55" playfield too big?
lemming
Hi Guys
Looking for some guidance.
I'm tossing up between these 2 monitors for a custom built virtual pinball cabinet.
http://www.kogan.com/au/buy/55-led-tv-full-hd-120hz-pvr/
http://www.kogan.com/au/buy/46-led-tv-borderless-full-hd-motion-max/
One is a 46" frameless that is 61.6cm wide, which should fit in a standard bally wide body cab (63cm) using a routed slot, without even decasing it.
The other is a 55" frameless with a 70.2cm width, so the cabinet would need to be larger than standard. No problem, but I'm wondering if it would actually be too big to play comfortably on. I guess the cab would be roughly 72cm wide if I slot it in without decasing it.
What I like about the 55" is that it has a Samsung panel, is brighter, and says it does 120Hz at 1080p when connected to a PC.
Is a 55" too big? Has anyone tried?
I don't mind getting a custom lock bar made. I just want to know if it's too big to play comfortably.
The place I'm looking to buy from has free postage for the next 5 or so hours, so am looking to pull the trigger.
Thanks for the feedback
Per post on other forum, will be like playing with a baseball, go for a 46/32
WWW.Xtremepinball.com
CNC Work Here.....
