SpatzST Posted April 17, 2016 Posted April 17, 2016 But it doesn't launch. Everything else in that folder does. Any idea why? I am using RocketLauncher as well.
Metalzoic Posted April 17, 2016 Posted April 17, 2016 You have a shortcut to HyperSpin.exe in the startup folder, not the actual file itself right? If so then that should work. I guess try making another shortcut in case it glitched? You could also try making a bat or AHK file to launch it I suppose.
SpatzST Posted April 17, 2016 Author Posted April 17, 2016 You have a shortcut to HyperSpin.exe in the startup folder, not the actual file itself right? If so then that should work. I guess try making another shortcut in case it glitched? You could also try making a bat or AHK file to launch it I suppose. correct it is a link to hyperspin.exe, the other files in there work so i'm not sure why HS isnt. I'll create a new one I guess and see if that helps. thanks
kylecp1979 Posted April 17, 2016 Posted April 17, 2016 1 userC:\Users\Username\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startupall usersC:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp try one of these paths top one is for 1 user the bottom is for all users change username to your PC's user name
