j600com Posted July 26, 2016 Posted July 26, 2016 Hi, Brand new to this, so forgive me if this is just a case of me being dumb. So I've tried to follow the setup process on the forum, thought I'd done it right - did the whole process step by step. So I reboot the Nvidia Shield TV, click on the Hyperspin logo - and all I get is a "Unfortunately, Hyperspin has stopped" message. I can't even open the app. I've tried then re-installing both Hyperspin and Retroarch but still not working. Anyone got any ideas, completely stuck :/ Thanks
thatman84 Posted July 26, 2016 Posted July 26, 2016 You will get it going soon! have you had the app open at all yet or was this first go? Retroarch should be separate so I would concentrate on making sure you have your Hyperspin folder in the correct place on the root of your sdcard or internal drive. Make sure Hyperspin is not running, check in the Shield settings/apps menu. Then try again If you can just post up your steps so far hopefully someone can spot an easy solution for you. At work ATM so can't remember off my head what it would be without a little testing. Don't think I have had it force close before. Maybe sometimes when I have tried to launch a game from Hyperspin that I have not closed properly in retroarch. Your not getting that far though! Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
reznnate Posted July 26, 2016 Posted July 26, 2016 Indeed, at this initial stage, Retroarch and other emulators are a non-factor until you start launching games. Take a bit of time to read through the sticky posts (known issues, basic setup, etc.) I'm assuming this setup hasn't been tested and working on Windows yet? I suggest you focus on a single wheel (reduce the entries in '/databases/main menu.xml' Ensure your /media/frontend folder is correct and includes at least one video file in /frontend/video/transitions. Ensure your /media/main menu has the necessary images, videos, themes Make the theme/rom filtering modes false in the /settings/<system name>.ini file If you are familiar with Android,enabling ADB so you can watch logcat helps me debug setup issues tremendously.
j600com Posted July 26, 2016 Author Posted July 26, 2016 I think I tried to add too much at once. Gone back and started again one console at a time and so far so good! Managed to get the following running so far; Atari 5200 - roms not loading (it just flickers when you click a game) Nintendo 64 / NES / SNES / N64 - working perfect Sega Master System / Mega Drive - working perfect MAME - in progress Hopefully going to try and add a few more consoles later. And also wouldn't mind Commodore Amiga, but wasn't if that was supported.
thatman84 Posted July 26, 2016 Posted July 26, 2016 Glad your getting things going Screen flicker sounds like a mistake in your launch path params. Spelling, space wrong path. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
