Random5095490 Posted May 15, 2016 Posted May 15, 2016 Sorry for making several threads but I again have more questions and issues. If these posts are causing too much spam or causing any issues here please tell me. 1 How do I stop the fade-in and fade-out of the controller buttons so that they remain permanently? 2 Is it possible to add 4 players all with their own controllers instead of only having Player 1 and Player 2 in Hyper HQ? 3 For my NES system I have the rom path set in both Hyper HQ and rocket launcher, all games are recognized when I audit inside of rocketlauncher, and I have all the artwork for each rom. However, when I go inside the NES wheel only 4 titles appear? 4 I have scanlines checked in HyperHQ and it pointed to a scanline image but I get no scanlines in Hyperspin? 5 For some windows games, Halo Online for this example, I have to open a launcher and navigate to the start button with a mouse to launch the actual game. Could I somehow automatically start a game launcher with no input needed or skip directly to the game? Preferably a way to start without needing to use the mouse as I have it hidden and want it to remain hidden. 6 I have the exit menu for Hyperspin enabled inside of HyperHQ but the menu will not appear?
Retro Goonie Posted May 15, 2016 Posted May 15, 2016 3 For my NES system I have the rom path set in both Hyper HQ and rocket launcher, all games are recognized when I audit inside of rocketlauncher, and I have all the artwork for each rom. However, when I go inside the NES wheel only 4 titles appear? When you say "only 4 titles appear"...do you mean artwork only appears for 4 games or only 4 games are selectable?! With box art, cart art, wheel art etc...make sure they all have the same name(s) as the rom(s). If they don't match 100%, they won't show up in HyperSpin! Ps. I only set my rom path inside Rocketlauncher and it works fine. I don't think you have to do it in both RL and HQ. 4 I have scanlines checked in HyperHQ and it pointed to a scanline image but I get no scanlines in Hyperspin? I just tried this in my setup and it works so I don't know why it's not working for you! My Artwork! Carts: GCE Vectrex 2D Carts (Realistic Version) 1.0, GCE Vectrex 2D Carts (Vector Version) 1.0 Pointers: NEC PC Engine Pointer(s), NEC SuperGrafx Pointer(s), Sega SG-1000 Pointer(s), Sega TecToy Pointer(s), Sega Mega Drive Japan Pointer(s), Nintendo 64 Pointer(s)
Metalzoic Posted May 15, 2016 Posted May 15, 2016 1. Are you talking about the joystick/buttons/free play animation that displays in HyperSpin? You can turn it off, but I don't think you can control the fade in/out. 2. Controllers are a whole other topic... 3. You only need to have a path to your roms in HyperHQ if you want to use the filters (roms only, parents only etc...). If only 4 games are showing you either have the path not 100% right, or you maybe have the filters set in a way that is keeping them from showing? 4. No idea. Don't use that feature and set up your shaders in Retroarch or MAME/MESS instead. They are worlds better. Or the latest version of RL has shaders built in now too. 5. Depends on the game. If it will accept command line launch parameters then there is a place to set those instructions on a game-by-game basis right in the PCLauncher module settings. If a game doesn't support that then you would probably need to write your own AHK script to do it yourself. https://autohotkey.com/docs/Tutorial.htm#s1 6. Exit menu? Not sure what you mean.
gibson75 Posted May 18, 2016 Posted May 18, 2016 What version of retro arch can I use with hyperspin?
Guest Posted May 18, 2016 Posted May 18, 2016 What version of retro arch can I use with hyperspin? If you're using RocketLauncher along with HyperSpin (you really should be if you aint), then the latest nightly should be fine.
gibson75 Posted May 18, 2016 Posted May 18, 2016 Yes I run hyperspin with Rlauncher so what's the highest version of retroarch can I use ??
