Linkseo Posted August 4, 2016 Posted August 4, 2016 Ive set up hyperspin on a 2nd pc and for some reason i cant get my 360 controller to work the HP menu. It works fine in the games just not in hyperspin. No idea of what i did differently. In hyperhq under the controls > joystick tab, everytime i check the box "joystick enabled" it becomes unchecked when i close and go back into hyperhq. This is the only difference i can find between my 2 pcs. Is there something i need to do to make the joystick enabled box to stick? Hope someone can help me. Ive waisted waaay to many hours trying to figure this out
Linkseo Posted August 4, 2016 Author Posted August 4, 2016 ok now that i've had a chance to cool off and look into this again, it seems that something is very wrong my HyperHQ on my other PC. Not only is it not keeping the settings i make to controls, (enable joystick box does not stay checked when i reopen Hyper HQ) The stuff in the volume tab doesnt work either. I lower the volume on some settings then i close HyperHQ. when i reopen it the settings are back to default. Is there an option somewhere in HyperHQ that forces everything to revert to default when i close it? or can i remove hyperHQ and reinstall it again? not sure if it comes by itself. worst case scenario is i have to try and reinstall Hyperspin along with everything else. I'd rather not do that. Has anyone else had this problem that hyperHQ reverts back to default settings when you close it? If anyone can provide some info on this it would be greatly appreciated.
Metalzoic Posted August 4, 2016 Posted August 4, 2016 Is your HyperHQ settings file set to read-only?
Linkseo Posted August 4, 2016 Author Posted August 4, 2016 Just checked. Its not. How i wish it was something that simple. I even tried running as administrator. Same deal. Settings keep reverting back to default when i close HyperHQ
Linkseo Posted August 4, 2016 Author Posted August 4, 2016 I'll check that tonight. Where can i find the ini for hyperspin frontend? I dont think i made an exception for hyperspin on this 2nd pc. Hmm I'll check that tonight also. Hyperspin never seems to get blocked from launching though. Hmm Thanks for the suggestions.
Linkseo Posted August 4, 2016 Author Posted August 4, 2016 Copy that. Ill update tonight to see if this helped. Thanks
Linkseo Posted August 9, 2016 Author Posted August 9, 2016 So apparently my settings.ini file was missing altogether. How this happened? I have no clue. But i downloaded HS again. The settings.ini file is now there and everything seems to be working including my 360. Thanks to everyone in this great forum for the help.
Metalzoic Posted August 9, 2016 Posted August 9, 2016 It was missing? I thought you said you checked it and it was set to read/write?
Linkseo Posted August 9, 2016 Author Posted August 9, 2016 What i checked was the HYPERHQ.exe to see if it was on read only
Dime333 Posted August 10, 2016 Posted August 10, 2016 My ini file also mysteriosly vanished a couple of days ago. Very strange. I changed a setting in hyperHQ. Then the ini file ONLY contained that last setting. A while later, the ini file was gone. Not in the thrashcan or anything. Luckily I keep a backup.
Linkseo Posted August 10, 2016 Author Posted August 10, 2016 Technically mine didnt actually disappear. When i tried copying and pasting a settings.ini file from my other pc just to test it, it kept saying "do you want to replace it?" even though everytime i check its not there. Must be hidden. Weird. Anyway i couldnt figure it out so i just redownloaded HS to get a new ini file.
jordanli8 Posted June 26, 2018 Posted June 26, 2018 On 8/4/2016 at 11:52 PM, Linkseo said: ok now that i've had a chance to cool off and look into this again, it seems that something is very wrong my HyperHQ on my other PC. Not only is it not keeping the settings i make to controls, (enable joystick box does not stay checked when i reopen Hyper HQ) The stuff in the volume tab doesnt work either. I lower the volume on some settings then i close HyperHQ. when i reopen it the settings are back to default. Is there an option somewhere in HyperHQ that forces everything to revert to default when i close it? or can i remove hyperHQ and reinstall it again? not sure if it comes by itself. worst case scenario is i have to try and reinstall Hyperspin along with everything else. I'd rather not do that. Has anyone else had this problem that hyperHQ reverts back to default settings when you close it? If anyone can provide some info on this it would be greatly appreciated. go to joystick untick player 1 the click set joy id click ok then press any button on xbox 360 controller
