MameUIFX 64bit + NoNag - Raw-input 0.173
sevenseal
File Name: MameUIFX 64bit + NoNag - Raw-input 0.173
File Submitter: sevenseal
File Submitted: 04 May 2016
File Category: Other
Credits: Sevenseal
no nag code added,
must be install over a fresh install of 0.173 setup, NO PREVIOUS INSTALL can be used
- Added support for all core options related to INTEGER SCALING in the GUI
- Added support for all ProgettoSnaps screenshot packages in the GUI
- Increased refresh rate in Nebulas Ray to "fix with an hack" MAMETESTERS bug ID 3488 [dany777]
if you would like to have dual lightguns
you must make your aimtrak lightgun into joystick instead of mouse mode.
orignally you had to set your lightgun as mouse to have both guns detectable on mame along with working right.
now on 172+ you must set you LIGHTGUN on JOYSTICK mode
test using these setting on mame.ini
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr                     XArcade
mouse                     1
joystick                  1
lightgun                  1
multikeyboard             0
multimouse                1
steadykey                 1
ui_active                 0
offscreen_reload          1
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           lightgun
positional_device         keyboard
mouse_device              mouse
I wonder how changing from mouse mode to joysticks affects all other emulators and pc games (hotd3, blue estate). I will test that out in the morning.
Did some testing and these settings did work for 2 lightguns in mame 173 but all of the other emulators stopped working lol.
Maybe the mame devs will put back mouse support... otherwise I will stick with 171 for mame so everything else works. Maybe someone else will have better luck
This is MAMEUIFX, which is arcades only... try the other build
its the same regardless, only real different is the ui
with minor addition of what mame provide.
ui is only for arcade but can be made used with both.... ui only appear for arcade side.
this compile is made with arcade only.
this build works for both guns but only if I set the guns in ultimarc app to joystick mode, which renders them useless in the other emulators.
I could never get them to work in any other build of 173
what other emulators that you speak of?
  • 5 weeks later...
