GameSet and Match. An Image Set tool
You guys over here at hyperspin are pretty awesome with the image sets. At various points I've been collaborating with others to produce image sets (such as developers logos and marquees) but it was quite a tricky process.
Easiest way to do it is to have a cloud account and all collaborators shared the same folder, but you also have a local copy of the image set. Bit hard to explain, but in short - should help you guys collaborate or it also helps with making up full sets individually.
You guys use hyperlist don't you? If you're needing me to integrate the hyperlist xml into this app - just let me know.
Vid:
Download + further info:
https://gamesetmatch.codeplex.com/
Hope it helps.
Go to site
I have been wishing for a long time for a program that I could use to quickly and easily discover missing artwork for a set. If you could make this perform that function using the hyperlist databases that would be superb.
Sent from my SM-G920V using Tapatalk
Someone post me an example playstation xml + I'll have a look at integrating hyperlist(??) format into GSM.
Don't think so, potts as it's a click-once release. I don't know if most people prefer it that way.
@ninja - sorry - i'm no familiar with the HS forums - but happy for anyone to move this post etc.
Go to site
just click download at the top. Then there is a green button in the top right corner that reads upload. Press it and fill in the blanks and press submit
*select category third party apps
@ninja - Ah. Well it won't work. You need to download it from the codeplex site as it's a click-once application. This ensures automatic updates and deployment.
EDIT: Scrap that - you might be able to install as stand-alone, but not sure whether effects the automatic update or not. Will upload.
Go to site
There you go fellas. Have added Hyperlist support. Let me know if any probs:
 1.2.0
 Added facilitiy for Hyperlist parsing
 Added faciltiy to remove tags (bracketd text) from Database filenames and Gamenames (only in HS at the moment - not needed in GE?)
 Added open folders buttons to main edit window.
It will autoupdate when you next launch the app (I think - if you download from codeplex then definitely. If you download from your repository here, I'm not so sure).
Go to site
Sorry fellas, I dumped a bad version on you last time. Now been updated with lots of new features:
 1.3.0
 Fixed Select All bug
 Fixed major deal breaker - Other folders not being matched.
 Added setting to show images that also match the gamename.
 Added overide saveas when moving images between folders - allows manual setting of filename (made safe)
  Added open search result images in image editor for editing before putting image set folders
 Added image search preview
 Added save any images as png when moving/adding/copying - produces unified sets of png images
 Added database backup roller - keeps rolling backup over months, weeks, days - limited to 10 files
 Added open logs/chagelog buttons
 Added manual backup and restore of database.
 Added image webserch function!
update  op too
Go to site
