ebarlow99 Posted March 13, 2012 Posted March 13, 2012 guys, am i correct to say:with a 3 screen setup (playfeild,backglass,dmd) i need to use FS tables? or do i use SPANNED? under the cabinet downloads on vpforums? FS..or you can make spanned into FS http://www.bartop-arcades.com
ebarlow99 Posted March 13, 2012 Posted March 13, 2012 Thanks for this thread! Good info! As a n00b to pin cabinets, I am doing "research" to figure out if/how to build my own. Maybe its a good idea to add some info about (force) feedback equipment? I read about shakers, knockers, contacters, solenoids, wiper motors, cree's, etc. Some components I understand how/why they are used, but most of them hold many a secret still :-) i would use this thread http://www.hyperspin-fe.com/forum/showthread.php?t=14625&highlight=lego along with his list of parts http://24.234.255.202/pinball/batpin-shopping-list.txt then finish up with his wiring diagrams here http://24.234.255.202/pinball/diagrams/ should be about good! http://www.bartop-arcades.com
tetrafred Posted May 4, 2012 Posted May 4, 2012 How do I get three monitors to work? You can use the ATI "Three eye infinity technologie" with a active display port adaptateur to DVI-D (26€ for the Saphire model on EUR). It's work perfectly with only one Graphic card on a motherboard with only one PCI express 16x slot. The FPS is the same as 1 or 2 monitor. http://www.sapphiretech.com/presentation/product/?cid=4&gid=1010&sgid=1011&pid=0&psn=000101&lid=3&leg=0
spec Posted November 4, 2012 Posted November 4, 2012 thanks for the thread!! great info ooking forward to building one soon
irondragoon Posted January 16, 2014 Posted January 16, 2014 When you are looking at TVs or PC Monitors, is there a technical word for "when the power comes on your power strip, the TV monitor turns on" or "The monitor/TV you are looking at remembers its power setting/state" that I cannot seem to Google Fu? I quite frequently entertain the idea of building a cabinet but it would drive me nuts to have to explain to people "first turn on the cabinet, then go get the remote and switch on the playfield" or worse yet, all the former plus "and don't forget to switch to game mode too otherwise your table will lag causing needless ball drains". Setup Multiple Systems on One wheel
somail Posted January 16, 2014 Posted January 16, 2014 something like this for the PC: http://www.tomshardware.com/reviews/bios-beginners,1126-8.html Look at AC Power Loss Restart Also look at smart power strips. They have a master plug which when active will automatically send power to all other devices. So plug your TV into the master plug of the power strip and PC (set to auto wake) into a slave plug on the strip. When the TV is turned on then the PC turns on. If the TV is turned off then the PC power is automatically cut. (of course this method risks disk corruption) You can do the reverse if the TV is set to turn on automatically. Sometimes this requires some soldering of the powerbutton. There are many other ways to accomplish such a feat.
Luckydogg420 Posted January 16, 2014 Posted January 16, 2014 Most tv's have power button memory, if your watching tv and the hydro goes out, then when the hydro comes back on the tv will auto turn on because that's the last state the device was in. To test this in a tv store simply unplug the tv while it's turned on, if the tv turns on again once you plug it in (without touching the power button) then that's the tv you want. Samsung, sony, insignia, RCA, most pc monitors, all do it.
fiatbravodriver Posted July 10, 2016 Posted July 10, 2016 Hi does anyone know if T2 is a Wide or Narrowbody cabinet? Thanks.
northvibe Posted December 1, 2020 Posted December 1, 2020 I know this is super old, but T2 is a standard body. Windows 7 x64 i5 2500k OC 4.4ghz nvidia GTX 470 Intel onboard video 8gb ram Crucial M4 64gb SSD
Create an account
Register a new accountSign in
Sign In Now
