Hypertheme graphic motion
Can a graphic be moved into the screen using HyperTheme, to simulate a tank driving onto the theme screen or would I need to use a flash program, using a motion tool.
Thanx.
This was easy but for those, like me, who were in the dark until a fortuitous moment of clarity freed my torture etc. Just select a starting position for your artwork (in properties), default is none - the others are - left, right, up or down. When you play your video, the selected artwork will enter from which ever position you have chosen. Basically, the artwork will slide in from the left and continue to the right if you have chosen (position starting left). It will then stop where you have placed it originally on the screen. I used Adobe Macromedia Flash to make them enter at various angles, e.g. diagonally.
Yes it shows your layer animation options on the left. I believe it also shows your animation options along the bottom?
You set where it comes in from and where it settles, what animation it uses to do that and what it does after it gets there. How long it takes to start and how long it takes to finish. Same for your video layer.
Your video frame cannot be animated separately from the video though which limits its extra trickery.
