dreamkey56 Posted February 13, 2014 Posted February 13, 2014 Hello. I have a problem with my motion plunger kit: It disconnects automatically after a few seconds ( sometimes more, sometimes less), When I am playing a table. First I thought, it is related to my opto board, because happened the first time, after i installed my opto board. But now I putted my opto board away, and have still the same problem: motion plunger board disconnects automatically. I have to plug the USB port out and in, and then it works again. For a short while. Can anybody help me? Any idea? Thx, Hp
Drnick Posted February 14, 2014 Posted February 14, 2014 Drawing too much power from USB socket possibly. Have you tried different sockets, are you using a Hub, Powered Hub, Connected to front panel of PC or Direct to Board Port?
dreamkey56 Posted February 14, 2014 Author Posted February 14, 2014 Hi. I tried different sockets, USB2.0, USB3.0, Front, Back, and on the separate RocketfishUSB Card, where my pindmd is connected. Everywhere the same. I will also try a powered USB Hub, but I am afraid, this is not the problem, because it worked for many weeks without this problem..
Drnick Posted February 15, 2014 Posted February 15, 2014 I will assume that you have also swapped out the cable then. In which case it's going to be back to manufacturer for you me thinks.
dreamkey56 Posted February 16, 2014 Author Posted February 16, 2014 Hi. Swapping USB cable isnt possible, As it is glued in in the box. Not a separate cable. Is there a possibility, that this is a software problem, or is it hardware related, so I have to send it back? Hp
dreamkey56 Posted February 17, 2014 Author Posted February 17, 2014 Hi again, I tried another old VP configuration, that I saved on another hard disc. Still the same Problem, when I start VP here. Only wanted to check, if there is something wrong with configuartion. For me it seems, that the board has a Hardware Problem
vampirolatino2 Posted February 18, 2014 Posted February 18, 2014 edit: read below. It's a hardware problem on that kit. RMA that ... stuff... lol
vampirolatino2 Posted February 18, 2014 Posted February 18, 2014 I read that this is a common problem for that kit. More info here: http://www.vpforums.org/index.php?showtopic=25885&page=4 I recommend that you contact Noah for a RMA
