Here I will try to keep the most recent pinball launcher, as I make changes I will update this thread and note the changes. The zip contains 2 files, the source script and the compile exe file, simply drop these into your install directory and thats it.
History:
Current Version 1.1
Test fix for black screen issue when launching Future Pinball, fixed where taskbar shows up when returning to HP
FPLaunch_1.1.zip
I was looking at doing a quick experiment with this AHK stuff.
As you have deployed it, if I make a change to the script file, do I need to have AHK make a new .exe file or does the .exe file just read through the script file?
you need to make a new exe, which means you have to have autohotkey installed on your system, save the file, then right click the file in explorer and click compile from the popup.
  • 1 year later...
  • 2 months later...
History:
Current Version 1.1
A little bit late, but I want say big thanks for this.
I has freezed after start 17 Future Pinball tables with Hyperpin now all works without any errors.
Edited by rosezentrier
  • 3 months later...
hallo i have a black screen problem and can see you have fix i with these file. but i cant find out where i have to put them. are there a nice person there can tell a noob this :-)
Just put them in your hyperpin directory, backup old version of files.
Here is the list of latest versions of fplaunch:
1.2 - BBB version with Exiting in 321 screen
http://www.hyperspin-fe.com/forum/showthread.php?p=25856#post25856
1.28 - improved 1.2 with loading, pause and exit 321 screens
http://www.hyperspin-fe.com/forum/showthread.php?t=10935
1.294 - latest version of this script based on 2.8 with fp support and pause on exit added
http://www.hyperspin-fe.com/forum/showthread.php?p=109551#post109551
1.13 - based on 1.1 - has exit and pause in fp and vp and some other useful features, no loading, pause and exit screens!!!
http://www.hyperspin-fe.com/forum/showpost.php?p=101955&postcount=64
Edited by blur
thank you now i works for me 2 :-) but i cant find where to download this one
1.2 - BBB version with Exiting in 321 screen - but i cant find where to download that one here. but maybe i am blind :-)
http://www.hyperspin-fe.com/forum/showthread.php?t=3062
1.28 - improved unofficial script with loading, pause and exit 321 screens
1.294 - latest version of this script with fp support and pause on exit added
1.13 - also unofficial - improved version 1.1 - has exit and pause in fp and vp and some other useful features
so what ones the latest version 1.2 or 1.294??
Ok just update to the latest version of fplaunch, now for some reason i load table get a black screen the quits back to hyperspin, any ideas??
Hi all.
I'm having a problem with new fplaunch
When exiting from future pinball table get's stuck and future pinball doesn't close.
It doesn't matter if i set FPsave true neither false.
Can Someone help me with that?
Same problem anyone or just me? :(
