How do I exit from a table?
sc204
I am testing hyperpin with visual pinball on a 2 monitor computer. I have 2 tables loaded and they can be selected and played. However I cannot exit a table back to hyperpin.
The only exit I get is VP exit when I hit Q. I tried to turn off esc in VP but didn't help.
If I have to edit the settings file what exactly is needed. Right now it has a number next to exit.
Exit does seem to work fine in hyperpin before loading a game. I get the Back, quit and shutdown options.
Thank you,
Stuart
Run the PinballX Settings.exe, go to Keyboard Input Settings and see what Exit Emulator is set to. If it is set to Q, then it won't work because Q will bring up the VP exit
This was with hyperpin but truthfully I have been trying both and have the same issue on both. I can get into a game but can't exit it. I changed the letters on pinball and still can't get anything but the vpinball exit menu to work.
Thanks for the reply.
  • 1 month later...
By default in HP you can exit a table by holding down the e key for 3 seconds (you may have changed yours). This is how my system runs when using the latest version of FPlaunch.
Hello Volumetric,
Isnt working for me.
When I press e for many seconds, nothing happens.
What is the version of your FPlaunch?
In my hyperpin Folder there are two different ones. Can i simply delete one of them?
Where can I adjust FPLaunch, to tell it to use button e to exit?
I ve been told to do this in fplaunch ini, but is it the .ahk files?
Thx
Are you using the latest FPLaunch1.295wip10?
I'm not having any problems after recently hooking up HyperPin
