Taito Type X Resolution
nutter1980
Hi all, So I can get TTX to work with hyperspin no problem.
The issue I have is I do not seem to get the games to run in a good resolution.
Eg- Samurai showdown runs in 800x600 as does Street Fighter Arcade edition.
I am running on a Samsung TV 1920x1080 and would ideally like to run at the best I can.
Can anyone else share there experience with this ?
Thanks !
You can play with the different resolutions of each game to find what works best, while some games require a certain resolution to even work.
For example there is only one resolution you can set Samurai Shodown at where it will play widescreen, but not be stretched.
Chaos Breaker has a specific rez it looks best at (640x480? can't remember)
That Steampunk fighting game only has a single resolution it even display properly in.
You just have to test each one to find what makes it tick.
These games aren't designed for 1080 so trying to run them at rez's better than 800x600 can often make them look worse (obviously).
That was me. Made a bezel for Chaos Breaker using Sub Zeros fake shader.png like Alex used in his Atomiswave bezels.
Sent from my SM-G935V
Some you can change the resolution in the file"gameres.dat" or "settings.arc", others require different hacked exe's.
And yes bezels help a lot, AlexDC22 made some,you should be able to find the ones we worked on some years ago in his signature with his other work.
Awesome post and thanks for the solved issue! I was going through the same thing on my set up.
BrewMasterLex Crafted Ales And Retro Gaming
Current Gaming Rig
  1. Alienware Alpha i7 GTX 960
  2. PS4
  3. PS3
  4. PS2
  5. Xbox One
  6. Xbox 360
  7. Xbox Original
  8. Nintendo Wii U
  9. Nintendo Wii
  10. Nintendo Gamecube
#Cheers4GreatBeers!
