaultFadeAnimation Fade_Layer_3_7z_Animation=DefaultFadeAnimation Fade_Layer_3_Image_Follow_7z_Progress=true Fade_Layer_3_Type=imageandbar Fade_Layer_3_Repeat=1 Fade_Layer_3_Shadow_Image_Transparency=30 Fade_Layer_3_Static_Alignment=No Alignment Fade_Layer_3_Static_X=0 Fade_Layer_3_Static_Y=870|1575 Fade_Layer_3_Static_Adjust=1 Fade_Layer_3_Static_Padding=0 Fade_Layer_3_Static_Prefix=Info Bar Fade_Layer_4_Pos=No Alignment Fade_Layer_4_X=1792|952 Fade_Layer_4_Y=891|1596 Fade_Layer_4_Adjust=1 Fade_Layer_4_Padding=0 Fade_Layer_4_FPS=50 Fade_Animated_Gif_Transparent_Color=FFFFFF Fade_Bar_Window=Image Fade_Bar_Window_X= Fade_Bar_Window_Y= Fade_Bar_Window_Width=900 Fade_Bar_Window_Height= Fade_Bar_Window_Radius=30 Fade_Bar_Window_Margin=30 Fade_Bar_Window_Hatch_Style=8 Fade_Bar=7zOnly Fade_Bar_Non7z_Progress_Time=0 Fade_Bar_Back=true Fade_Bar_Back_Color=FF555555 Fade_Bar_Height=30 Fade_Bar_Radius=10 Fade_Bar_Color=DD00BFFF Fade_Bar_Hatch_Style=8 Fade_Bar_Percentage_Text=true Fade_Bar_Info_Text=true Fade_Bar_X_Offset=0 Fade_Bar_Y_Offset=150 Fade_Rom_Info_Description=filtered text Fade_Rom_Info_System_Name=image Fade_Rom_Info_Year=text with label Fade_Rom_Info_Manufacturer=text with label Fade_Rom_Info_Genre=disabled Fade_Rom_Info_Rating=image Fade_Rom_Info_Order=Description|SystemName|Year|Manufacturer|Genre|Rating Fade_Rom_Info_Text_Placement=User Defined Fade_Rom_Info_Text_Margin=7 Fade_Rom_Info_Text_1_Options=w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular Fade_Rom_Info_Text_2_Options=w400 x8 y15 cFF555555 r4 s60 Bold Fade_Rom_Info_Text_3_Options=w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular Fade_Rom_Info_Text_4_Options=w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular Fade_Rom_Info_Text_5_Options=cFF555555 r4 s42 Bold Fade_Rom_Info_Text_6_Options=h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular Fade_Stats_Number_of_Times_Played=text with label Fade_Stats_Last_Time_Played=text with label Fade_Stats_Average_Time_Played=text with label Fade_Stats_Total_Time_Played=text with label Fade_Stats_System_Total_Played_Time=text with label Fade_Stats_Total_Global_Played_Time=text with label Fade_Stats_Info_Order=Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time Fade_Stats_Info_Text_Placement=topRight Fade_Stats_Info_Text_Margin=7 Fade_Stats_Info_Text_1_Options=cFFB4B4B4 r4 s22 Bold Fade_Stats_Info_Text_2_Options=cFFB4B4B4 r4 s22 Bold Fade_Stats_Info_Text_3_Options=cFFB4B4B4 r4 s22 Bold Fade_Stats_Info_Text_4_Options=cFFB4B4B4 r4 s22 Bold Fade_Stats_Info_Text_5_Options=cFFB4B4B4 r4 s22 Bold Fade_Stats_Info_Text_6_Options=cFFB4B4B4 r4 s22 Bold Fade_Text_1_X=0 Fade_Text_1_Y=0 Fade_Text_1_Options=cFFB4B4B4 r4 s30 Right Bold Fade_Text_1=Loading Game Fade_Text_2_X=0 Fade_Text_2_Y=0 Fade_Text_2_Options=cFFB4B4B4 r4 s30 Right Bold Fade_Text_2=Extraction Complete, Ready Fade_Text_3=Loading Game Fade_Text_4=Loading Complete Fade_Font=Bebas Neue Fade_System_And_Rom_Layers_Only=false Fade_Extraction_Time=disabled Fade_Extraction_Time_Text_X=0 Fade_Extraction_Time_Text_Y=0 Fade_Extraction_Time_Text_Options=cFF555555 r4 s20 Bold Fade_Layer_2_W= Fade_Layer_2_H= Fade_Layer_3_W= Fade_Layer_3_H= Fade_Layer_3_Static_W= Fade_Layer_3_Static_H= Fade_Layer_4_W=128 Fade_Layer_4_H= Fade_Click_Through =false Fade_Rom_Info_Developer=text with label Fade_Rom_Info_Publisher=text with label Fade_Rom_Info_Text_7_Options=h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular [7z] 7z_Enabled=false 7z_Extract_Path=..\..\NVIDIA\TEMP GAME HS 7z_Attach_System_Name=false 7z_Delete_Temp=true 7z_Sounds=true [Keymapper] Keymapper_Enabled=false Keymapper_AHK_Method=false Keymapper=xpadder JoyIDs_Enabled=false JoyIDs_Preferred_Controllers= JoyIDs_Preferred_Controllers_On_Exit= [VJoy] VJoy_Enabled=false [MultiGame] MultiGame_Enabled=false MultiGame_Background_Color=FF000000 MultiGame_Side_Padding=0.2 MultiGame_Base_Resolution_Width=1920 MultiGame_Base_Resolution_Height=1080 MultiGame_Y_Offset=500|800 MultiGame_Font=Arial MultiGame_Text_1_Options=x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic MultiGame_Text_1_Text=Please select a game MultiGame_Text_2_Options=w96p cFFFFFFFF r4 s50 Center BoldItalic MultiGame_Text_2_Offset=100 MultiGame_Use_Sound=true MultiGame_Sound_Frequency=300 MultiGame_Exit_Effect=none MultiGame_Selected_Effect=rotate MultiGame_Use_Game_Art=false MultiGame_On_Launch=false [Pause] Pause_Enabled=false [Bezel] Bezel_Enabled=false Bezel_Instruction_Cards_Enabled=false [Statistics] Statistics_Enabled=true [Rom Mapping] Rom_Mapping_Enabled=false Rom_Mapping_Launch_Menu_Enabled=false Default_Menu_List=FullList Single_Filtered_Rom_Automatic_Launch=false First_Matching_Ext=false Show_All_Roms_In_Archive=true Number_of_Games_by_Screen=7 Menu_Width=400 Menu_Margin=65 Text_Font=Bebas Neue Text_Options=cFFFFFFFF r4 s60 Bold Disabled_Text_Color=ff888888 Text_Size_Difference=7 Text_Margin=15 Title_Text_Font=Bebas Neue Title_Text_Options=cFFFFFFFF r4 s90 Bold Title2_Text_Font=Bebas Neue Title2_Text_Options=cFFFFFFFF r4 s22 Bold Game_Info_Text_Font=Bebas Neue Game_Info_Text_Options=cFFFFFFFF r4 s22 Regular Background_Brush=aa000000 Column_Brush=33000000 Button_Brush1=6f000000 Button_Brush2=33000000 Background_Align=Stretch and Lose Aspect Language_Flag_Width=55 Language_Flag_Separation=7 Hide_Parent=false Game_Name_Text_Font=Bebas Neue Game_Name_Text_Options=cFFFFFFFF r4 s40 Regular [Keyboard Encoder] Keyboard_Encoder= Keyboard_Encoder_Enabled=false
Bruiserh89 Posted March 22, 2016 Author Posted March 22, 2016 When posting large amounts of text please use code tags. It keeps the post from being super long and makes the text easier to read. Thanks! Cheers mate. Sorry. Will do in future.
gec5741 Posted March 22, 2016 Posted March 22, 2016 I'd look in hyperHQ as well under the system your using to make sure the wheel setting/navigation is set to escape for exit. I'm new here but I had changed things there for some of my navigation.
Bruiserh89 Posted March 22, 2016 Author Posted March 22, 2016 I'd look in hyperHQ as well under the system your using to make sure the wheel setting/navigation is set to escape for exit. I'm new here but I had changed things there for some of my navigation. Thanks mate. Had a look at that. In the controls area you mean? Esc is set to exit for player 1 in the emulator wheel settings. I also have this problem with other emulators.
Bruiserh89 Posted March 22, 2016 Author Posted March 22, 2016 I found the answer. It wasnt an issue with RL or hyperspin settings. It was an issue because I had an old version of photoshop open (was getting media at the time). Apparently according to my google search. This can stop the escape button working and you have to use shift+escape instead.
gec5741 Posted March 22, 2016 Posted March 22, 2016 Crazy! I'll keep that one in mind. Glad you got it working.
