mihaliousa Posted August 9, 2016 Posted August 9, 2016 Got the games to launch through hyperspin for this system. However have not managed yet to configure controls nor do i know how to bring up the menu to set them as none of the shield controller buttons respond.
thatman84 Posted August 9, 2016 Posted August 9, 2016 What emu are you using? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted August 9, 2016 Posted August 9, 2016 Does your mame git still have a video bug? I can barely make out menu in mame git
mihaliousa Posted August 9, 2016 Author Posted August 9, 2016 What emu are you using? I am using mamegit on retroarch
mihaliousa Posted August 9, 2016 Author Posted August 9, 2016 Does your mame git still have a video bug? I can barely make out menu in mame git No, it does not - only issue is the controls. Any ideas how to figure them out?
badhemi Posted August 9, 2016 Posted August 9, 2016 No, it does not - only issue is the controls. Any ideas how to figure them out?I'll check later
badhemi Posted August 10, 2016 Posted August 10, 2016 I can get mine to work. I just press left trigger then go into "input this machine" then select the start letters
mihaliousa Posted August 10, 2016 Author Posted August 10, 2016 I can get mine to work. I just press left trigger then go into "input this machine" then select the start letters Got it to work, thanks! Just had to redownload mame git as pressing the left trigger did nothing for me in the first place. After redownloading though, it worked.
mihaliousa Posted August 10, 2016 Author Posted August 10, 2016 My video loading page is still blurry. Redownload mamegit and then try again.
mihaliousa Posted August 10, 2016 Author Posted August 10, 2016 use an older version of retroarch, that might do the trick
