dreamkey56 Posted October 19, 2013 Posted October 19, 2013 Hello. Can get the following Siemens contactors very cheap: 3RT1016-1BB42 The type number is nearly the same, as the ones, that have been used by many cab owners. They are 24 V, which doesnt matter for me, because I have a 24V supply. But will the sound of them be ok? And are they fast enough? Does anybody know? Would be really fine if somebody can tell and help me, as they are really cheap. Thank you, HP
mikekim Posted October 20, 2013 Posted October 20, 2013 They sound ok in a cab. You can also modify them by placing metal washers where the coil pin strikes the plastic in the base of the contactor Sent from my GT-N7100 using Tapatalk
dreamkey56 Posted October 20, 2013 Author Posted October 20, 2013 Hi. Yes, i found a video regarding the modification. I think, Only difference between 1BB42 and 1BB41 is the normally-open and normaly-closed standard, which should be no problem in the pinball cab? One more question: How many amps do they have? According Siemens manual 3,3W. At 24 Volt this is only 0.13A. Can it be? Below 1Ampere?? Does anybody know? Thanks, HP
chriz99 Posted October 21, 2013 Posted October 21, 2013 One more question:How many amps do they have? According Siemens manual 3,3W. At 24 Volt this is only 0.13A. Can it be? Below 1Ampere?? Does anybody know? Thanks, HP yes, that should be correct. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
dreamkey56 Posted October 22, 2013 Author Posted October 22, 2013 Thank you, Chrizz. So it is no problem to use my 15 A power supply. Perfect. HP
