sajazzman007 Posted July 14, 2016 Posted July 14, 2016 Good Afternoon All, I have all the images, videos, themes, wheels, bezels setup for Mame in HS/RL and thought it would be a great idea to start creating "Classic" folders to assist in scanning through 7000+ games. As I start to setup all the classic folders, I began to think I will have to copying wheels, themes, videos, images, bezels for RL etc. I was about to just copy and paste my current MAME vids, images, etc for each classic folder however that is a lot of wasted space. I look through some of the forums for solutions and saw someone mentioned Link Extensions however not in great detail. Is there a program that can redistribute HS media files in one location to using classic folders via.xml files or will this have to be manually done? Thanks
damageinc86 Posted July 14, 2016 Posted July 14, 2016 The video part is easy, it's under HyperHQ for each system you can point it to a video folder. So all the classics get pointed to MAME video folder. As for the other media, I have used the hyperspinrommanager program to run my MAME media against each classic database and then copy that over to their respective folders. I also have a mame.xml that was ran through don's tools in order to remove all of the classics and crap games (trivia, mahjong, othello, etc.) leaving a "mame left over" xml. That is now my main mame.xml so then running the hyperspinrommanager against that database, copies the media needed only for the main mame system.
sajazzman007 Posted July 14, 2016 Author Posted July 14, 2016 On 7/14/2016 at 6:17 PM, damageinc86 said: The video part is easy, it's under HyperHQ for each system you can point it to a video folder. So all the classics get pointed to MAME video folder. As for the other media, I have used the hyperspinrommanager program to run my MAME media against each classic database and then copy that over to their respective folders. I also have a mame.xml that was ran through don's tools in order to remove all of the classics and crap games (trivia, mahjong, othello, etc.) leaving a "mame left over" xml. That is now my main mame.xml so then running the hyperspinrommanager against that database, copies the media needed only for the main mame system. Thank you so much damageinc86. I tried this out with my Atari Classics and it got all the wheels right and videos right however several of the themes are wrong (give or take about 50). I will have to go through and search for the correct themes later. This was a far better solution than what I was going to go with.
damageinc86 Posted July 14, 2016 Posted July 14, 2016 Ahh well at least something worked well. I have never used game themes with Arcade classics since I use the custom Hypermamu theme and wheels. But 50 should be too hard to manually rename.
Metalzoic Posted July 14, 2016 Posted July 14, 2016 Symbolic links. That way you only need a single themes, wheels etc... folder and all your manufacturer wheels share from it. Read this topic: http://www.hyperspin-fe.com/topic/13152-arcade-classics-as-a-main-wheel-with-media-simple-solution/ The link is in post #6. You now owe me either $100 or your firstborn son. You choose.
sajazzman007 Posted July 15, 2016 Author Posted July 15, 2016 Thanks guys I appreciate it. I went with the first method and it worked like a champ however, I will look more into Symbolic Links for the future I tried to do the same with Williams Classic but for some reason the ROMs are all jacked up. It freezes up RL. Maybe i need a new ROM set. All the ROMs are green but they don't work right. I have .173 right now. I don't know if they were fixed in the update or what. Lastly off topic, I also read up on individuals using Zinc emulator or MAME, what would you recommend and why?
Metalzoic Posted July 15, 2016 Posted July 15, 2016 On 7/15/2016 at 5:07 AM, sajazzman007 said: I went with the first method and it worked like a champ however, I will look more into Symbolic Links for the future I tried to do the same with Williams Classic but for some reason the ROMs are all jacked up. You could have all your manufacturer wheels up and running with no duplicated media and no issues in just a few minutes using Symbolic Links.
maks Posted July 15, 2016 Posted July 15, 2016 Lookup Hypermint 2.0 in the RocketLauncher forums. It creates the symbolic links for you and offers a UI that makes editing xmls easy. As long as your setup isnt on a network drive it will create all the symbolic links for you as well. Sent from my SM-N910P using Tapatalk
damageinc86 Posted July 15, 2016 Posted July 15, 2016 There is no duplicated media if you delete the files from the directory that hyperspinrommanager copied from. That Hypermint looks cool though.
