Hyperspin Total Editor
Believe the Hype in this Program
Update 21st May 2009
New Version Just Released.... Ok we have added 2 NEW OPTIONS to the Video Converter, MenCoder LQ & MenCoder HQ, This was because of FFmpeg couldn't encode some Xvid/DivX files We tested on the EmuMoview Sega Genesis set and all seemed fine.
MenCoder LQ:- Video Size 320x240 - Video Bitrate 400k - Audio 56k - Audio Sample Rate 22050
MenCoder HQ:- Video Size 640x480 - Video Bitrate 900k - Audio 128k - Audio Sample Rate 44100
Now FFmpeg you can choose your own options. If FFmpeg will convert your AVI's as it does some of them then you will perhaps get a better quality. Also use FFmpeg for WMV files.
File Name Comparer/Renamer We have worked long and hard on this, it has took along time to get to this stage, Although it may not be perfect, it does work... But please remeber this is a work in progress for us as we try to improve the algorithm... We will not be resposible for any loss of files, although the program does create a Reverse Rename Batch File so you can rename your files back to their original names. We have the program Automaticaly Remove Duplicates from the list... We also added some nice little options for you to help filter out problem characters within some filenames.
Anyway please report any bugs back to us...
Download Below
Available on the Hyperspin FTP
or
http://www.mediafire.com/download.php?hjljgkmmmz4
Currently Working On:- Continuing work on our internal database. Also FLV Merger and Screen Recoreder.
Raw Editor Here you can load your XML file and it will display it for you, then you can use the Find and Replace option to correct the & bugs that are in some XML game lists you need to put & in find and & in the replace.
Merge XML This allows you to merge 2 XML lists together, this has been added because as far as our testing has gone our Dir To XML has about a 1000 file limit for some reason.
Dir To XML Here you can create a XML Game list by browsing to your Rom, Png etc folder and selecting all or some... ? of your files that you want to create a list from. It supports ALL FILES There There can be problems with file name that have & in their name, if the name is sonic & knuckles thats fine our program will correct this for you but if its Sonic&Knuckles where there is no space then you will need to use the Raw Edit option afterwards. Also there seems to be around a 1000 file limit, we don't know why this is...? But you can create more than 1 XML and Merge Them with our Merge XML util.
Avi To FLV Converter New to convert AVI's to FLV with options.
System Editor With this you can add your new system theme to your main menu XML list, just load the Main Menu.XML and you can add any new main system themes you have installed. e.g Vic 20, Gameboy etc.
XML Editor This now displays your Game/Rom count in your Game XML list.
Image Converter Used to convert your images to PNG format this will run single or Batch which is great if you have 1000 box art images.
Internal Database Config For Previewing Our Built-In System XML's, In Later Versions.. It will be used for importing data into your XML's. (This is in testing now and is almost complete).
File Renamer Is now working, 95% Done on this, but can be used, It works fine and effectivly!.
System Theme Uninstaller As requsted this will uninstall your MainSystem Themes. Such as Nintendo, Mame etc. Please be carefull and report any bugs.
Bug Fixes Fixed some bugs and improved Fix Xml and Format XML.
What We Are Working On
Pictures:
Designed by: Tonycrew
Coded by: Dean Reynolds (My 12 Yr-Old Son)
Fixes by: Dean Reynolds
Can i just say my son has worked really hard on this to sort all the errors out, he has put alot of hours into this, and really in the space of more than a week has got alot done on this, especially for a 12 year old who has taught himself.
Man I cant believe a person only 12 years old made that, he must be very smart. I see a theme generator there, nice. If you need to know any of the parameters let me know.
My son thaksyou for the replies...
That would be good if you you could let us know...
wow thanks, but the theme editor has 1 small bug, dont worry it works, its only very small..
Very cool.
This almost makes me want to create my own kid. I'm sure my parenting skills would be subpar and would never be able to raise such a promising fellow.
Thanks very much!
I know it wont, I was just asking if it ever will, some people like to use good named roms and would rather rename the artwork rather than rename the roms. It was a feature I considered adding to HQ.
Right i see what you mean... i dunno really it depends on which way it would work... theres the fatbatch way or using actual Dats...
Extensions that should be added would be lnx, fpt, int, ngc, nes, 32x, cdi, sms, lst, mdf, img, nrg.
Those are most of the ones I can think of right now, there are probably others, but that is most of the ones you are missing.
No problem they will be in the next update... :)
Ok added support for lnx, fpt, int, ngc, nes, 32x, cdi, sms, lst, mdf, img, nrg as well as ALL FILES please read 1st post for important info on this.
BadBoyBill
I spoke to my son about this and we think it might be just a little to much for him to impliment at this time :( but we think that he maybe able to add something like Fatbatch to our editor, he is looking into this.
Hello, I am getting upto towards the Artwork/File/ROM Renamer, Infact im working on this project almost all day, this one is a tough one but i think i can do it. Thanks!
Thanks... We had a disaster and lost all the source code... :( don't ask....
Anyways we have re done it again... Slightly different and with all our last experience on creating this we found it easier and had less bug solving to do.
A new release will be up soon... :)
I get an error when I try to add a system. I have Vista 64bit.
This is what is under the details section of the error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Argument cannot be Nothing.
Parameter name: file
at Microsoft.VisualBasic.FileIO.FileSystem.CheckFilePathTrailingSeparator(String path, String paramName)
at Microsoft.VisualBasic.FileIO.FileSystem.WriteAllText(String file, String text, Boolean append, Encoding encoding)
at Microsoft.VisualBasic.MyServices.FileSystemProxy.WriteAllText(String file, String text, Boolean append)
at iVeam_Editor.Form1.Button16_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///E:/HyperSpin/HP%20total%20editor/Hyperspin%20Total%20Editor.exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
