Vivanonno in Hyperspin
akiles500
Brian it didn´t work vivanonno in hyperspin with is configuration:
[exe info]
path = C:\HyperSpin\Emulators\Vivanonno\
rompath = C:\HyperSpin\Emulators\Vivanonno\roms\
userompath = true
exe =vivanonno.exe
romextension = zip
parameters =
searchsubfolders = false
pcgame = false
winstate = HIDDEN
hyperlaunch = true
Hyperlaunch.ahk:
;***********************************VIVANONNO*************************************
else if (systemName = "Vivanonno" && executable = "vivanonno.exe")
hideDesktop()
Hotkey, %exitEmulatorKey%, CloseProcess
RunWait, %executable% "%romPath%%romName%%romExtension%", %emuPath%, Hide UseErrorLevel
It miss give support in hyperlaunch to PC-FX and Vivanonno emulator because didn´t work .
Out hyperspin work perfect
I know that wouldnt work. Vivvanono only mouse drivin to load roms. I wrote a loader a while back for gameex. Ill see about intergrating it into HL.
You must defeat Sheng Long to stand a chance.
  • 1 year later...
sorry rise this old topic ...
I Have the loader and run fine by a batch file : ( work - runvivanonno.bat %romname%%romextension%
@echo off
::Autor: Cabecita
::Requisitos: Loader_VivaNonno.exe, VivaNonno.exe, Close_children.exe
CLS
IF %1.==. GOTO ERROR
:MAIN
:: En esta sentencia hago un GOTO porque el nombre de la rom incluye parentesis
IF /I "%1"=="rv2.zip" GOTO RV2
IF /I "%1"=="rrs1.zip" (
SET rom=Ridge Racer 2
GOTO LOADER
IF /I "%1"=="rr1.zip" (
SET rom=Ridge Racer
GOTO LOADER
IF /I "%1"=="rv1.zip" (
SET rom=Rave Racer
GOTO LOADER
GOTO ERROR
:RV2
SET rom=Rave Racer (World-B)
GOTO LOADER
:LOADER
Loader_VivaNonno.exe "%rom%"
set rom=
GOTO FIN
:ERROR
ECHO ERROR. Se necesita un par*metro o el par*metro introducido no es correcto.
ECHO Este script esta dise¤ado para ser lanzado desde un front-end.
ECHO El script debe estar en la misma carpeta en la que est* instalado vivanonno
ECHO y llamar a este archivo desde el front-end.
ECHO.
ECHO Uso: runvivanonno "nombre_rom"
ECHO.
ECHO Nombre_Rom = rrs1.zip
ECHO rr1.zip
ECHO rv1.zip
ECHO rv2.zip
ECHO.
ECHO Ejemplo de configuraci¢n en MaLa:
ECHO ---------------------------------
ECHO Opciones - Configuraci¢n para otros emuladores - B*sicas - Nombre - VivaNonno
ECHO Opciones - Configuraci¢n para otros emuladores - B*sicas - Ejecutable
ECHO - runvivanonno.bat
ECHO Opciones - Configuraci¢n para otros emuladores - B*sicas - Ruta Rom
ECHO - C:\VivaNonno\roms
ECHO Activar Buscar en Subcarpetas
ECHO Opciones - Configuraci¢n para otros emuladores - B*sicas - Extensiones ROMS
ECHO - ,zip
ECHO Opciones - Configuraci¢n para otros emuladores - Ejecuci¢n - L¡nea de comando
ECHO - %%rom%%.%%ext%%
PAUSE >NUL
GOTO FIN
:FIN
Theres a way to run a batch file from hyperspin ( i cant make this work ) or put this bat in hyperlaunch mode ???
  • 4 years later...
Hi guys,
I'll try to revive this tread because I'm starting to go insane with this and I really need help figuring this out.
I'm having some issues while starting Vivanonno in hyperlaunch. If I want to start let's say Ridge Racer 1 (rr1) It just hangs at the game selection screen and I get this :
There was an error while waiting for the window 'Select System ahk_class #32770'.
My question is: Are the roms supposed to be manually selected at this selection screen (with the mouse) or is it automated ?
Because all I see in the VN module is :
; Selecting the game we want to play
If romName = rr1 ; Ridge Racer (Japan-A)
SelectGame(1)
Else If romName = rrs1 ; Ridge Racer 2 (Japan-A)
SelectGame(2)
and so on ..
Also.. my roms are named appropriately they are in the correct folder and launch fine in vivanonno standalone..
Vivanonno version : v22.0.3
Module Version 2.0.1
Any help would be greatly appreciated !
Yeah but for the 3D games, you need a lot of cpu power to have a good frame rate, which I don't .. They run at about 5/10 fps on my setup.
That's why I have to use Zinc and Vivanonno for everything 3D and it works flawlessly. I just have trouble getting hyperlaunch to work with my VN..
